Probleme beim Instalieren des Boards
Ick
Post by Ick »
Deine Portal Version: 2.0.2
Portal instaliert nach Anleitung
Im Forum gesucht
Huhu an alle.
Habe mich dran versucht das Portal 2.0.2 zu Instalieren.
Meine PhpBB Version ist 3.0.12
Ich bekomme folgende Fehlermeldung
Parse error: syntax error, unexpected $end in /home/u939587138/public_html/includes/functions.php on line 4943
Ich komm einfach nicht mehr weiter. Könnte mit jemand von euch Helfen?
* @package phpBB3
* @version $Id$
* @ignore
if (!defined('IN_PHPBB'))
	exit;
// Common global functions
* set_var
* Set variable, used by {@link request_var the request_var function}
* @access private
function set_var(&$result, $var, $type, $multibyte = false)
	settype($var, $type);
	$result = $var;
	if ($type == 'string')
		$result = trim(htmlspecialchars(str_replace(array("\r\n", "\r", "\0"), array("\n", "\n", ''), $result), ENT_COMPAT, 'UTF-8'));
		if (!empty($result))
			// Make sure multibyte characters are wellformed
			if ($multibyte)
				if (!preg_match('/^./u', $result))
					$result = '';
				// no multibyte, allow only ASCII (0-127)
				$result = preg_replace('/[\x80-\xFF]/', '?', $result);
		$result = (STRIP) ? stripslashes($result) : $result;
* request_var
* Used to get passed variable
function request_var($var_name, $default, $multibyte = false, $cookie = false)
	if (!$cookie && isset($_COOKIE[$var_name]))
		if (!isset($_GET[$var_name]) && !isset($_POST[$var_name]))
			return (is_array($default)) ? array() : $default;
		$_REQUEST[$var_name] = isset($_POST[$var_name]) ? $_POST[$var_name] : $_GET[$var_name];
	$super_global = ($cookie) ? '_COOKIE' : '_REQUEST';
	if (!isset($GLOBALS[$super_global][$var_name]) || is_array($GLOBALS[$super_global][$var_name]) != is_array($default))
	$var = $GLOBALS[$super_global][$var_name];
	if (!is_array($default))
		$type = gettype($default);
		list($key_type, $type) = each($default);
		$type = gettype($type);
		$key_type = gettype($key_type);
		if ($type == 'array')
			reset($default);
			$default = current($default);
			list($sub_key_type, $sub_type) = each($default);
			$sub_type = gettype($sub_type);
			$sub_type = ($sub_type == 'array') ? 'NULL' : $sub_type;
			$sub_key_type = gettype($sub_key_type);
	if (is_array($var))
		$_var = $var;
		$var = array();
		foreach ($_var as $k => $v)
			set_var($k, $k, $key_type);
			if ($type == 'array' && is_array($v))
				foreach ($v as $_k => $_v)
					if (is_array($_v))
						$_v = null;
					set_var($_k, $_k, $sub_key_type, $multibyte);
					set_var($var[$k][$_k], $_v, $sub_type, $multibyte);
				if ($type == 'array' || is_array($v))
					$v = null;
				set_var($var[$k], $v, $type, $multibyte);
		set_var($var, $var, $type, $multibyte);
	return $var;
* Sets a configuration option's value.
* Please note that this function does not update the is_dynamic value for
* an already existing config option.
* @param string $config_name   The configuration option's name
* @param string $config_value  New configuration value
* @param bool   $is_dynamic    Whether this variable should be cached (false) or
*                              if it changes too frequently (true) to be
*                              efficiently cached.
* @return null
function set_config($config_name, $config_value, $is_dynamic = false)
	global $db, $cache, $config;
	$sql = 'UPDATE ' . CONFIG_TABLE . "
		SET config_value = '" . $db->sql_escape($config_value) . "'
		WHERE config_name = '" . $db->sql_escape($config_name) . "'";
	$db->sql_query($sql);
	if (!$db->sql_affectedrows() && !isset($config[$config_name]))
		$sql = 'INSERT INTO ' . CONFIG_TABLE . ' ' . $db->sql_build_array('INSERT', array(
			'config_name'	=> $config_name,
			'config_value'	=> $config_value,
			'is_dynamic'	=> ($is_dynamic) ? 1 : 0));
	$config[$config_name] = $config_value;
	if (!$is_dynamic)
		$cache->destroy('config');
* Increments an integer config value directly in the database.
* @param int    $increment     Amount to increment by
* @return null
function set_config_count($config_name, $increment, $is_dynamic = false)
	global $db, $cache;
	switch ($db->sql_layer)
		case 'firebird':
			// Precision must be from 1 to 18
			$sql_update = 'CAST(CAST(config_value as DECIMAL(18, 0)) + ' . (int) $increment . ' as VARCHAR(255))';
		break;
		case 'postgres':
			// Need to cast to text first for PostgreSQL 7.x
			$sql_update = 'CAST(CAST(config_value::text as DECIMAL(255, 0)) + ' . (int) $increment . ' as VARCHAR(255))';
		break;
		// MySQL, SQlite, mssql, mssql_odbc, oracle
		default:
			$sql_update = 'config_value + ' . (int) $increment;
		break;
	$db->sql_query('UPDATE ' . CONFIG_TABLE . ' SET config_value = ' . $sql_update . " WHERE config_name = '" . $db->sql_escape($config_name) . "'");
	if (!$is_dynamic)
* Generates an alphanumeric random string of given length
* @return string
function gen_rand_string($num_chars = 8)
	// [a, z] + [0, 9] = 36
	return substr(strtoupper(base_convert(unique_id(), 16, 36)), 0, $num_chars);
* Generates a user-friendly alphanumeric random string of given length
* We remove 0 and O so users cannot confuse those in passwords etc.
* @return string
function gen_rand_string_friendly($num_chars = 8)
	$rand_str = unique_id();
	// Remove Z and Y from the base_convert(), replace 0 with Z and O with Y
	// [a, z] + [0, 9] - {z, y} = [a, z] + [0, 9] - {0, o} = 34
	$rand_str = str_replace(array('0', 'O'), array('Z', 'Y'), strtoupper(base_convert($rand_str, 16, 34)));
	return substr($rand_str, 0, $num_chars);
* Return unique id
* @param string $extra additional entropy
function unique_id($extra = 'c')
	static $dss_seeded = false;
	global $config;
	$val = $config['rand_seed'] . microtime();
	$val = md5($val);
	$config['rand_seed'] = md5($config['rand_seed'] . $val . $extra);
	if ($dss_seeded !== true && ($config['rand_seed_last_update'] < time() - rand(1,10)))
		set_config('rand_seed_last_update', time(), true);
		set_config('rand_seed', $config['rand_seed'], true);
		$dss_seeded = true;
	return substr($val, 4, 16);
* Wrapper for mt_rand() which allows swapping $min and $max parameters.
* PHP does not allow us to swap the order of the arguments for mt_rand() anymore.
* (since PHP 5.3.4, see http://bugs.php.net/46587)
* @param int $min		Lowest value to be returned
* @param int $max		Highest value to be returned
* @return int			Random integer between $min and $max (or $max and $min)
function phpbb_mt_rand($min, $max)
	return ($min > $max) ? mt_rand($max, $min) : mt_rand($min, $max);
* Wrapper for getdate() which returns the equivalent array for UTC timestamps.
* @param int $time		Unix timestamp (optional)
* @return array			Returns an associative array of information related to the timestamp.
*						See http://www.php.net/manual/en/function.getdate.php
function phpbb_gmgetdate($time = false)
	if ($time === false)
		$time = time();
	// getdate() interprets timestamps in local time.
