Your Portal Version: none
Nothing
Read installation instructions and forum
Hi folks.
Really a great job you've done. And thanks for sharing it.
Quickly, I'm a real beginner in all that stuff. However I have a good background within field of computers.
So I download "Board3_portal-210.zip" and read the installation instructions.
First of all, it says "In it's root-folder you will find both install.xml and modx.prosilver.en.xsl"
And I haven't these files within the zip.
So I think, as you say somewhere, this version is an extension, it's necessary to get the base in order to install it.
Is it the good way and if so, which package must be dowloaded prior to the one above ?
Sorry for a so basic question.
Thanks for any tip and relevant information.
Download and installation process
Condor
- phpBB.de User: Kirk
Condor
Re: Download and installation process
Thank you very much kirk. It's great !
Now board3_portal_210 is active in my the ACP.
