i put the install directory into my browser and it came up that config.php could not be found, what am i doing wrong? please help.
Board3 Portal install error
Re: Board3 Portal install error
Did you upload all files as stated in the install.xml?
If you did, try to make sure you have phpBB3 installed. The config.php is part of phpBB3.
Regards, Marc.
![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
Regards, Marc.