	// What follows uses the fact that getdate() and
	// date('Z') balance each other out.
	return getdate($time - date('Z'));
* Return formatted string for filesizes
* @param mixed	$value			filesize in bytes
*								(non-negative number; int, float or string)
* @param bool	$string_only	true if language string should be returned
* @param array	$allowed_units	only allow these units (data array indexes)
* @return mixed					data array if $string_only is false
* @author bantu
function get_formatted_filesize($value, $string_only = true, $allowed_units = false)
	global $user;
	$available_units = array(
		'tb' => array(
			'min' 		=> 1099511627776, // pow(2, 40)
			'index'		=> 4,
			'si_unit'	=> 'TB',
			'iec_unit'	=> 'TIB',
		'gb' => array(
			'min' 		=> 1073741824, // pow(2, 30)
			'index'		=> 3,
			'si_unit'	=> 'GB',
			'iec_unit'	=> 'GIB',
		'mb' => array(
			'min'		=> 1048576, // pow(2, 20)
			'index'		=> 2,
			'si_unit'	=> 'MB',
			'iec_unit'	=> 'MIB',
		'kb' => array(
			'min'		=> 1024, // pow(2, 10)
			'index'		=> 1,
			'si_unit'	=> 'KB',
			'iec_unit'	=> 'KIB',
		'b' => array(
			'min'		=> 0,
			'index'		=> 0,
			'si_unit'	=> 'BYTES', // Language index
			'iec_unit'	=> 'BYTES',  // Language index
	foreach ($available_units as $si_identifier => $unit_info)
		if (!empty($allowed_units) && $si_identifier != 'b' && !in_array($si_identifier, $allowed_units))
			continue;
		if ($value >= $unit_info['min'])
			$unit_info['si_identifier'] = $si_identifier;
			break;
	unset($available_units);
	for ($i = 0; $i < $unit_info['index']; $i++)
		$value /= 1024;
	$value = round($value, 2);
	// Lookup units in language dictionary
	$unit_info['si_unit'] = (isset($user->lang[$unit_info['si_unit']])) ? $user->lang[$unit_info['si_unit']] : $unit_info['si_unit'];
	$unit_info['iec_unit'] = (isset($user->lang[$unit_info['iec_unit']])) ? $user->lang[$unit_info['iec_unit']] : $unit_info['iec_unit'];
	// Default to IEC
	$unit_info['unit'] = $unit_info['iec_unit'];
	if (!$string_only)
		$unit_info['value'] = $value;
		return $unit_info;
	return $value  . ' ' . $unit_info['unit'];
* Determine whether we are approaching the maximum execution time. Should be called once
* at the beginning of the script in which it's used.
* @return	bool	Either true if the maximum execution time is nearly reached, or false
*					if some time is still left.
function still_on_time($extra_time = 15)
	static $max_execution_time, $start_time;
	$time = explode(' ', microtime());
	$current_time = $time[0] + $time[1];
	if (empty($max_execution_time))
		$max_execution_time = (function_exists('ini_get')) ? (int) @ini_get('max_execution_time') : (int) @get_cfg_var('max_execution_time');
		// If zero, then set to something higher to not let the user catch the ten seconds barrier.
		if ($max_execution_time === 0)
			$max_execution_time = 50 + $extra_time;
		$max_execution_time = min(max(10, ($max_execution_time - $extra_time)), 50);
		// For debugging purposes
		// $max_execution_time = 10;
		global $starttime;
		$start_time = (empty($starttime)) ? $current_time : $starttime;
	return (ceil($current_time - $start_time) < $max_execution_time) ? true : false;
* @version Version 0.1 / slightly modified for phpBB 3.0.x (using $H$ as hash type identifier)
* Portable PHP password hashing framework.
* Written by Solar Designer <solar at openwall.com> in 2004-2006 and placed in
* the public domain.
* There's absolutely no warranty.
* The homepage URL for this framework is:
*	http://www.openwall.com/phpass/
* Please be sure to update the Version line if you edit this file in any way.
* It is suggested that you leave the main version number intact, but indicate
* your project name (after the slash) and add your own revision information.
* Please do not change the "private" password hashing method implemented in
* here, thereby making your hashes incompatible.  However, if you must, please
* change the hash type identifier (the "$P$") to something different.
* Obviously, since this code is in the public domain, the above are not
* requirements (there can be none), but merely suggestions.
* Hash the password
function phpbb_hash($password)
	$itoa64 = './0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz';
	$random_state = unique_id();
	$random = '';
	$count = 6;
	if (($fh = @fopen('/dev/urandom', 'rb')))
		$random = fread($fh, $count);
		fclose($fh);
	if (strlen($random) < $count)
		$random = '';
		for ($i = 0; $i < $count; $i += 16)
			$random_state = md5(unique_id() . $random_state);
			$random .= pack('H*', md5($random_state));
		$random = substr($random, 0, $count);
	$hash = _hash_crypt_private($password, _hash_gensalt_private($random, $itoa64), $itoa64);
	if (strlen($hash) == 34)
		return $hash;
	return md5($password);
* Check for correct password
* @param string $password The password in plain text
* @param string $hash The stored password hash
* @return bool Returns true if the password is correct, false if not.
function phpbb_check_hash($password, $hash)
	if (strlen($password) > 4096)
		// If the password is too huge, we will simply reject it
		// and not let the server try to hash it.
		return false;
		return (_hash_crypt_private($password, $hash, $itoa64) === $hash) ? true : false;
	return (md5($password) === $hash) ? true : false;
* Generate salt for hash generation
function _hash_gensalt_private($input, &$itoa64, $iteration_count_log2 = 6)
	if ($iteration_count_log2 < 4 || $iteration_count_log2 > 31)
		$iteration_count_log2 = 8;
	$output = '$H$';
	$output .= $itoa64[min($iteration_count_log2 + ((PHP_VERSION >= 5) ? 5 : 3), 30)];
	$output .= _hash_encode64($input, 6, $itoa64);
	return $output;
* Encode hash
function _hash_encode64($input, $count, &$itoa64)
	$output = '';
	$i = 0;
	do
		$value = ord($input[$i++]);
		$output .= $itoa64[$value & 0x3f];
		if ($i < $count)
			$value |= ord($input[$i]) << 8;
		$output .= $itoa64[($value >> 6) & 0x3f];
		if ($i++ >= $count)
			break;
		if ($i < $count)
			$value |= ord($input[$i]) << 16;
		$output .= $itoa64[($value >> 12) & 0x3f];
		if ($i++ >= $count)
			break;
		$output .= $itoa64[($value >> 18) & 0x3f];
	while ($i < $count);
	return $output;
* The crypt function/replacement
function _hash_crypt_private($password, $setting, &$itoa64)
	$output = '*';
	// Check for correct hash
	if (substr($setting, 0, 3) != '$H$' && substr($setting, 0, 3) != '$P$')
		return $output;
	$count_log2 = strpos($itoa64, $setting[3]);
	if ($count_log2 < 7 || $count_log2 > 30)
		return $output;
	$count = 1 << $count_log2;
	$salt = substr($setting, 4, 8);
	if (strlen($salt) != 8)
		return $output;
	* We're kind of forced to use MD5 here since it's the only
	* cryptographic primitive available in all versions of PHP
	* currently in use.  To implement our own low-level crypto
	* in PHP would result in much worse performance and
	* consequently in lower iteration counts and hashes that are
	* quicker to crack (by non-PHP code).
	if (PHP_VERSION >= 5)
		$hash = md5($salt . $password, true);
		do
			$hash = md5($hash . $password, true);
		while (--$count);
		$hash = pack('H*', md5($salt . $password));
		do
			$hash = pack('H*', md5($hash . $password));
		while (--$count);
	$output = substr($setting, 0, 12);
	$output .= _hash_encode64($hash, 16, $itoa64);
	return $output;
* Hashes an email address to a big integer
* @param string $email		Email address
* @return string			Unsigned Big Integer
function phpbb_email_hash($email)
	return sprintf('%u', crc32(strtolower($email))) . strlen($email);
* Wrapper for version_compare() that allows using uppercase A and B
* for alpha and beta releases.
