Hello.
I just installed the portal on my PhpBB forum.
The extension .yml helped me to adapte the .yml files in ../config and there is no more problem.
The issue i have is when i go on the Extension part of the ACP and go to the "Portal" Menu. When i click on "General parameters" or on "modules" i have a message that says :
"The page you are trying to see cannot be displayed because it uses an invalid or unsupported compression type"
And of course... i don't know what i could do.
Thanks for helping.
Bernard
Portal 2.1.0 with PhpBB 3.3.0 ACP
- phpBB.com User: Berni69
- phpBB.de User: Kirk
Re: Portal 2.1.0 with PhpBB 3.3.0 ACP
Take this customized version of me, link in my signature. Uninstall the portal first.
Hi, it works super well ! Thanks a lot for the job and conception !
If you need translation in french, i am ready to help you, let me know...
Best regards
Bernard
Best regards
Bernard
