Your Portal Version: 2.1.0
Hello,
Since I installed the portal, all the statistics shows right except the number of users per day that stays always at 0. Any idea as to why?
Also, I removed this line in the statistic module (statistics.php):
$l_users_per_day_s = $this->get_average_language($this->config['num_users'], 'USERS_PER_DAY');
in order to not show the incorrect information in the meantime but it leaves an empty line between Messages per day & Subject per users.
How can I remove the information and the complete line of where Users per day is shown?
Thanks!
Count of users per day in Statistics always at 0
mahugin
- phpBB.de User: mahugin
- phpBB.com User: mahugin
- phpBB.de User: Kirk
Re: Count of users per day in Statistics always at 0
Users per day describes how many users are registered per day, and as it will be rounded, everything is under 0.5 as 0
mahugin
Hello Kirk,
Thank you for your reply.
When you say registered per day, you mean new register or people that logged in during the day?
If I would like to remove this line, where should I do it?
Thanks!
Thanks!