* See http://www.php.net/manual/en/function.version-compare.php
* @param string $version1		First version number
* @param string $version2		Second version number
* @param string $operator		Comparison operator (optional)
* @return mixed					Boolean (true, false) if comparison operator is specified.
*								Integer (-1, 0, 1) otherwise.
function phpbb_version_compare($version1, $version2, $operator = null)
	$version1 = strtolower($version1);
	$version2 = strtolower($version2);
	if (is_null($operator))
		return version_compare($version1, $version2);
		return version_compare($version1, $version2, $operator);
* Global function for chmodding directories and files for internal use
* This function determines owner and group whom the file belongs to and user and group of PHP and then set safest possible file permissions.
* The function determines owner and group from common.php file and sets the same to the provided file.
* The function uses bit fields to build the permissions.
* The function sets the appropiate execute bit on directories.
* Supported constants representing bit fields are:
* CHMOD_ALL - all permissions (7)
* CHMOD_READ - read permission (4)
* CHMOD_WRITE - write permission (2)
* CHMOD_EXECUTE - execute permission (1)
* NOTE: The function uses POSIX extension and fileowner()/filegroup() functions. If any of them is disabled, this function tries to build proper permissions, by calling is_readable() and is_writable() functions.
* @param string	$filename	The file/directory to be chmodded
* @param int	$perms		Permissions to set
* @return bool	true on success, otherwise false
* @author faw, phpBB Group
function phpbb_chmod($filename, $perms = CHMOD_READ)
	static $_chmod_info;
	// Return if the file no longer exists.
	if (!file_exists($filename))
		return false;
	// Determine some common vars
	if (empty($_chmod_info))
		if (!function_exists('fileowner') || !function_exists('filegroup'))
			// No need to further determine owner/group - it is unknown
			$_chmod_info['process'] = false;
			global $phpbb_root_path, $phpEx;
			// Determine owner/group of common.php file and the filename we want to change here
			$common_php_owner = @fileowner($phpbb_root_path . 'common.' . $phpEx);
			$common_php_group = @filegroup($phpbb_root_path . 'common.' . $phpEx);
			// And the owner and the groups PHP is running under.
			$php_uid = (function_exists('posix_getuid')) ? @posix_getuid() : false;
			$php_gids = (function_exists('posix_getgroups')) ? @posix_getgroups() : false;
			// If we are unable to get owner/group, then do not try to set them by guessing
			if (!$php_uid || empty($php_gids) || !$common_php_owner || !$common_php_group)
				$_chmod_info = array(
					'process'		=> true,
					'common_owner'	=> $common_php_owner,
					'common_group'	=> $common_php_group,
					'php_uid'		=> $php_uid,
					'php_gids'		=> $php_gids,
	if ($_chmod_info['process'])
		$file_uid = @fileowner($filename);
		$file_gid = @filegroup($filename);
		// Change owner
		if (@chown($filename, $_chmod_info['common_owner']))
			clearstatcache();
		// Change group
		if (@chgrp($filename, $_chmod_info['common_group']))
			clearstatcache();
		// If the file_uid/gid now match the one from common.php we can process further, else we are not able to change something
		if ($file_uid != $_chmod_info['common_owner'] || $file_gid != $_chmod_info['common_group'])
	// Still able to process?
		if ($file_uid == $_chmod_info['php_uid'])
			$php = 'owner';
		else if (in_array($file_gid, $_chmod_info['php_gids']))
			$php = 'group';
			// Since we are setting the everyone bit anyway, no need to do expensive operations
	// We are not able to determine or change something
	if (!$_chmod_info['process'])
		$php = 'other';
	// Owner always has read/write permission
	$owner = CHMOD_READ | CHMOD_WRITE;
	if (is_dir($filename))
		$owner |= CHMOD_EXECUTE;
		// Only add execute bit to the permission if the dir needs to be readable
		if ($perms & CHMOD_READ)
			$perms |= CHMOD_EXECUTE;
	switch ($php)
		case 'owner':
			$result = @chmod($filename, ($owner << 6) + (0 << 3) + (0 << 0));
			clearstatcache();
			if (is_readable($filename) && phpbb_is_writable($filename))
				break;
		case 'group':
			$result = @chmod($filename, ($owner << 6) + ($perms << 3) + (0 << 0));
			clearstatcache();
			if ((!($perms & CHMOD_READ) || is_readable($filename)) && (!($perms & CHMOD_WRITE) || phpbb_is_writable($filename)))
				break;
		case 'other':
			$result = @chmod($filename, ($owner << 6) + ($perms << 3) + ($perms << 0));
			clearstatcache();
				break;
		default:
			return false;
		break;
	return $result;
* Test if a file/directory is writable
* This function calls the native is_writable() when not running under
* Windows and it is not disabled.
* @param string $file Path to perform write test on
* @return bool True when the path is writable, otherwise false.
function phpbb_is_writable($file)
	if (strtolower(substr(PHP_OS, 0, 3)) === 'win' || !function_exists('is_writable'))
		if (file_exists($file))
			// Canonicalise path to absolute path
			$file = phpbb_realpath($file);
			if (is_dir($file))
				// Test directory by creating a file inside the directory
				$result = @tempnam($file, 'i_w');
				if (is_string($result) && file_exists($result))
					unlink($result);
					// Ensure the file is actually in the directory (returned realpathed)
					return (strpos($result, $file) === 0) ? true : false;
				$handle = @fopen($file, 'r+');
				if (is_resource($handle))
					fclose($handle);
					return true;
			// file does not exist test if we can write to the directory
			$dir = dirname($file);
			if (file_exists($dir) && is_dir($dir) && phpbb_is_writable($dir))
				return true;
		return false;
		return is_writable($file);
// Compatibility functions
if (!function_exists('array_combine'))
	* A wrapper for the PHP5 function array_combine()
	* @param array $keys contains keys for the resulting array
	* @param array $values contains values for the resulting array
	* @return Returns an array by using the values from the keys array as keys and the
	* 	values from the values array as the corresponding values. Returns false if the
	* 	number of elements for each array isn't equal or if the arrays are empty.
	function array_combine($keys, $values)
		$keys = array_values($keys);
		$values = array_values($values);
		$n = sizeof($keys);
		$m = sizeof($values);
		if (!$n || !$m || ($n != $m))
			return false;
		$combined = array();
		for ($i = 0; $i < $n; $i++)
			$combined[$keys[$i]] = $values[$i];
		return $combined;
if (!function_exists('str_split'))
	* A wrapper for the PHP5 function str_split()
	* @param array $string contains the string to be converted
	* @param array $split_length contains the length of each chunk
	* @return  Converts a string to an array. If the optional split_length parameter is specified,
	*  	the returned array will be broken down into chunks with each being split_length in length,
	*  	otherwise each chunk will be one character in length. FALSE is returned if split_length is
	*  	less than 1. If the split_length length exceeds the length of string, the entire string is
	*  	returned as the first (and only) array element.
	function str_split($string, $split_length = 1)
		if ($split_length < 1)
			return false;
		else if ($split_length >= strlen($string))
			return array($string);
			preg_match_all('#.{1,' . $split_length . '}#s', $string, $matches);
			return $matches[0];
if (!function_exists('stripos'))
	* A wrapper for the PHP5 function stripos
	* Find position of first occurrence of a case-insensitive string
	* @param string $haystack is the string to search in
	* @param string $needle is the string to search for
	* @return mixed Returns the numeric position of the first occurrence of needle in the haystack string. Unlike strpos(), stripos() is case-insensitive.
