White Screen
Harewood
phpBB.de User: Jae
phpBB.com User: Jae
White Screen
Post by Harewood »
Just a quick post to see if anyone can help.... or is in the same predicament.
I`m using :
phpBB Board version: 3.3.10
PHP version: 8.1.14
Board3: Latest version
Recent Topics Ext: 2.2.15
However when I activate the Recent Topics extension I get a white screen and nothing is displayed. Is anyone else experiencing the same?
I have uninstalled, cleared cache and browser cache and re-installed Recent Topics extension but same error.
I`ve been to https://www.avathar.be/ for help and also emailed sajaki9[at]gmail.com but no reply yet.
Any help or work around would be appreciated. ;)
Many thanks, Jason
Re: White Screen
Have you tried this?
viewtopic.php?f=72&t=11789
Re: White Screen
There is a problem with the Recent Topics EXT and PHP 8.x.
A fork is available for this: https://github.com/IMC-GER/RecentTopics
Harewood
phpBB.de User: Jae
phpBB.com User: Jae
Re: White Screen
Post by Harewood »
Yes, tried that... ;)
Harewood
phpBB.de User: Jae
phpBB.com User: Jae
Re: White Screen
Post by Harewood »
Thank you Kirk, will try this too.... ;)
Harewood
phpBB.de User: Jae
phpBB.com User: Jae
Re: White Screen
Post by Harewood »
We tried but we received the following error messages after updating Recent Topics extension.
Here is a screen shot:
In phpBB debug we get:
[phpBB Debug] PHP warning: in file [ROOT]/phpbb/db/migrator.php on line 662: Undefined array key 4
Any advice would be appreciated...
Many thanks,
Jason
Re: White Screen
This problem has nothing to do with the portal.
Harewood
phpBB.de User: Jae
phpBB.com User: Jae
Re: White Screen
Post by Harewood »
I understand that... just wondered if anyone else here has experienced the same and managed to resolve in anyway? ;)
BriaTyler
Re: White Screen
Post by BriaTyler »
Make sure the extension is installed correctly and not damaged. You can do this by uninstalling and reinstalling it again using the official extension package. Try disabling all other extensions and see if Recent Topics works without them. If so, the problem may be due to a conflict with another extension. Check the server and phpBB error log files to see if there may be any errors or exception messages related to the Recent Topics extension. This information may help you and the support staff to determine the possible cause of the problem.
BriaTyler
Re: White Screen
Post by BriaTyler »
Thank you for publishing the text
