[RELEASE] Warcraft Guild Recruitment block V2.2.0
talonos
Portal Specialist
Portal Specialist
phpBB.com User: talonos
Post by talonos »
THIS MODULE WORKS WITH BOARD3 PORTAL V2.1+
UPDATED: 19 Feb 2017
Addon: Warcraft Guild Recruitment Module
Addon Version: 2.2.0
Addon Author: Talonos
Addon Description:
This is a guild recruitment display module. Specs are displayed on the portal via images and transanercy for images is set in the ACP. also you can set a numeric value (0-5) AND/OR a Priority level (none-low-medium-high), these 2 values will display in a nice mouseover tooltip that is customisable from a theme dropdown menu. you can set the block to only display classes that you are recruiting for OR display all classes. Class images can be enabled/disabled. Class name colors can be enabled/disabled. Clicking on a spec image will direct you to the forum/link of your choosing for said clicker to make an application to the guild be it from an application form or a forum which is custonisable from the ACP aswell
Addon Requirements: Board3 Portal 2.1 and newer.
Download Link is here:
http://pretereo-stormrage.co.uk/viewtopic.php?f=19&t=44
Instructions:
1. Unzip the downloaded release and copy it to the ext directory of your phpBB board. Navigate in the ACP to Customise -> Manage extensions . Look for Board3 Warcraft Guild Recruitment under the Disabled Extensions list, and click its Enable link
2. navigate to Extensions -> Portal -> Portal Modules and click "Add Module" for the Left OR Right Column and add Warcraft Guild Recruitment.
3. now configure your installed "Warcraft Guild Recruitment" module to your liking by clicking on the Image.
REVISION INFOMATION
V2.2.0
rebuilt for phpbb 3.2
no more tables. uses <ul> and <li> tags now
add css classes to UL so can be customised to your liking easier
all images are now a sprite image so only 2 images loaded in total instead of 20+ (page loads faster)
v2.1.3
Bugfix Demon hunter
Bugfix Druid
v2.1.2
Added Demon hunter Class with 2 specs. Vengeance and Havoc
removed Combat Rogue class and added Outlaw Rogue class + icon
v2.1.1
updated code to load images properly when portal/inex is not on domain root.
v2.1.0
updated code to enable block loading images right when on app.php/portal
V2.0.1
improved image linking to account for different .htaccess settings.
V2.0.0
Updated to now use the new Extensions system for PHPBB 3.1+ and Board3 2.1+
1.0.1
Improved Tooltip Stability
1.0.0
Initial Release
SCREENSHOTS:
talonos
Portal Specialist
Portal Specialist
Re: [RELEASE] Warcraft Guild Recruitment block V2.0.1
Post by talonos »
V2.0.1
talonos
Portal Specialist
Portal Specialist
Re: [RELEASE] Warcraft Guild Recruitment block V2.1.0
Post by talonos »
v2.1.0
talonos
Portal Specialist
Portal Specialist
Re: [RELEASE] Warcraft Guild Recruitment block V2.1.1
Post by talonos »
v2.1.1
talonos
Portal Specialist
Portal Specialist
Re: [RELEASE] Warcraft Guild Recruitment block V2.1.2
Post by talonos »
v2.1.2
talonos
Portal Specialist
Portal Specialist
Re: [RELEASE] Warcraft Guild Recruitment block V2.1.3
Post by talonos »
v2.1.3
Bugfix Demon hunter
Bugfix Druid
talonos
Portal Specialist
Portal Specialist
Re: [RELEASE] Warcraft Guild Recruitment block V2.2.0
Post by talonos »
V2.2.0
Dirdet
Post by Dirdet »
Any alternate download link pls?
talonos
Portal Specialist
Portal Specialist
Post by talonos »
ohh yea forgot my domain was offline.
here you go heres a link https://files.fm/u/c9pq23r5
Return to “v2.1.x”