	* Note that the needle may be a string of one or more characters.
	* If needle is not found, stripos() will return boolean FALSE.
	function stripos($haystack, $needle)
		if (preg_match('#' . preg_quote($needle, '#') . '#i', $haystack, $m))
			return strpos($haystack, $m[0]);
		return false;
* Checks if a path ($path) is absolute or relative
* @param string $path Path to check absoluteness of
* @return boolean
function is_absolute($path)
	return (isset($path[0]) && $path[0] == '/' || preg_match('#^[a-z]:[/\\\]#i', $path)) ? true : false;
* @author Chris Smith <chris@project-minerva.org>
* @copyright 2006 Project Minerva Team
* @param string $path The path which we should attempt to resolve.
* @return mixed
function phpbb_own_realpath($path)
	// Now to perform funky shizzle
	// Switch to use UNIX slashes
	$path = str_replace(DIRECTORY_SEPARATOR, '/', $path);
	$path_prefix = '';
	// Determine what sort of path we have
	if (is_absolute($path))
		$absolute = true;
		if ($path[0] == '/')
			// Absolute path, *NIX style
			$path_prefix = '';
			// Absolute path, Windows style
			// Remove the drive letter and colon
			$path_prefix = $path[0] . ':';
			$path = substr($path, 2);
		// Relative Path
		// Prepend the current working directory
		if (function_exists('getcwd'))
			// This is the best method, hopefully it is enabled!
			$path = str_replace(DIRECTORY_SEPARATOR, '/', getcwd()) . '/' . $path;
			$absolute = true;
			if (preg_match('#^[a-z]:#i', $path))
				$path_prefix = '';
		else if (isset($_SERVER['SCRIPT_FILENAME']) && !empty($_SERVER['SCRIPT_FILENAME']))
			// Warning: If chdir() has been used this will lie!
			// Warning: This has some problems sometime (CLI can create them easily)
			$path = str_replace(DIRECTORY_SEPARATOR, '/', dirname($_SERVER['SCRIPT_FILENAME'])) . '/' . $path;
			$absolute = true;
			$path_prefix = '';
			// We have no way of getting the absolute path, just run on using relative ones.
			$absolute = false;
			$path_prefix = '.';
	// Remove any repeated slashes
	$path = preg_replace('#/{2,}#', '/', $path);
	// Remove the slashes from the start and end of the path
	$path = trim($path, '/');
	// Break the string into little bits for us to nibble on
	$bits = explode('/', $path);
	// Remove any . in the path, renumber array for the loop below
	$bits = array_values(array_diff($bits, array('.')));
	// Lets get looping, run over and resolve any .. (up directory)
	for ($i = 0, $max = sizeof($bits); $i < $max; $i++)
		// @todo Optimise
		if ($bits[$i] == '..' )
			if (isset($bits[$i - 1]))
				if ($bits[$i - 1] != '..')
					// We found a .. and we are able to traverse upwards, lets do it!
					unset($bits[$i]);
					unset($bits[$i - 1]);
					$i -= 2;
					$max -= 2;
					$bits = array_values($bits);
			else if ($absolute) // ie. !isset($bits[$i - 1]) && $absolute
				// We have an absolute path trying to descend above the root of the filesystem
				// ... Error!
				return false;
	// Prepend the path prefix
	array_unshift($bits, $path_prefix);
	$resolved = '';
	$max = sizeof($bits) - 1;
	// Check if we are able to resolve symlinks, Windows cannot.
	$symlink_resolve = (function_exists('readlink')) ? true : false;
	foreach ($bits as $i => $bit)
		if (@is_dir("$resolved/$bit") || ($i == $max && @is_file("$resolved/$bit")))
			// Path Exists
			if ($symlink_resolve && is_link("$resolved/$bit") && ($link = readlink("$resolved/$bit")))
				// Resolved a symlink.
				$resolved = $link . (($i == $max) ? '' : '/');
				continue;
			// Something doesn't exist here!
			// This is correct realpath() behaviour but sadly open_basedir and safe_mode make this problematic
			// return false;
		$resolved .= $bit . (($i == $max) ? '' : '/');
	// @todo If the file exists fine and open_basedir only has one path we should be able to prepend it
	// because we must be inside that basedir, the question is where...
	// @internal The slash in is_dir() gets around an open_basedir restriction
	if (!@file_exists($resolved) || (!@is_dir($resolved . '/') && !is_file($resolved)))
		return false;
	// Put the slashes back to the native operating systems slashes
	$resolved = str_replace('/', DIRECTORY_SEPARATOR, $resolved);
	// Check for DIRECTORY_SEPARATOR at the end (and remove it!)
	if (substr($resolved, -1) == DIRECTORY_SEPARATOR)
		return substr($resolved, 0, -1);
	return $resolved; // We got here, in the end!
if (!function_exists('realpath'))
	* A wrapper for realpath
	* @ignore
	function phpbb_realpath($path)
		return phpbb_own_realpath($path);
		$realpath = realpath($path);
		// Strangely there are provider not disabling realpath but returning strange values. :o
		// We at least try to cope with them.
		if ($realpath === $path || $realpath === false)
		if (substr($realpath, -1) == DIRECTORY_SEPARATOR)
			$realpath = substr($realpath, 0, -1);
		return $realpath;
* Eliminates useless . and .. components from specified path.
* @param string $path Path to clean
* @return string Cleaned path
function phpbb_clean_path($path)
	$exploded = explode('/', $path);
	$filtered = array();
	foreach ($exploded as $part)
		if ($part === '.' && !empty($filtered))
			continue;
		if ($part === '..' && !empty($filtered) && $filtered[sizeof($filtered) - 1] !== '..')
			array_pop($filtered);
			$filtered[] = $part;
	$path = implode('/', $filtered);
	return $path;
if (!function_exists('htmlspecialchars_decode'))
	* A wrapper for htmlspecialchars_decode
	* @ignore
	function htmlspecialchars_decode($string, $quote_style = ENT_COMPAT)
		return strtr($string, array_flip(get_html_translation_table(HTML_SPECIALCHARS, $quote_style)));
// functions used for building option fields
* Pick a language, any language ...
