Support for PbWoW3 Style
Max_69
phpBB.com User: Max_69
Post by Max_69 »
Your Portal Version: 2.1.0
Boardlink: http://www.gameinvaders.it
nothing
yes but any result
Hi, I installed the world but in my theme I see it as from image
How resolve?
Thanks
Kind Regards
Re: Support for PbWoW3 Style
copy: root/ext/board3/portal/styles/prosilver/template/portal/*.*
to: root/ext/board3/portal/styles/pbwow3/template/portal/*.*
copy: root/ext/board3/portal/styles/prosilver/theme/portal.css
to: root/ext/board3/portal/styles/pbwow3/theme/portal.css
copy: root/ext/board3/portal/styles/prosilver/theme/portal_responsive.css
to: root/ext/board3/portal/styles/pbwow3/theme/portal_responsive.css
open: root/ext/board3/portal/styles/pbwow3/template/portal/_block_config.html
Replace the complete code with this:
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg-portal" role="row"><div class="inner"><ul class="topiclist topiclist-portal"><li class="header"><dl><dt style="padding: 0px 0px 4px; white-space: nowrap; margin-bottom: 0px; margin-top: 0px;">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</dt><dd></dd></dl></li></ul><ul class="topiclist topiclist-portal forums"><li><dl><dt></dt><dd class="portal-side-wrapper"><div class="portal-side">' -->
<!-- DEFINE $LR_BLOCK_F_R = '</div></div><br class="portal-clear" />' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="forabg-portal" role="row"><div class="inner"><ul class="topiclist topiclist-portal"><li class="header"><dl class="icon"><dt>' -->
<!-- DEFINE $C_BLOCK_H_R = '</dt><dd></dd></dl></li></ul>' -->
<!-- DEFINE $C_BLOCK_F_L = ' ' -->
<!-- DEFINE $C_BLOCK_F_R = '</div></div><br class="portal-clear" />' -->
<!-- DEFINE $CC_BLOCK_H_L = '<div class="forabg-portal" role="row"><div class="inner"><ul class="topiclist topiclist-portal"><li class="header"><dl class="icon">' -->
open: root/ext/board3/portal/styles/pbwow3/theme/portal.css
@media all\0 {
	.portal-clock-back-hours-down, .portal-clock-front-hours-down {
		margin-left: -1px;
Add after:
.forabg-portal {
	background: #111;
	background: rgba(20, 20, 20, 0.75);
	border: 1px solid #444;
	border-radius: 0;
	box-shadow: 0 0 4px 2px rgba(0, 0, 0, 0.6);
	padding: 5px;
.topiclist-portal {
	background: #282828;
open: root/ext/board3/portal/styles/pbwow3/theme/portal_responsive.css
@media only screen and (max-width: 700px), only screen and (max-device-width: 700px)
Add after:
	.topiclist-portal { padding-top: 4px; }
additional changes:
In the end "ACP -> General" --> purge cache
Max_69
Post by Max_69 »
Fantastic!!! Thanks so much!! ;)
Max_69
Post by Max_69 »
Hi, I'm asking here to find out if I can get some help. In this style, is there the possibility of eliminating the subforum dropdown and having them normally visible? Thank you
This has nothing to do with the portal, please ask the style author.
Max_69
Post by Max_69 »
Ok sorry
Return to “Styles Support”
