Your Portal Version: 2.1.0-rc1
Boardlink: http://minorhockeytalk.ca
Nothing
Looked around and changed a few things on my test board but could not figure out a solution
Is there a way to style the look of a block? In particular I would like to use a custom block as a container for advertising but would like to eliminate the border that delineates the block so that the advertising within the block does not have any border around it. I can then still use these custom blocks to position the advertising modules on my board without any border or title on the top present for these custom blocks.
[UPDATE] I have managed to format just the Custom blocks with a couple of changes. The last thing to do is change the background color of the custom block. Does anyone understand how to do this? How are the colors of the background blocks controlled?
[UPDATE 2 - SOLVED] I completed these changes and managed to get the desired effect on my test board. It turns out some simple changes in custom_side.html and _block_config.html is all that is required.
Styling for Custom Blocks
ohockey
