Your Portal Version: 2.1.0
Boardlink: http://infinitegamingservers.com
I am unsure, as I don't know how long exactly this problem has existed.
I have checked my .htaccess to make sure nothing new was added, disabled and re-enabled board3, and I've tried reinstalling it.
When viewing the portal as a guest, it works fine. As soon as I log in it sends me directly to the board index and when try to go back to the portal it just loads the board index again. I asked for support from phpbb, but was told it was an issue with the extension itself so here I am. Thanks in advance.
Can't access portal while logged in
DarkJesture
Re: Can't access portal while logged in
Please ensure you have user rights and group rights.
DarkJesture
The portal does not show in the permissionsarchivar wrote:Please ensure you have user rights and group rights.
DarkJesture
http://prntscr.com/bbbapjarchivar wrote:Please ensure you have user rights and group rights.
I do not have the option of setting permissions for the portal. ATM anyone can see it as a guest but not logged in. It was working fine a day ago, now it's not.
Make these changes: https://github.com/board3/Board3-Portal/pull/650/filesDarkJesture wrote:I do not have the option of setting permissions for the portal. ATM anyone can see it as a guest but not logged in. It was working fine a day ago, now it's not.
DarkJesture
I was able to make all the changes except for the files in tests. I don't have those files at all, should I create them?Kirk wrote:Make these changes: https://github.com/board3/Board3-Portal/pull/650/filesDarkJesture wrote:I do not have the option of setting permissions for the portal. ATM anyone can see it as a guest but not logged in. It was working fine a day ago, now it's not.
EDIT: Nevermind, the portal works now. Thanks.
