Board Refuses To Enable!!!
retroray
i have copied the files to the ext folder installed the extension and i have checked permissions and enabled the board and still will not display the portal page. am i missing something here? any help would be greatly appreciated I am on version 3.3.10
- phpBB.de User: Kirk
retroray
Re: Board Refuses To Enable!!!
hey there... is there any reason why the portal page would not be loading
retroray
If you have set the permissions of a group (where you are also present) to never, you will not see the portal. A never overwrites the other permissions.
Not all portal files have been uploaded.
Look here: https://www.retroraytv.com/forums/app.php/portal
retroray
I fixed it by reinstalling by unzipping files to the ext folder rather than uploading through ftp client atleast everything is working so far thank you for the quick responces
