[RELEASE]mChat V2.1.0 Board3 extension
Re: [RELEASE]mChat V2.1.0 Board3 extension
Have all files been uploaded correctly?
Neves
phpBB.com User: Neves Projects
Post by Neves »
Yes
I uploaded b3pmchat To
To Ext >Talonos > b3pmchat
I just tested it again on a test site and still the same.
mchat works fine, but when I enable b3pmchat I get the errors.
I'm using mchat-2.1.2 , mChat.2.1.0.board3.extension with your dark_vision_2.2.5 theme
The correct path should look like this ./ext/talonos/b3pmchat, pay attention to the upper and lower case.
Neves
Post by Neves »
Sorry I typed it wrong in the post it is in ./ext/talonos/b3pmchat
Here is the error I get
Parse error: syntax error, unexpected 'public' (T_PUBLIC) in /home/nevespro/public_html/phpbbtestsite/ext/talonos/b3pmchat/b3pmchat.php on line 28
I was able to install version 2.1.0 without any problems. Did you install the current mchat extension?
Neves
Post by Neves »
Yes,
This is what I installed
phpbb-ext-mchat-2.1.2
and then
Are there any edits that need to be done ?
because I just uploaded and enabled them
In /ext/talonos/b3pmchat/b3pmchat.php on line 28 I have only one blank line.
Neves
Post by Neves »
I have this on line 28
I have this on line 129 with Notepad++
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
Neves wrote: 16. February 2019 23:09 I have this on line 28
mines on line 29 aswell.
something has changed the file in some way when you have uploaded it.
you could try installing via the extension "upload externsions" and see if that works correctly for you.
Neves
Post by Neves »
talonos wrote: 17. February 2019 14:44
Ok I checked and on my computer there is nothing on line 28 but when I upload it through ftp and bring it back the file has changed.
that's weird I don't know why.
talonos I don't see anything under extensions where I can upload files
Neves
Post by Neves »
So now it works :mrgreen:
My ftp transfer setting was set to Auto
I tried switching it to Binary and that was it.
such a little thing can drive someone crazy.
I'm sorry for wasting your time BUT without this post and you guy's helping me I would probably never have figured it out
Thanks guy's
talonos
Portal Specialist
Post by talonos »
Neves wrote: 18. February 2019 00:53
its an extension you can install that lets you manage and also upload/install extensions directly from the ACP
https://www.phpbb.com/customise/db/extension/upload
make sure to read the NOTE to make sure you get correct version.
Neves
Post by Neves »
I have it working great now thank you.
But just one more thing :D
Now that I have it on the portal is there a way to take it off the forum ?
I tried setting it to show on bottom but it still shows on top of forum
Neves
Post by Neves »
I got rid of it :D
I had to Overwrite settings for all users
Return to “v2.1.x”
