Your Portal Version: 2.1.0RC3
Boardlink: http://viragohelp.com/phpbb3/index.php
Its not a problem persay.. It just doesnt let me change the name so when I use custom block and make a custom block it says "Custom Block" on it on my webpage.
Tried looking here couldnt really figure out what to do
It doesnt let me change the name so when I use custom block and make a custom block it says "Custom Block" on it on my webpage. viragohelp.com/phpbb3/index.php Do I need to edit the code for the custom block itself?
Changing name when using custom block
tigg
- phpBB.de User: tigg
- phpBB.com User: tigg
- phpBB.de User: Kirk
Re: Changing name when using custom block
Click on this block to the green cogs,
at Module name you can change the name.
tigg
When I try that it doesnt change what it says at the top of the block on my site where it is added... am I missing something?
