update
Current Version: 2.0.2
Released: 2013-10-27
grazia
update
Post by grazia »
Your Portal Version: 2.0.1
Hello everyone
Hello everyone I wanted to know how do I update
where I find this update
Re: update
The Portal Version 2.1.0-b1 works only by phpBB version 3.1.x
grazia
Re: update
Post by grazia »
ok , I'm back, I want to update my phpbb SIA ed Even portal thanks
grazia
Re: update
Post by grazia »
ok , then reinstall all over again , I just downloaded version 3.0.12 phpbb , adessso Which version of board3 portal I PUT , I downloaded version , board3_portal_210_rc1 , but I saw it lacks the ' installation
Re: update
The Portal Version 2.1.0-b1 works only by phpBB version 3.1.x not with phpBB 3.0.12.
grazia
Re: update
Post by grazia »
Kirk wrote:The Portal Version 2.1.0-b1 works only by phpBB version 3.1.x not with phpBB 3.0.12.
ok , ok thanks sorry if I had not understood before
