does not contain valid YAML: The reserved indicator "@"
John
Post by John »
HI, installing this extension : 3.3.9 and PHP7.4
Error:
phpBB encountered an error building the container due to an installed extension. For this reason, all extensions have been temporarily disabled. Please try purging your forum cache. All extensions will automatically be re-enabled once the container error is resolved. If this error continues, please visit phpBB.com for support.
Exception: The file "/home/jsofzone/public_html/ext/board3/portal/config/services.yml" does not contain valid YAML: The reserved indicator "@" cannot start a plain scalar; you need to quote the scalar at line 12 (near "- @board3.portal.columns").
#0 /home/jsofzone/public_html/vendor/symfony/dependency-injection/Loader/YamlFileLoader.php(117): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->loadFile('/home/jsofzone/...')
#1 /home/jsofzone/public_html/phpbb/extension/di/extension_base.php(99): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->load('services.yml')
#2 /home/jsofzone/public_html/phpbb/extension/di/extension_base.php(63): phpbb\extension\di\extension_base->load_services(Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#3 /home/jsofzone/public_html/vendor/symfony/dependency-injection/Compiler/MergeExtensionConfigurationPass.php(71): phpbb\extension\di\extension_base->load(Array, Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#4 /home/jsofzone/public_html/vendor/symfony/http-kernel/DependencyInjection/MergeExtensionConfigurationPass.php(39): Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#5 /home/jsofzone/public_html/vendor/symfony/dependency-injection/Compiler/Compiler.php(140): Symfony\Component\HttpKernel\DependencyInjection\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#6 /home/jsofzone/public_html/vendor/symfony/dependency-injection/ContainerBuilder.php(789): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#7 /home/jsofzone/public_html/phpbb/di/container_builder.php(223): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#8 /home/jsofzone/public_html/common.php(117): phpbb\di\container_builder->get_container()
#9 /home/jsofzone/public_html/adm/index.php(23): require('/home/jsofzone/...')
After deleting cache with all extensions automatically disabled by phpbb i get this:
Fatal error: Uncaught Symfony\Component\Config\Exception\FileLoaderLoadException: Cannot load resource "phpbb_pages_new_controller". Make sure there is a loader supporting the "phpbb_pages_route" type. in /home/jsofzone/public_html/vendor/symfony/config/Loader/Loader.php:73 Stack trace: #0 /home/jsofzone/public_html/vendor/symfony/config/Loader/FileLoader.php(133): Symfony\Component\Config\Loader\Loader->resolve('phpbb_pages_new...', 'phpbb_pages_rou...') #1 /home/jsofzone/public_html/vendor/symfony/config/Loader/FileLoader.php(90): Symfony\Component\Config\Loader\FileLoader->doImport('phpbb_pages_new...', 'phpbb_pages_rou...', false, 'ext/phpbb/pages...') #2 /home/jsofzone/public_html/vendor/symfony/routing/Loader/YamlFileLoader.php(161): Symfony\Component\Config\Loader\FileLoader->import('phpbb_pages_new...', 'phpbb_pages_rou...', false, 'ext/phpbb/pages...') #3 /home/jsofzone/public_html/vendor/symfony/routing/Loader/YamlFileLoader.php(91): Symfony\Component\Routing\Loader\YamlFileLoader->parseImport(Object(Symfony\Com in /home/jsofzone/public_html/vendor/symfony/config/Loader/Loader.php on line 73
Thanks in advance :)
Re: does not contain valid YAML: The reserved indicator "@"
There is an adapted version, link in my signature.
John
Post by John »
Thanks, that version installs fine but I know get this message on /portal
Fatal error: Uncaught Twig\Error\LoaderError: Looks like you try to load a template outside configured directories (../theme/portal.css) in "@board3_portal/event/overall_header_head_append.html" at line 2. in /home/jsofzone/public_html/vendor/twig/twig/src/Loader/FilesystemLoader.php:291 Stack trace: #0 /home/jsofzone/public_html/vendor/twig/twig/src/Loader/FilesystemLoader.php(211): Twig\Loader\FilesystemLoader->validateName('../theme/portal...') #1 /home/jsofzone/public_html/phpbb/template/twig/loader.php(135): Twig\Loader\FilesystemLoader->findTemplate('../theme/portal...', true) #2 /home/jsofzone/public_html/vendor/twig/twig/src/Loader/FilesystemLoader.php(150): phpbb\template\twig\loader->findTemplate('../theme/portal...') #3 /home/jsofzone/public_html/phpbb/template/twig/environment.php(313): Twig\Loader\FilesystemLoader->getCacheKey('../theme/portal...') #4 /home/jsofzone/public_html/cache/production/twig/38/38d337347de24a147d7442be2c4d5421ca48a5a30a027c5bf7be199353dc3fdc.php(44): phpbb\template\twig\environment->f in /home/jsofzone/public_html/vendor/twig/twig/src/Loader/FilesystemLoader.php on line 29
This is after clearing cache and using default prosilver...
EDIT: The fix fixed it viewtopic.php?f=72&t=11789
All good, thanks very much :)
