display forum on portal
Viragohelp
phpBB.de User: Viragohelp
phpBB.com User: Viragohelp
Post by Viragohelp »
First off thank you for this great extension. I am trying to figure out how to get the forumlist module to display on the center instead of the bottom on the portal page. Is this possible? It cant be selected for the center row but can I add it using custom block?
here is an image to show what i mean
Re: display forum on portal
Click on "Add module" and select the forum list.
Viragohelp
omg. all this time I just realized if you delete the forumlist from the bottom section it will then let you add it to the center one.... but if it is already used even if not actiated but listed in bottom it wont let you add it to center section....
