Your Portal Version: 2.1.0
Boardlink: http://www.conquest-wow.com
updated to 3.1.3
Randomly uploaded/deleted and clicked things
Hello,
I've just updated to 3.1.3 which worked lovely and installed the portal, which appears to have worked although I have two issues.
1) there is no upload module option? I have a couple of wow related modules, I'd love to upload. I can't find a guide telling me how to do this. I tried guessing to put them in the upload folder but that didn't seem to work. Tried copying them into the same folders as other modules
2) I'm not sure the best way to set the portal to load as the initial page when visiting the site. Before there were instructions to edit certain files, but with the new version of phpbb and portal that appears to be different. So how do I do it?
Any help would be greatly appreciated.
Unable to upload modules
- phpBB.de User: gazmon
- phpBB.com User: gazmon
- Portal Specialist
- phpBB.com User: talonos
Re: Unable to upload modules
the WOW modules havn't been remade to work with 2.1 yet. they will only work on 2.0 currently.
Ahh I misread the page! Thanks for that
Any ideas how to get the portal to be the default page? Any posts I find tend to point to 2.0 rather than 2.1
- Portal Specialist
check out kirk's post HERE for how to make portal main page.
Cheers man you're a star!
