Image Slider
Current Version: 2.3.0
Released: 2023-03-19
Max_69
phpBB.com User: Max_69
Image Slider
Post by Max_69 »
Hi everyone, could I please know how to download image slider? The link at the bottom of the page to download it doesn't work. Thank you so much.
viewtopic.php?p=37986&hilit=slide#p37986
Re: Image Slider
Max_69
Re: Image Slider
Post by Max_69 »
The bottom of the page to download it doesn't work, do i have to be registered to download?
Re: Image Slider
There seem to be major problems with this board.
Max_69
Re: Image Slider
Post by Max_69 »
How do i download? I have to do a test on my forum.
Re: Image Slider
I also can't download it
Max_69
Re: Image Slider
Post by Max_69 »
Ok, I contacted the author and I'm waiting for a response, in the meantime is there another extension that I can insert into the portal as a slider?
Re: Image Slider
I know of no other.
Max_69
Re: Image Slider
Post by Max_69 »
Ok, thanks for the support ;)
talonos
Portal Specialist
phpBB.com User: talonos
Re: Image Slider
Post by talonos »
i replied to your message :)
my website has been offline for over 5 years now so i've no idea why it shows as working.
Max_69
Re: Image Slider
Post by Max_69 »
Ok, thanks so much!! ;)
Max_69
Re: Image Slider
Post by Max_69 »
Would there be a possibility to update to the latest version? I get so many errors and had to uninstall.
Max_69
Re: Image Slider
Post by Max_69 »
I found this, https://www.phpbb.com/customise/db/exte ... anagement/
I made the various changes to make it appear on the portal but the only problem is that it also appears in the index, if in acp I click on the disable button in the index it doesn't appear on the portal.
Re: Image Slider
Max_69 wrote: 12. May 2024 14:56 I made the various changes
What exactly did you change?
Max_69
Re: Image Slider
Post by Max_69 »
Return to “Board3 Portal 2.3.x - English Support”
