I did a search but didn't see what I need.
I am wondering if it is possible to have no text at the top of a module? If I leave no text my module appears in my list blank with no name. If I did this to all it would be quite confusing. Also on custom blocs it automatically adds CUSTOM BLOCK in the space I want blank. Is there a way to still enter my module names in my acp but have them all be blank when they display on my website?
What would be great is on module creation have an extra line for text to be displayed at the top of module which can be left blank if you do not want text there.
And the current line for Module Name only be for the module name and not be displayed as text on the module itself.
I also notice module name text is forced to be displayed as capital letters regardless if you use caps or not.
remove text on modules
- phpBB.de User: Viragohelp
- phpBB.com User: Viragohelp
- phpBB.de User: Kirk
Re: remove text on modules
Which module (Name, Postion of Module) would you like to have no text displayed?
Open:
Find:
In line find:
Replace with:
In the end "ACP -> General" --> purge cache It's recommended to purge your browser cache too.
This is because of prosilver.Viragohelp wrote: ↑10. April 2021 10:32 I also notice module name text is forced to be displayed as capital letters regardless if you use caps or not.
Open:
root/styles/prosilver/theme/content.css
Find:
li.header dt, li.header dd {
line-height: 1em;
border-left-width: 0;
margin: 2px 0 4px 0;
padding-top: 2px;
padding-bottom: 2px;
font-size: 1em;
font-family: Arial, Helvetica, sans-serif;
text-transform: uppercase;
text-transform: inherit;
Thank you. That will get rid of caps. As for which module... All of them to be honest.
Go to the directory
Open all files
Find and delete this:
root/ext/board3/portal/styles/prosilver/template/portal/modules/
Open all files
{$TITLE}
I tried this. Purged board cache. Then deleted my cookies using link at bottom of board. I also went into my browser settings and deleted all cookies and cache. It still displays as capitals. Any ideas?Kirk wrote: ↑10. April 2021 16:20 Which module (Name, Postion of Module) would you like to have no text displayed?This is because of prosilver.Viragohelp wrote: ↑10. April 2021 10:32 I also notice module name text is forced to be displayed as capital letters regardless if you use caps or not.
Open:root/styles/prosilver/theme/content.css
Find:In line find:Code: Select all
li.header dt, li.header dd { line-height: 1em; border-left-width: 0; margin: 2px 0 4px 0; padding-top: 2px; padding-bottom: 2px; font-size: 1em; font-family: Arial, Helvetica, sans-serif; text-transform: uppercase; }
Replace with:Code: Select all
In the end "ACP -> General" --> purge cache It's recommended to purge your browser cache too.Code: Select all
as you can see it is already done as I stated in my other post
It is now displayed correctly
wth.. ive cleared cokies. why isnt it showing properly for me... isnt hard clear ookies
i haad to close browser.. so odd. tyvm for helping!! Looks so much better ty ty ty
now how can I have modules named with no text showing at the top?
https://www.board3.de/viewtopic.php?p=38764#p38764Viragohelp wrote: ↑11. April 2021 16:50 now how can I have modules named with no text showing at the top?
