Modifying a custom ACP template module.
cabot
phpBB.com User: cabot
Post by cabot »
Hello,
I have created a module that allows me to display blocks of links retrieved from an extension.
The permissions for displaying these blocks are configured upstream by the extension.
I would like to disable the ‘Module permissions’ block.
Alternatively, if this is not possible, display a message to warn the administrator that the permissions are already set by the extension and that it is recommended not to change anything in this block.
The current code is very basic.
		if (is_object($this->controller_helpers) && method_exists($this->controller_helpers, 'build_sidebar'))
			$this->controller_helpers->build_sidebar();
		return '@gtroph_b3pgtrophlinks/gtroph_links_side.html';
		return [
			'title' => 'B3P_GTROPH_LINKS',
			'vars' => [],
Re: Modifying a custom ACP template module.
This is not possible as it is displayed in every block. You could add something to the PHP file of your block.
within:
cabot
Post by cabot »
So return a message using “legend1” or something like that?
Exactly, it looks like this:
cabot
Post by cabot »
Thx!
