Portal AJAX failing when behind reverse proxy
Fulgan
phpBB.com User: Fulgan
Post by Fulgan »
Your Portal Version: 2.1.0-b1
Your knowledge: Professional
Boardlink: http://fracture.fulgan.com
Installed Portal 2.1.0-b1 (no previous install)
Check options for existing preference
Hello,
When using Portal behind a reverse proxy system (WAF/SSL accelerator, in my case, behind Cloudflare), none of the module control are working. Every single one gives back an AJAX error
here is a sample error:
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
FILE: [ROOT]/ext/board3/portal/acp/portal_module.php
LINE: 1136
CALL: trigger_error()
LINE: 405
CALL: board3\portal\acp\portal_module->module_delete()
FILE: [ROOT]/includes/functions_module.php
LINE: 674
CALL: board3\portal\acp\portal_module->main()
FILE: [ROOT]/adm/index.php
LINE: 81
CALL: p_master->load_active()
Fulgan
Re: Portal AJAX failing when behind reverse proxy
Post by Fulgan »
If you need help reproducing it, contact me via PM, please