function language_select($default = '')
	global $db;
	$sql = 'SELECT lang_iso, lang_local_name
		FROM ' . LANG_TABLE . '
		ORDER BY lang_english_name';
	$lang_options = '';
		$selected = ($row['lang_iso'] == $default) ? ' selected="selected"' : '';
		$lang_options .= '<option value="' . $row['lang_iso'] . '"' . $selected . '>' . $row['lang_local_name'] . '</option>';
	$db->sql_freeresult($result);
	return $lang_options;
* Pick a template/theme combo,
function style_select($default = '', $all = false)
	global $db;
	$sql_where = (!$all) ? 'WHERE style_active = 1 ' : '';
	$sql = 'SELECT style_id, style_name
		FROM ' . STYLES_TABLE . "
		$sql_where
		ORDER BY style_name";
	$style_options = '';
		$selected = ($row['style_id'] == $default) ? ' selected="selected"' : '';
		$style_options .= '<option value="' . $row['style_id'] . '"' . $selected . '>' . $row['style_name'] . '</option>';
	return $style_options;
* Pick a timezone
function tz_select($default = '', $truncate = false)
	global $user;
	$tz_select = '';
	foreach ($user->lang['tz_zones'] as $offset => $zone)
		if ($truncate)
			$zone_trunc = truncate_string($zone, 50, 255, false, '...');
			$zone_trunc = $zone;
		if (is_numeric($offset))
			$selected = ($offset == $default) ? ' selected="selected"' : '';
			$tz_select .= '<option title="' . $zone . '" value="' . $offset . '"' . $selected . '>' . $zone_trunc . '</option>';
	return $tz_select;
// Functions handling topic/post tracking/marking
* Marks a topic/forum as read
* Marks a topic as posted to
* @param int $user_id can only be used with $mode == 'post'
function markread($mode, $forum_id = false, $topic_id = false, $post_time = 0, $user_id = 0)
	global $db, $user, $config;
	if ($mode == 'all')
		if ($forum_id === false || !sizeof($forum_id))
			if ($config['load_db_lastread'] && $user->data['is_registered'])
				// Mark all forums read (index page)
				$db->sql_query('DELETE FROM ' . TOPICS_TRACK_TABLE . " WHERE user_id = {$user->data['user_id']}");
				$db->sql_query('DELETE FROM ' . FORUMS_TRACK_TABLE . " WHERE user_id = {$user->data['user_id']}");
				$db->sql_query('UPDATE ' . USERS_TABLE . ' SET user_lastmark = ' . time() . " WHERE user_id = {$user->data['user_id']}");
			else if ($config['load_anon_lastread'] || $user->data['is_registered'])
				$tracking_topics = (isset($_COOKIE[$config['cookie_name'] . '_track'])) ? ((STRIP) ? stripslashes($_COOKIE[$config['cookie_name'] . '_track']) : $_COOKIE[$config['cookie_name'] . '_track']) : '';
				$tracking_topics = ($tracking_topics) ? tracking_unserialize($tracking_topics) : array();
				unset($tracking_topics['tf']);
				unset($tracking_topics['t']);
				unset($tracking_topics['f']);
				$tracking_topics['l'] = base_convert(time() - $config['board_startdate'], 10, 36);
				$user->set_cookie('track', tracking_serialize($tracking_topics), time() + 31536000);
				$_COOKIE[$config['cookie_name'] . '_track'] = (STRIP) ? addslashes(tracking_serialize($tracking_topics)) : tracking_serialize($tracking_topics);
				unset($tracking_topics);
		return;
	else if ($mode == 'topics')
		// Mark all topics in forums read
		if (!is_array($forum_id))
			$forum_id = array($forum_id);
		// Add 0 to forums array to mark global announcements correctly
		// $forum_id[] = 0;
			$sql = 'DELETE FROM ' . TOPICS_TRACK_TABLE . "
					AND " . $db->sql_in_set('forum_id', $forum_id);
			$sql = 'SELECT forum_id
			$sql_update = array();
				$sql_update[] = (int) $row['forum_id'];
			if (sizeof($sql_update))
				$sql = 'UPDATE ' . FORUMS_TRACK_TABLE . '
					SET mark_time = ' . time() . "
						AND " . $db->sql_in_set('forum_id', $sql_update);
			if ($sql_insert = array_diff($forum_id, $sql_update))
				$sql_ary = array();
				foreach ($sql_insert as $f_id)
					$sql_ary[] = array(
						'user_id'	=> (int) $user->data['user_id'],
						'forum_id'	=> (int) $f_id,
						'mark_time'	=> time()
				$db->sql_multi_insert(FORUMS_TRACK_TABLE, $sql_ary);
			$tracking = (isset($_COOKIE[$config['cookie_name'] . '_track'])) ? ((STRIP) ? stripslashes($_COOKIE[$config['cookie_name'] . '_track']) : $_COOKIE[$config['cookie_name'] . '_track']) : '';
			$tracking = ($tracking) ? tracking_unserialize($tracking) : array();
			foreach ($forum_id as $f_id)
				$topic_ids36 = (isset($tracking['tf'][$f_id])) ? $tracking['tf'][$f_id] : array();
				if (isset($tracking['tf'][$f_id]))
					unset($tracking['tf'][$f_id]);
				foreach ($topic_ids36 as $topic_id36)
					unset($tracking['t'][$topic_id36]);
				if (isset($tracking['f'][$f_id]))
					unset($tracking['f'][$f_id]);
				$tracking['f'][$f_id] = base_convert(time() - $config['board_startdate'], 10, 36);
			if (isset($tracking['tf']) && empty($tracking['tf']))
				unset($tracking['tf']);
			$user->set_cookie('track', tracking_serialize($tracking), time() + 31536000);
			$_COOKIE[$config['cookie_name'] . '_track'] = (STRIP) ? addslashes(tracking_serialize($tracking)) : tracking_serialize($tracking);
			unset($tracking);
		return;
	else if ($mode == 'topic')
		if ($topic_id === false || $forum_id === false)
			return;
			$sql = 'UPDATE ' . TOPICS_TRACK_TABLE . '
				SET mark_time = ' . (($post_time) ? $post_time : time()) . "
					AND topic_id = $topic_id";
			// insert row
			if (!$db->sql_affectedrows())
				$db->sql_return_on_error(true);
				$sql_ary = array(
					'topic_id'		=> (int) $topic_id,
					'forum_id'		=> (int) $forum_id,
					'mark_time'		=> ($post_time) ? (int) $post_time : time(),
				$db->sql_query('INSERT INTO ' . TOPICS_TRACK_TABLE . ' ' . $db->sql_build_array('INSERT', $sql_ary));
				$db->sql_return_on_error(false);
			$topic_id36 = base_convert($topic_id, 10, 36);
			if (!isset($tracking['t'][$topic_id36]))
				$tracking['tf'][$forum_id][$topic_id36] = true;
			$post_time = ($post_time) ? $post_time : time();
			$tracking['t'][$topic_id36] = base_convert($post_time - $config['board_startdate'], 10, 36);
			// If the cookie grows larger than 10000 characters we will remove the smallest value
			// This can result in old topics being unread - but most of the time it should be accurate...
			if (isset($_COOKIE[$config['cookie_name'] . '_track']) && strlen($_COOKIE[$config['cookie_name'] . '_track']) > 10000)
				//echo 'Cookie grown too large' . print_r($tracking, true);
				// We get the ten most minimum stored time offsets and its associated topic ids
				$time_keys = array();
				for ($i = 0; $i < 10 && sizeof($tracking['t']); $i++)
					$min_value = min($tracking['t']);
					$m_tkey = array_search($min_value, $tracking['t']);
					unset($tracking['t'][$m_tkey]);
					$time_keys[$m_tkey] = $min_value;
				// Now remove the topic ids from the array...
