Latest News -Post count and Last poster in responsive Mobile
Current Version: 2.0.2
Released: 2013-10-27
kooljp
Post by kooljp »
Boardlink: http://www.fishing-victoria.com/
PHP Version: 5.5
Hi guys,
With the "Latest News" portal module, in Responsive Mobile view, you cannot see the Replies post count of the thread and the last post.
Is it possible to view the replies post count of the thread and the last poster? Otherwise you can't see if there's been any posts since you last looked without clicking into the thread.
Thanks
Re: Latest News -Post count and Last poster in responsive Mo
Set in the settings for this module with Display the number of replies and views on no.
kooljp
Post by kooljp »
Kirk wrote:Set in the settings for this module with Display the number of replies and views on no.
Thanks Kirk, doing this removed the number of replies and views when viewed from a wider screen.
Is there a way to set it to "no" just for smaller screens which require the responsive layout?
Cheers
JP
kooljp
Post by kooljp »
Hi Kirk,
I want it to display the number of replies and views on both wider screens and smaller "responsive" screens.
And add "LAST POST" for smaller screens.
I think it's in the CSS file but I'm not sure what to change...
Your above suggestions removes the number of replies and views from the wider screen view.
Any ideas
Thanks
JP
That would be a lot of effort.
One would have the HTML and CSS files rewrite.
kooljp
Post by kooljp »
Kirk wrote:That would be a lot of effort.
How about just adding the "last post" information to be viewed in responsive mode?
Cheers
JP
kooljp
Post by kooljp »
On a side note, it works perfectly with this "Recent Topics" Extension on the index page:
https://www.phpbb.com/customise/db/exte ... _topics_2/
Is there a way to replicate the "Recent Topics" behavior?
Try it with this: (This works only for the Compact news block style)
Open: root/ext/board3/portal/styles/prosilver/template/portal/modules/news_compact_center.html
Find:
	<!-- IF news.S_DISPLAY_NEWS_RVS -->
		<dd class="posts responsive-portal-news">{L_REPLIES}</dd>
		<dd class="views responsive-portal-news">{L_VIEWS}</dd>
Replace with:
	<div class="replies-views">
Find:
<!-- IF not news.S_DISPLAY_NEWS_RVS --><!-- IF news.news_row.FORUM_NAME -->&bull; <!-- ENDIF -->{L_REPLIES}{L_COLON} <strong>{news.news_row.REPLIES}</strong>  &bull; {L_VIEWS}{L_COLON} <strong>{news.news_row.TOPIC_VIEWS}</strong><!-- ENDIF -->
Replace with:
<div class="responive-show responsive-replies-views" style="display: none;"><!-- IF news.news_row.FORUM_NAME -->&bull; <!-- ENDIF -->{L_REPLIES}{L_COLON} <strong>{news.news_row.REPLIES}</strong>  &bull; {L_VIEWS}{L_COLON} <strong>{news.news_row.TOPIC_VIEWS}</strong></div>
Open: root/ext/board3/portal/styles/prosilver/theme/portal_responsive.css
Find:
@media only screen and (max-width: 1040px), only screen and (max-device-width: 1040px)
Add after:
	.responsive-replies-views {
	    display: block !important;
	.replies-views {
	    display: none !important;
The function "display the number of replies and views" will have no effect.
additional changes:
In the end "ACP -> General" --> purge cache
kooljp
Post by kooljp »
Thanks Kirk!
works perfectly on my forum now: www.fishing-victoria.com
Cheers
JP
kooljp
Post by kooljp »
One last thing.
Is it possible to get the pagination in responsive view to show the last page?
Currently it shows 1,2,3,4,5 even if there are more pages.
Is it possible to display pagination like this 1,2,3,4,5...12 (with an ellipsis before the last page)?
Many thanks
JP
Insert at the end:
@media only screen and (max-width: 350px), only screen and (max-device-width: 350px) {
.row .pagination .ellipsis + li {
    display: block;
kooljp
Post by kooljp »
Kirk wrote:Open: root/ext/board3/portal/styles/prosilver/theme/portal_responsive.css
Insert at the end:
    display: block;
Thanks Kirk, but this didn't seem to work.
You can see the portal here on www.fishing-victoria.com
If you also go to non-portal http://www.fishing-victoria.com/index.php you can see it works with the "recent topics" Extension.
Cheers
JP
kooljp
Post by kooljp »
After a bit of experimenting I changed the code to:
Insert at the end:
    display: inline-block !important;
It seems to work for now...
So how would you change the display pagination like this: 1...9,10,11,12(last page number)
instead of 1,2,3,4,5...12?
Thanks again
JP
I had tested it only with firebug.
