mChat with Board3 portal 2.1.0
Condor
Post by Condor »
Your Portal Version: 2.1.0
Installed Board3 portal 2.1.0
Installed mChat extension 0.1.7
Read the forum here :viewtopic.php?f=54&t=4577&start=15 and over the internet
Hi folks.
I've installed the mChat 0.1.7 but its loads on top of forum and I wish it to load on top of the portal.
Here I saw this thread : viewtopic.php?f=54&t=4577&start=15, but it seems a little bit old, last post 2014 feb.
Trying to install it by copy in the /ext, and does not appear in the available extension list of the ACP.
Are mChat von RMcGirr83 + b3p_mchat_block_110 always active with this version ?
If yes, how to install it in order to be recognize into the ACP ? If not, ...what else ?
Thanks in advance.
Re: mChat with Board3 portal 2.1.0
You have to create a module for the Portal: [How To] Create a module for Board3 Portal 2.1.x
Condor
Post by Condor »
Thank you. kirk.
It seems a little bit hard at first right, now ?
No more simple solution to transfer it from the forum to the portal ?
HoodieWeather
Post by HoodieWeather »
If you created one let me know,, I'd like a chatroom within the boarders of the portal as well. to i have the two sidebars left and right and the chat in the middle, if you can send that module over that would be rad.. I plan on getting the mchat.. seems like the only good one to use.. since I can't use my shoutmix one ehh