				foreach ($tracking['tf'] as $f_id => $topic_id_ary)
					foreach ($time_keys as $m_tkey => $min_value)
						if (isset($topic_id_ary[$m_tkey]))
							$tracking['f'][$f_id] = $min_value;
							unset($tracking['tf'][$f_id][$m_tkey]);
					$user->data['user_lastmark'] = intval(base_convert(max($time_keys) + $config['board_startdate'], 36, 10));
					$db->sql_query('UPDATE ' . USERS_TABLE . ' SET user_lastmark = ' . $user->data['user_lastmark'] . " WHERE user_id = {$user->data['user_id']}");
					$tracking['l'] = max($time_keys);
		return;
	else if ($mode == 'post')
		if ($topic_id === false)
			return;
		$use_user_id = (!$user_id) ? $user->data['user_id'] : $user_id;
		if ($config['load_db_track'] && $use_user_id != ANONYMOUS)
			$sql_ary = array(
				'user_id'		=> (int) $use_user_id,
				'topic_posted'	=> 1
			$db->sql_query('INSERT INTO ' . TOPICS_POSTED_TABLE . ' ' . $db->sql_build_array('INSERT', $sql_ary));
		return;
* Get topic tracking info by using already fetched info
function get_topic_tracking($forum_id, $topic_ids, &$rowset, $forum_mark_time, $global_announce_list = false)
	global $config, $user;
	$last_read = array();
	if (!is_array($topic_ids))
		$topic_ids = array($topic_ids);
	foreach ($topic_ids as $topic_id)
		if (!empty($rowset[$topic_id]['mark_time']))
			$last_read[$topic_id] = $rowset[$topic_id]['mark_time'];
	$topic_ids = array_diff($topic_ids, array_keys($last_read));
	if (sizeof($topic_ids))
		$mark_time = array();
		// Get global announcement info
		if ($global_announce_list && sizeof($global_announce_list))
			if (!isset($forum_mark_time[0]))
				global $db;
				$sql = 'SELECT mark_time
						AND forum_id = 0";
				if ($row)
					$mark_time[0] = $row['mark_time'];
				if ($forum_mark_time[0] !== false)
					$mark_time[0] = $forum_mark_time[0];
		if (!empty($forum_mark_time[$forum_id]) && $forum_mark_time[$forum_id] !== false)
			$mark_time[$forum_id] = $forum_mark_time[$forum_id];
		$user_lastmark = (isset($mark_time[$forum_id])) ? $mark_time[$forum_id] : $user->data['user_lastmark'];
			if ($global_announce_list && isset($global_announce_list[$topic_id]))
				$last_read[$topic_id] = (isset($mark_time[0])) ? $mark_time[0] : $user_lastmark;
				$last_read[$topic_id] = $user_lastmark;
	return $last_read;
* Get topic tracking info from db (for cookie based tracking only this function is used)
function get_complete_topic_tracking($forum_id, $topic_ids, $global_announce_list = false)
		global $db;
		$sql = 'SELECT topic_id, mark_time
				AND " . $db->sql_in_set('topic_id', $topic_ids);
			$last_read[$row['topic_id']] = $row['mark_time'];
			$sql = 'SELECT forum_id, mark_time
					AND forum_id " .
					(($global_announce_list && sizeof($global_announce_list)) ? "IN (0, $forum_id)" : "= $forum_id");
				$mark_time[$row['forum_id']] = $row['mark_time'];
		global $tracking_topics;
		if (!isset($tracking_topics) || !sizeof($tracking_topics))
		if (!$user->data['is_registered'])
			$user_lastmark = (isset($tracking_topics['l'])) ? base_convert($tracking_topics['l'], 36, 10) + $config['board_startdate'] : 0;
			$user_lastmark = $user->data['user_lastmark'];
			if (isset($tracking_topics['t'][$topic_id36]))
				$last_read[$topic_id] = base_convert($tracking_topics['t'][$topic_id36], 36, 10) + $config['board_startdate'];
				if (isset($tracking_topics['f'][0]))
					$mark_time[0] = base_convert($tracking_topics['f'][0], 36, 10) + $config['board_startdate'];
			if (isset($tracking_topics['f'][$forum_id]))
				$mark_time[$forum_id] = base_convert($tracking_topics['f'][$forum_id], 36, 10) + $config['board_startdate'];
			$user_lastmark = (isset($mark_time[$forum_id])) ? $mark_time[$forum_id] : $user_lastmark;
	return $last_read;
* Get list of unread topics
* @param int $user_id			User ID (or false for current user)
* @param string $sql_extra		Extra WHERE SQL statement
* @param string $sql_sort		ORDER BY SQL sorting statement
* @param string $sql_limit		Limits the size of unread topics list, 0 for unlimited query
* @param string $sql_limit_offset  Sets the offset of the first row to search, 0 to search from the start
* @return array[int][int]		Topic ids as keys, mark_time of topic as value
function get_unread_topics($user_id = false, $sql_extra = '', $sql_sort = '', $sql_limit = 1001, $sql_limit_offset = 0)
	global $config, $db, $user;
	$user_id = ($user_id === false) ? (int) $user->data['user_id'] : (int) $user_id;
	// Data array we're going to return
	$unread_topics = array();
	if (empty($sql_sort))
		$sql_sort = 'ORDER BY t.topic_last_post_time DESC';
		// Get list of the unread topics
		$last_mark = (int) $user->data['user_lastmark'];
		$sql_array = array(
			'SELECT'		=> 't.topic_id, t.topic_last_post_time, tt.mark_time as topic_mark_time, ft.mark_time as forum_mark_time',
			'FROM'			=> array(TOPICS_TABLE => 't'),
			'LEFT_JOIN'		=> array(
				array(
					'FROM'	=> array(TOPICS_TRACK_TABLE => 'tt'),
					'ON'	=> "tt.user_id = $user_id AND t.topic_id = tt.topic_id",
				array(
					'FROM'	=> array(FORUMS_TRACK_TABLE => 'ft'),
					'ON'	=> "ft.user_id = $user_id AND t.forum_id = ft.forum_id",
			'WHERE'			=> "
				 t.topic_last_post_time > $last_mark AND
				(tt.mark_time IS NOT NULL AND t.topic_last_post_time > tt.mark_time) OR
				(tt.mark_time IS NULL AND ft.mark_time IS NOT NULL AND t.topic_last_post_time > ft.mark_time) OR
				(tt.mark_time IS NULL AND ft.mark_time IS NULL)
				$sql_extra
				$sql_sort",
		$sql = $db->sql_build_query('SELECT', $sql_array);
		$result = $db->sql_query_limit($sql, $sql_limit, $sql_limit_offset);
			$topic_id = (int) $row['topic_id'];
			$unread_topics[$topic_id] = ($row['topic_mark_time']) ? (int) $row['topic_mark_time'] : (($row['forum_mark_time']) ? (int) $row['forum_mark_time'] : $last_mark);
		if (empty($tracking_topics))
			$tracking_topics = request_var($config['cookie_name'] . '_track', '', false, true);
			$user_lastmark = (int) $user->data['user_lastmark'];
		$sql = 'SELECT t.topic_id, t.forum_id, t.topic_last_post_time
			FROM ' . TOPICS_TABLE . ' t
			WHERE t.topic_last_post_time > ' . $user_lastmark . "
			$sql_extra
			$sql_sort";
			$forum_id = (int) $row['forum_id'];
				$last_read = base_convert($tracking_topics['t'][$topic_id36], 36, 10) + $config['board_startdate'];
				if ($row['topic_last_post_time'] > $last_read)
					$unread_topics[$topic_id] = $last_read;
			else if (isset($tracking_topics['f'][$forum_id]))
				$mark_time = base_convert($tracking_topics['f'][$forum_id], 36, 10) + $config['board_startdate'];
				if ($row['topic_last_post_time'] > $mark_time)
					$unread_topics[$topic_id] = $mark_time;
				$unread_topics[$topic_id] = $user_lastmark;
	return $unread_topics;
* Check for read forums and update topic tracking info accordingly
* @param int $forum_id the forum id to check
* @param int $forum_last_post_time the forums last post time
* @param int $f_mark_time the forums last mark time if user is registered and load_db_lastread enabled
* @param int $mark_time_forum false if the mark time needs to be obtained, else the last users forum mark time
* @return true if complete forum got marked read, else false.
function update_forum_tracking_info($forum_id, $forum_last_post_time, $f_mark_time = false, $mark_time_forum = false)
	global $db, $tracking_topics, $user, $config, $auth;
	// Determine the users last forum mark time if not given.
	if ($mark_time_forum === false)
			$mark_time_forum = (!empty($f_mark_time)) ? $f_mark_time : $user->data['user_lastmark'];
				$user->data['user_lastmark'] = (isset($tracking_topics['l'])) ? (int) (base_convert($tracking_topics['l'], 36, 10) + $config['board_startdate']) : 0;
			$mark_time_forum = (isset($tracking_topics['f'][$forum_id])) ? (int) (base_convert($tracking_topics['f'][$forum_id], 36, 10) + $config['board_startdate']) : $user->data['user_lastmark'];
	// Handle update of unapproved topics info.
