Hello,
We are currently making some tests with Board3 Portal (fix for 3.3.9) and I'm wondering if it could be possible to add some code to make every module collapsible so each member could customize his own portal appearance?
For example, some of our members would like to have the clock displayed, some others not... but we have to choose. I was thus wondering if a collapsible button such as the one in Collapsible Forum Categories could work.
Thank you in advance for your answers!
[Solved] Would it be possible to make modules collapsible?
Mornagest
- phpBB.de User: Mornagest
- phpBB.com User: Mornagest
- phpBB.de User: Kirk
Re: Would it be possible to make modules collapsible?
It could work with this: https://www.phpbb.de/community/viewtopic.php?t=242482
Mornagest
Hello Kirk,
Thank you for your answer!
Yes, that works. I just have to disable Collapsible Forum Categories because it causes a conflict between the two extensions, but since Hide Forum Categories does the trick for both (categories AND Board3 modules), I'll keep that one.
Thank you again!
Thank you again!
