Portal not displaying correctly on iPad
Current Version: 2.0.2
Released: 2013-10-27
kooljp
Post by kooljp »
Your Portal Version: 2.1.0-rc2
Boardlink: http://www.fishing-victoria.com/
PHP Version: 5.5
Hi team,
Portal is not displaying the center column only on iPads.
Width of the left and right columns are set at the default 180px.
Please see screenshot here:
http://www.fishing-victoria.com/images/portal.jpg
Any help with this is greatly appreciated.
Cheers
JP
Re: Portal not displaying correctly on iPad
This is a known issue and is currently being looked at here: http://board3.de/tracker.php?p=13&t=239
kooljp
Post by kooljp »
Thanks Marc,
I have been following the thread but it's hard to translate the German.
Which files to I need to edit as I am not familiar with the GitHub format:
https://github.com/board3/Board3-Portal/pull/642
Thank you
JP
I'd recommend you just download the latest build from here: https://download.m-a-styles.de/2.1.x/la ... tal_73.zip
kooljp
Post by kooljp »
Marc wrote:I'd recommend you just download the latest build from here: https://download.m-a-styles.de/2.1.x/la ... tal_73.zip
I disabled the Board3 Portal in the Extensions Manager and it says "No route found for "GET /""
What are the instructions to remove the installed version?
Thanks
If you want to update the portal with a newer version, just disable it in the ACP (do not delete the data), remove the existing files and upload the new ones, and enable the portal again in the ACP.
