Problem with Recent Module?
Current Version: 2.0.2
Released: 2013-10-27
PavvelB
phpBB.com User: PavvelB
Post by PavvelB »
Your Portal Version: 2.0.2
Boardlink: http://foto-forum.info
Typica installation phpBB3.0.12 + phpBB Gallery 1.1.6 + Board3 2.0.2 + mChat 1.3.8
Many tests
Hi.
Sorry for my english, I hope you will understand my problem :)
Few days ago I started my page. Short after beginning the mChat module disappears from the main page.
I have made some tests and found reason. It is connected with News module. If any toppic in this window has an attachment in first post mChat window doesn't work. Attachments in second post or later doesn't make any problems, only the first.
MyLady
Sponsor
phpBB.de User: Scanialady
phpBB.com User: Scanialady
Re: Problem with Recent Module?
Post by MyLady »
In conjunction with mChat there are occasional problems if multiple versions of Javascript are used. Your style is using Javascript, mChat is using Javascript.
Make sure you don't load the same Javascript twice.
Sometimes the order in which the scripts are loaded in overall_header.html decides work or not work.
If the Javascript of your style is the newest, delete the line with version number from mChat entry.
Make sure the file edits are on the right place.
