Creating Portal Block With No Padding
the.ronin
Post by the.ronin »
The default style for the portal block has an inherent padding. When I imbed a Flash file file, I have to resize it to take the padding into consideration otherwise it “breaks” outside of the protal block and disturbs the spacing between the center and side blocks.
I have tried to address this by changing from:
<!--version $Id: link_us.html 236 2008-05-18 15:50:06Z kevin74 $ //-->
<div class="portal-panel">
	<div class="inner">
			CONTENT
<br style="clear:both" />
... to:
<div class="inner">
<h3>TITLE</h3><br style="clear:both" />
</div></div>
<div style="margin-top: -10px; background-color:#D2D9E3;">
			CONTENT
		</div><div class="portal-panel"><div class="inner">
Although the changes remove the padding and I am able to resize the Flash file to the full width of the portal block, it ruins the style in IE6.
Is there a cleaner way to remove the padding for a particular block which would be compatible with IE6? I presume I need to make a new style class?[/i]
