Boardlink: http://www.ninowebs.it/bord/
hi, I updated everything, the portal to 2.0.2, the phpbb to 3-0-12, style aero alla1.5.2, but now I see the portal with the blocks not perfect, I kindly ask your help
Aero1.5.2 problem
grazia
talonos
- Portal Specialist
- phpBB.com User: talonos
Re: Aero1.5.2 problem
grazia
ok, Thank you for answer
Edit, i soved for portal, no for arcade
