Who is online?
HoodieWeather
Who is online?
Post by HoodieWeather »
Your Portal Version: 2.1.0
PHP Version: PHP Version 5.6.10
When I'm logged in, the who is doesn't seem to work some reason. shows nobody is online.. anything i can do?
Re: Who is online?
This has to do with the cache time of Portal: viewtopic.php?p=36347#p36347
HoodieWeather
Re: Who is online?
Kirk wrote:This has to do with the cache time of Portal: viewtopic.php?p=36347#p36347
Thanks Kirk, this should work, I logged in, and then from that same tab I went else where on the net, and then came back to my forum, looked and it wasn't showing I was logged in, said no registered users weird. Hopefully, this little code should do the trick.
