Your Portal Version: 2.0.2
Boardlink: http://twgs.afterhours-bbs.com/
PHP Version: 5.3
MySQL Version: MySQL 5.1.68-community
I installed AutoMod
I did your Redirect to the portal after login / logout and that worked fine.
When I open a new browser window it still goes to index.php and not portal.php, what am I missing?
Thanks before hand.
Portal.php
computerhavok
- phpBB.com User: computerhavok
- phpBB.de User: Kirk
Re: Portal.php
Open: root/ucp.php
Find:
Relace with:
Open: root/ucp.php
Find:
case 'login':
redirect(append_sid("{$phpbb_root_path}index.$phpEx"));
login_box(request_var('redirect', "index.$phpEx"));
break;
case 'logout':
if ($user->data['user_id'] != ANONYMOUS && isset($_GET['sid']) && !is_array($_GET['sid']) && $_GET['sid'] === $user->session_id)
$user->session_kill();
$user->session_begin();
$message = $user->lang['LOGOUT_REDIRECT'];
$message = ($user->data['user_id'] == ANONYMOUS) ? $user->lang['LOGOUT_REDIRECT'] : $user->lang['LOGOUT_FAILED'];
meta_refresh(3, append_sid("{$phpbb_root_path}index.$phpEx"));Code: Select all
case 'login':
redirect(append_sid("{$phpbb_root_path}portal.$phpEx"));
login_box(request_var('redirect', "portal.$phpEx"));
break;
case 'logout':
meta_refresh(3, append_sid("{$phpbb_root_path}portal.$phpEx"));Gruß Udo
Re: Portal.php
Moved to the correct forum.
HoodieWeather
- Valued Contributor
Re: Portal.php
Are those codes so that if a user logs into the forum it spits them the portal instead of the forum if so thanks
cause i have a dummy account and I log in and it shoots me to the forum and not the portal itself and i'm trying to find a way to stop that. I want users to be sent to portal not the forum instead
talonos
- Portal Specialist
- phpBB.com User: talonos
Re: Portal.php
yes they are but they are for the old version so these edits won't work in current or future versions.
HoodieWeather
Re: Portal.php
talonos wrote:yes they are but they are for the old version so these edits won't work in current or future versions.
I'm running 2.0.2
