[DEV]mChat 0.3.4 with board3 portal capabilities
talonos
Portal Specialist
phpBB.com User: talonos
Re: [DEV]mChat 0.3.4 with board3 portal capabilities
Post by talonos »
i've created an account on your site and can see mchat on index. if that version is 0.3.4 then it looks like you'd have to disable and remove mchat data from
acp/customise/manage extensions/ disable mchat && delete data
acp/customise/manage extensions/ enable mchat
that should then instal the "display_on_portal" config to database and it should display right away then (after enabling block in board3 portal settings)
doing that will also reset permissions for all users. and admin display will work for you then.
talonos
Portal Specialist
Post by talonos »
also due to your theme missing event to show mchat @ bottom of index ensure to set
"Location on Forum:" top of forum in mchat settings or mchat won't display on your index.
GameMASTER
Post by GameMASTER »
damn, you missed my edits :/
http://www.schattenraid.de - fresh, clean install. only phpbb3.17-pl1, german_lang, board3 2.10 and your mchat 0.34. same problem: mchat on forumindex, but empty @ portal
i dont know what's wrong with my boards :(
if you want, i can give you access to the files, so you can look by yourself...
GameMASTER
double post
talonos
Portal Specialist
Post by talonos »
GameMASTER wrote:damn, you missed my edits :/
just created an account. can you do acp access for me and i'll look into it from there.
GameMASTER
done, have fun and thx ;)
talonos
Portal Specialist
Post by talonos »
on mana site you have portal link going to app.php/portal that will break images/js/css for board3 exts. just look @ the recruitment module.
GameMASTER
i tried to "Enable URL Rewriting" for testing the mchat-problem. if i dont enable this, the images appear
GameMASTER
your change broke the forum, i reinstalled your original-version - site is online again!
talonos
Portal Specialist
Post by talonos »
@GameMASTER's issue was resolved and is now fully operational. have fun.
GameMASTER
thanks again!
sina54
phpBB.de User: sina54
phpBB.com User: sina54
Post by sina54 »
der chat geht ..und auch nicht..bin noch am schaun ..
http://www.duwirstvermisst.de
wenn man auf www.duwirstvermisst.de klickt ist der chat zu sehen und man kann schreiben..
aber wenn ich wechsele von Forum zur Portalseite geht es nicht!
http://www.duwirstvermisst.de/app.php/portal
talonos
Portal Specialist
Post by talonos »
sina54 wrote:der chat geht ..und auch nicht..bin noch am schaun ..
wenn man auf http://www.duwirstvermisst.de klickt ist der chat zu sehen und man kann schreiben..
see this post.
http://board3.de/viewtopic.php?f=71&t=1 ... tal#p36321
once that is done you can add the mchat module in acp/extension/portal/portal module/add module >> mini-chat (top/center/bottom) instead of using a vframe for module like you have.
sina54
Post by sina54 »
hab es probiert wie im Link beschrieben..klappt nicht, dann komme ich nicht mehr in das Portal
siehe ganz unten auf der startseite dort ist der chat ja , aber man kann ihn nicht bedienen nur mit der normalen Internetadresse! http://www.duwirstvermisst.de
Ich habe auch gewechselt im ACP zu http://www.duwirstvermisst.de/portal ..das selbe Problem!
iframe Chat will ich ja dann löschen !
lg sina
_____________________________________________________________________________________
Es klappt soweit, allerdings wenn ich aufs Portal klicke kommt diese Meldung
No route found for "GET /%7Bhttp://duwirstvermisst.de%7D"
alles ok bei "Startseite" und Forums-Übersicht auch der Chat wird auf beiden Seiten angezeigt!
ich hab das Portal einfach ausgeschaltet und nun können die User auf Startseite klicken!
Wenn jemand Zeit hat wäre es toll wenn mir jemand sagen könnte wie ich die Startseite in Portal umbennen kann. Ich finde es nicht!
Ansonsten geht alles. Vielen Dank fü den Chat im Portal..klasse!
lg Sina
Wäre toll wenn wir das Portal auch anklicken könnten und es wieder das Portal anzeigt. (Was ja die Route leider nicht angezeigt hat)
lg Sina
archivar wrote:There appears no link to the chat as a separate page in the index.
Genuine mChat the link to your page exists.
Return to “v2.1.x”
