I have a question. I'd rather have forabg boxes over panels and I used phpbb3 portal for a long time and edited it a lot so I'm pretty familiar with how this portal works. At one point, I changed all the panels to forabg's and added my own icons. You have the icons added which I would like to keep. So I tried to change it but ran into some problems:
http://i34.tinypic.com/2ia51jp.jpg
As you can see, the random member block title now breaks for some odd reason although it has plenty of room to do it straight across. Also, it's not centered anymore. I looked with Internet Explorer 7, and it's still centered so I don't understand why it's not correctly working in Firefox. My code for that block is:
<!--version $Id: random_member.html 260 2008-08-09 20:23:45Z icedcold $ //-->
<div class="forabg">
<div class="inner">
<ul class="topiclist">
<li class="header"><dl><dt><img src="{T_THEME_PATH}/images/portal/portal_random.gif" width="18px" height="18px" alt=""/>{L_RND_MEMBER}</dt></dl></li>
<ul class="topiclist forums">
<li><dl>
<dd class="posts_portal">
<!-- BEGIN random_member -->
<div style="text-align: center;"><span style="font-size:12px; padding-top:1px; margin-bottom: 5px;">{random_member.USERNAME_FULL}</span><br style="clear:both" />
<!-- IF random_member.AVATAR_IMG --><a href="{random_member.U_VIEW_PROFILE}">{random_member.AVATAR_IMG}</a><br style="clear:both" /><!-- ENDIF -->
<!-- IF random_member.RANK_TITLE --><span class="gensmall">{random_member.RANK_TITLE}</span><br style="clear:both" /><!-- ENDIF -->
<!-- IF random_member.RANK_IMG -->{random_member.RANK_IMG}<br style="clear:both" /><!-- ENDIF -->
<span style="float:left;"><strong>{L_RND_JOIN}:</strong></span><span style="float:right;padding-right:10px;">{random_member.JOINED}</span><br style="clear:both" />
<span style="float:left;"><strong>{L_RND_POSTS}:</strong></span><span style="float:right;padding-right:10px;">{random_member.USER_POSTS}</span><br style="clear:both" />
<!-- IF random_member.USER_OCC -->
<span style="float:left;"><strong>{L_RND_OCC}:</strong></span><span style="float:right;padding-right:10px;"> {random_member.USER_OCC}</span><br style="clear:both" />
<!-- IF random_member.USER_FROM -->
<span style="float:left;"><strong>{L_RND_FROM}:</strong></span><span style="float:right;padding-right:10px;"> {random_member.USER_FROM}</span><br style="clear:both" />
<!-- IF random_member.U_WWW -->
<span style="float:left;"><a href="{random_member.U_WWW}" title="{random_member.U_WWW}"><strong>{L_RND_WWW}</strong></a></span><br style="clear:both" />
<!-- END random_member -->
</dd>
</dl></li>