	// Only update for moderators having m_approve permission for the forum.
	$sql_update_unapproved = ($auth->acl_get('m_approve', $forum_id)) ? '': 'AND t.topic_approved = 1';
	// Check the forum for any left unread topics.
	// If there are none, we mark the forum as read.
		if ($mark_time_forum >= $forum_last_post_time)
			// We do not need to mark read, this happened before. Therefore setting this to true
			$row = true;
			$sql = 'SELECT t.forum_id
				LEFT JOIN ' . TOPICS_TRACK_TABLE . ' tt
					ON (tt.topic_id = t.topic_id
						AND tt.user_id = ' . $user->data['user_id'] . ')
				WHERE t.forum_id = ' . $forum_id . '
					AND t.topic_last_post_time > ' . $mark_time_forum . '
					AND t.topic_moved_id = 0 ' .
					$sql_update_unapproved . '
					AND (tt.topic_id IS NULL
						OR tt.mark_time < t.topic_last_post_time)';
		// Get information from cookie
		$row = false;
		if (!isset($tracking_topics['tf'][$forum_id]))
			$row = true;
					$sql_update_unapproved;
			$check_forum = $tracking_topics['tf'][$forum_id];
			$unread = false;
				if (!isset($check_forum[base_convert($row['topic_id'], 10, 36)]))
					$unread = true;
					break;
			$row = $unread;
		$row = true;
	if (!$row)
		markread('topics', $forum_id);
		return true;
	return false;
* Transform an array into a serialized format
function tracking_serialize($input)
	$out = '';
	foreach ($input as $key => $value)
		if (is_array($value))
			$out .= $key . ':(' . tracking_serialize($value) . ');';
			$out .= $key . ':' . $value . ';';
	return $out;
* Transform a serialized array into an actual array
function tracking_unserialize($string, $max_depth = 3)
	$n = strlen($string);
	if ($n > 10010)
		die('Invalid data supplied');
	$data = $stack = array();
	$key = '';
	$mode = 0;
	$level = &$data;
	for ($i = 0; $i < $n; ++$i)
		switch ($mode)
			case 0:
				switch ($string[$i])
					case ':':
						$level[$key] = 0;
						$mode = 1;
					break;
					case ')':
						unset($level);
						$level = array_pop($stack);
						$mode = 3;
					break;
					default:
						$key .= $string[$i];
			break;
			case 1:
					case '(':
						if (sizeof($stack) >= $max_depth)
						$stack[] = &$level;
						$level[$key] = array();
						$level = &$level[$key];
						$key = '';
						$mode = 0;
					break;
					default:
						$level[$key] = $string[$i];
						$mode = 2;
					break;
			break;
			case 2:
					case ')':
						unset($level);
						$mode = 3;
					break;
					case ';':
						$key = '';
						$mode = 0;
					break;
					default:
						$level[$key] .= $string[$i];
					break;
			break;
			case 3:
					case ')':
						unset($level);
					break;
					case ';':
						$key = '';
						$mode = 0;
					break;
					default:
					break;
			break;
	if (sizeof($stack) != 0 || ($mode != 0 && $mode != 3))
	return $level;
// Pagination functions
* Pagination routine, generates page number sequence
* tpl_prefix is for using different pagination blocks at one page
function generate_pagination($base_url, $num_items, $per_page, $start_item, $add_prevnext_text = false, $tpl_prefix = '')
	global $template, $user;
	// Make sure $per_page is a valid value
	$per_page = ($per_page <= 0) ? 1 : $per_page;
	$seperator = '<span class="page-sep">' . $user->lang['COMMA_SEPARATOR'] . '</span>';
	$total_pages = ceil($num_items / $per_page);
	if ($total_pages == 1 || !$num_items)
		return false;
	$on_page = floor($start_item / $per_page) + 1;
	$url_delim = (strpos($base_url, '?') === false) ? '?' : ((strpos($base_url, '?') === strlen($base_url) - 1) ? '' : '&');
	$page_string = ($on_page == 1) ? '<strong>1</strong>' : '<a href="' . $base_url . '">1</a>';
	if ($total_pages > 5)
		$start_cnt = min(max(1, $on_page - 4), $total_pages - 5);
		$end_cnt = max(min($total_pages, $on_page + 4), 6);
		$page_string .= ($start_cnt > 1) ? '<span class="page-dots"> ... </span>' : $seperator;
		for ($i = $start_cnt + 1; $i < $end_cnt; $i++)
			$page_string .= ($i == $on_page) ? '<strong>' . $i . '</strong>' : '<a href="' . $base_url . "{$url_delim}start=" . (($i - 1) * $per_page) . '">' . $i . '</a>';
			if ($i < $end_cnt - 1)
				$page_string .= $seperator;
		$page_string .= ($end_cnt < $total_pages) ? '<span class="page-dots"> ... </span>' : $seperator;
		for ($i = 2; $i < $total_pages; $i++)
			if ($i < $total_pages)
	$page_string .= ($on_page == $total_pages) ? '<strong>' . $total_pages . '</strong>' : '<a href="' . $base_url . "{$url_delim}start=" . (($total_pages - 1) * $per_page) . '">' . $total_pages . '</a>';
	if ($add_prevnext_text)
		if ($on_page != 1)
			$page_string = '<a href="' . $base_url . "{$url_delim}start=" . (($on_page - 2) * $per_page) . '">' . $user->lang['PREVIOUS'] . '</a>&nbsp;&nbsp;' . $page_string;
		if ($on_page != $total_pages)
			$page_string .= '&nbsp;&nbsp;<a href="' . $base_url . "{$url_delim}start=" . ($on_page * $per_page) . '">' . $user->lang['NEXT'] . '</a>';
	$template->assign_vars(array(
		$tpl_prefix . 'BASE_URL'		=> $base_url,
		'A_' . $tpl_prefix . 'BASE_URL'	=> addslashes($base_url),
		$tpl_prefix . 'PER_PAGE'		=> $per_page,
		$tpl_prefix . 'PREVIOUS_PAGE'	=> ($on_page == 1) ? '' : $base_url . "{$url_delim}start=" . (($on_page - 2) * $per_page),
		$tpl_prefix . 'NEXT_PAGE'		=> ($on_page == $total_pages) ? '' : $base_url . "{$url_delim}start=" . ($on_page * $per_page),
		$tpl_prefix . 'TOTAL_PAGES'		=> $total_pages,
	return $page_string;
* Return current page (pagination)
function on_page($num_items, $per_page, $start)
	$on_page = floor($start / $per_page) + 1;
		'ON_PAGE'		=> $on_page)
	return sprintf($user->lang['PAGE_OF'], $on_page, max(ceil($num_items / $per_page), 1));
// Server functions (building urls, redirecting...)
* Append session id to url.
* This function supports hooks.
* @param string $url The url the session id needs to be appended to (can have params)
* @param mixed $params String or array of additional url parameters
* @param bool $is_amp Is url using & (true) or & (false)
* @param string $session_id Possibility to use a custom session id instead of the global one
* Examples:
* <code>
* append_sid("{$phpbb_root_path}viewtopic.$phpEx?t=1&f=2");
* append_sid("{$phpbb_root_path}viewtopic.$phpEx", 't=1&f=2');
* append_sid("{$phpbb_root_path}viewtopic.$phpEx", 't=1&f=2', false);
* append_sid("{$phpbb_root_path}viewtopic.$phpEx", array('t' => 1, 'f' => 2));
* </code>
function append_sid($url, $params = false, $is_amp = true, $session_id = false)
	global $_SID, $_EXTRA_URL, $phpbb_hook;
	if ($params === '' || (is_array($params) && empty($params)))
		// Do not append the ? if the param-list is empty anyway.
