Style selection module in conflict with UCP
Mornagest
phpBB.de User: Mornagest
phpBB.com User: Mornagest
Post by Mornagest »
Hello,
I just discovered a conflict with Board3 2.1.0 (downloaded from here) and phpBB 3.3.9: the Style Selector module takes the priority from the UCP, where it becomes impossible to switch style (no effect when you select another style and validate).
As I didn't found any information about that, I assume this is not a feature but a bug?
Anyway, thank you for that great extension! 8-)
Re: Style selection module in conflict with UCP
After using the style changer in the portal, the style ID is appended to the URL.
As an alternative use this Extension.
Mornagest
Post by Mornagest »
Hello Kirk,
Thank you for your swift answer! Your extension seems accurate :)
Cheers!
