[RELEASE]mChat V2.1.0 Board3 extension
Neverlands
Re: [RELEASE]mChat V2.1.0 Board3 extension
Post by Neverlands »
Hello,
the download link http://pretereo-stormrage.co.uk/viewtop ... p=145#p145 does not work anymore.
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
Neverlands
Hello talonos,
I am asking because phpBB cannot recognize if there is any update for the mChat Borad3 extension available:
Best regards,
Neverlands
Solidjeuh
phpBB.com User: Froddelaar
Post by Solidjeuh »
2.1.0 is the latest version, so you're good.
tak
Post by tak »
Hi talonos !
I don't understand why, when I activate this extension, every single page from my forum gives me a php error :
Fatal error: Uncaught TypeError: Argument 2 passed to dmzx\mchat\core\functions::__construct() must be an instance of dmzx\mchat\core\notifications, instance of phpbb\user given in /var/www/website/ext/dmzx/mchat/core/functions.php:77 Stack trace: #0 [internal function]: dmzx\mchat\core\functions->__construct(Object(dmzx\mchat\core\settings), Object(phpbb\user), Object(phpbb\auth\auth), Object(phpbb\log\log), Object(phpbb\db\driver\factory), Object(phpbb\cache\driver\file), Object(phpbb\event\dispatcher), './../', 'php', 'phpbb3014_mchat', 'phpbb3014_mchat...', 'phpbb3014_mchat...') #1 /var/www/website/vendor/symfony/dependency-injection/ContainerBuilder.php(925): ReflectionClass->newInstanceArgs(Array) #2 /var/www/website/vendor/symfony/dependency-injection/ContainerBuilder.php(467): Symfony\Component\DependencyInjection\ContainerBuilder->createService(Object(Symfony\Component\DependencyInjection\Definition), Object(SplObjectStorage), 'dmzx.mchat.func...') #3 /var/www/website/vendor/symfony/dependency-injecti in /var/www/website/ext/dmzx/mchat/core/functions.php on line 77
with php7.3. php 5.6 gives me the same error.
The construct method needs notification instance as second argument, while it receives a user instance.
I guess the board extension overload the notif variable with a user instance ?
Solidjeuh
Post by Solidjeuh »
Don't use PHP 7.3, it's not supported by phpBB. Downgrade to 7.2
7.3 gives PHP errors and fills up your server logs.
dtc
Post by dtc »
Does it run with phpbb 3.3.x ?
Mike-on-Tour
phpBB.de User: Mike-on-Tour
phpBB.com User: Mike-on-Tour
Post by Mike-on-Tour »
EDIT
Forget everything I said, wrong topic
Neverlands
Solidjeuh wrote: 20. June 2019 18:25 2.1.0 is the latest version, so you're good.
Is 2.1.0 still the latest version?
johnvsd
Post by johnvsd »
My portal did not show mChat block when add new block module.
Please help. Thanks
What block module did you add?
johnvsd
Post by johnvsd »
i just add new block, and it appeared a drop down list, but no mchat block appear
please view the attachment. Thanks
Is this extension also activated? The mchat block can only be activated in top, center, buttom
johnvsd
Post by johnvsd »
It is activated and running. But the issue is i can't add it to portal. I checked the portal (root file) and found out that there is no file relate to the mchat inside the portal (ex. mchat.php). I did download another older version which would have those related file to the portal and upload into the root, however it still does not show up in the drop down menu on portal when adding the new block
Did you do it like it says here: viewtopic.php?f=75&t=11166
Return to “v2.1.x”
