Stylechanger module
SinglWolf
Stylechanger module
Post by SinglWolf »
Your Portal Version: 2.1.0
When this module is turned on
When this module is turned off
When activated this module, the selected style is not saved in the user profile, please, help solve the breakdown.
Re: Stylechanger module
This Style Changer only StyleID appears.
You have to adjust your desired Style in User Control Panel/Board preferences
SinglWolf
Post by SinglWolf »
I tune the desired style in the user control panel, but it he not saved. I not clearly explain? :D
Show the picture how to do it.
SinglWolf
Post by SinglWolf »
1. choose style
2. save
Does not save when the module activated
It is clear now?
The user control panel has nothing to do with the portal.
Turn to phpbb.com
SinglWolf
Post by SinglWolf »
Kirk wrote:The user control panel has nothing to do with the portal.
Turn to phpbb.com
Delightfully! Why, then, if you disable this module, the selected style is saved?
You do not want admit his mistake, your case.
Is unpleasant to me prove to you the obvious. Excuse for troubling.
Have a good day!