		$params = false;
	// Developers using the hook function need to globalise the $_SID and $_EXTRA_URL on their own and also handle it appropriately.
	// They could mimic most of what is within this function
	if (!empty($phpbb_hook) && $phpbb_hook->call_hook(__FUNCTION__, $url, $params, $is_amp, $session_id))
		if ($phpbb_hook->hook_return(__FUNCTION__))
			return $phpbb_hook->hook_return_result(__FUNCTION__);
	$params_is_array = is_array($params);
	// Get anchor
	$anchor = '';
	if (strpos($url, '#') !== false)
		list($url, $anchor) = explode('#', $url, 2);
		$anchor = '#' . $anchor;
	else if (!$params_is_array && strpos($params, '#') !== false)
		list($params, $anchor) = explode('#', $params, 2);
	// Handle really simple cases quickly
	if ($_SID == '' && $session_id === false && empty($_EXTRA_URL) && !$params_is_array && !$anchor)
		if ($params === false)
			return $url;
		$url_delim = (strpos($url, '?') === false) ? '?' : (($is_amp) ? '&' : '&');
		return $url . ($params !== false ? $url_delim. $params : '');
	// Assign sid if session id is not specified
	if ($session_id === false)
		$session_id = $_SID;
	$amp_delim = ($is_amp) ? '&' : '&';
	$url_delim = (strpos($url, '?') === false) ? '?' : $amp_delim;
	// Appending custom url parameter?
	$append_url = (!empty($_EXTRA_URL)) ? implode($amp_delim, $_EXTRA_URL) : '';
	// Use the short variant if possible ;)
		// Append session id
		if (!$session_id)
			return $url . (($append_url) ? $url_delim . $append_url : '') . $anchor;
			return $url . (($append_url) ? $url_delim . $append_url . $amp_delim : $url_delim) . 'sid=' . $session_id . $anchor;
	// Build string if parameters are specified as array
	if (is_array($params))
		$output = array();
		foreach ($params as $key => $item)
			if ($item === NULL)
				continue;
			if ($key == '#')
				$anchor = '#' . $item;
				continue;
			$output[] = $key . '=' . $item;
		$params = implode($amp_delim, $output);
	// Append session id and parameters (even if they are empty)
	// If parameters are empty, the developer can still append his/her parameters without caring about the delimiter
	return $url . (($append_url) ? $url_delim . $append_url . $amp_delim : $url_delim) . $params . ((!$session_id) ? '' : $amp_delim . 'sid=' . $session_id) . $anchor;
* Generate board url (example: http://www.example.com/phpBB)
* @param bool $without_script_path if set to true the script path gets not appended (example: http://www.example.com)
* @return string the generated board url
function generate_board_url($without_script_path = false)
	$server_name = $user->host;
	$server_port = (!empty($_SERVER['SERVER_PORT'])) ? (int) $_SERVER['SERVER_PORT'] : (int) getenv('SERVER_PORT');
	// Forcing server vars is the only way to specify/override the protocol
	if ($config['force_server_vars'] || !$server_name)
		$server_protocol = ($config['server_protocol']) ? $config['server_protocol'] : (($config['cookie_secure']) ? 'https://' : 'http://');
		$server_name = $config['server_name'];
		$server_port = (int) $config['server_port'];
		$script_path = $config['script_path'];
		$url = $server_protocol . $server_name;
		$cookie_secure = $config['cookie_secure'];
		// Do not rely on cookie_secure, users seem to think that it means a secured cookie instead of an encrypted connection
		$cookie_secure = (isset($_SERVER['HTTPS']) && $_SERVER['HTTPS'] == 'on') ? 1 : 0;
		$url = (($cookie_secure) ? 'https://' : 'http://') . $server_name;
		$script_path = $user->page['root_script_path'];
	if ($server_port && (($cookie_secure && $server_port <> 443) || (!$cookie_secure && $server_port <> 80)))
		// HTTP HOST can carry a port number (we fetch $user->host, but for old versions this may be true)
		if (strpos($server_name, ':') === false)
			$url .= ':' . $server_port;
	if (!$without_script_path)
		$url .= $script_path;
	// Strip / from the end
	if (substr($url, -1, 1) == '/')
		$url = substr($url, 0, -1);
	return $url;
* Redirects the user to another page then exits the script nicely
* This function is intended for urls within the board. It's not meant to redirect to cross-domains.
* @param string $url The url to redirect to
* @param bool $return If true, do not redirect but return the sanitized URL. Default is no return.
* @param bool $disable_cd_check If true, redirect() will redirect to an external domain. If false, the redirect point to the boards url if it does not match the current domain. Default is false.
function redirect($url, $return = false, $disable_cd_check = false)
	global $db, $cache, $config, $user, $phpbb_root_path;
	$failover_flag = false;
	if (empty($user->lang))
		$user->add_lang('common');
	if (!$return)
		garbage_collection();
	// Make sure no &'s are in, this will break the redirect
	$url = str_replace('&', '&', $url);
	// Determine which type of redirect we need to handle...
	$url_parts = @parse_url($url);
	if ($url_parts === false)
		// Malformed url, redirect to current page...
		$url = generate_board_url() . '/' . $user->page['page'];
	else if (!empty($url_parts['scheme']) && !empty($url_parts['host']))
		// Attention: only able to redirect within the same domain if $disable_cd_check is false (yourdomain.com -> www.yourdomain.com will not work)
		if (!$disable_cd_check && $url_parts['host'] !== $user->host)
			$url = generate_board_url();
	else if ($url[0] == '/')
		// Absolute uri, prepend direct url...
		$url = generate_board_url(true) . $url;
		// Relative uri
		$pathinfo = pathinfo($url);
		if (!$disable_cd_check && !file_exists($pathinfo['dirname'] . '/'))
			$url = str_replace('../', '', $url);
			if (!file_exists($pathinfo['dirname'] . '/'))
				// fallback to "last known user page"
				// at least this way we know the user does not leave the phpBB root
				$failover_flag = true;
		if (!$failover_flag)
			// Is the uri pointing to the current directory?
			if ($pathinfo['dirname'] == '.')
				$url = str_replace('./', '', $url);
				// Strip / from the beginning
				if ($url && substr($url, 0, 1) == '/')
					$url = substr($url, 1);
				if ($user->page['page_dir'])
					$url = generate_board_url() . '/' . $user->page['page_dir'] . '/' . $url;
					$url = generate_board_url() . '/' . $url;
				// Used ./ before, but $phpbb_root_path is working better with urls within another root path
				$root_dirs = explode('/', str_replace('\\', '/', phpbb_realpath($phpbb_root_path)));
				$page_dirs = explode('/', str_replace('\\', '/', phpbb_realpath($pathinfo['dirname'])));
				$intersection = array_intersect_assoc($root_dirs, $page_dirs);
				$root_dirs = array_diff_assoc($root_dirs, $intersection);
				$page_dirs = array_diff_assoc($page_dirs, $intersection);
				$dir = str_repeat('../', sizeof($root_dirs)) . implode('/', $page_dirs);
				if ($dir && substr($dir, -1, 1) == '/')
					$dir = substr($dir, 0, -1);
				if ($dir && substr($dir, 0, 1) == '/')
					$dir = substr($dir, 1);
				$url = str_replace($pathinfo['dirname'] . '/', '', $url);
				if (substr($url, 0, 1) == '/')
				$url = (!empty($dir) ? $dir . '/' : '') . $url;
	// Make sure no linebreaks are there... to prevent http response splitting for PHP < 4.4.2
	if (strpos(urldecode($url), "\n") !== false || strpos(urldecode($url), "\r") !== false || strpos($url, ';') !== false)
		trigger_error('Tried to redirect to potentially insecure url.', E_USER_ERROR);
	// Now, also check the protocol and for a valid url the last time...
	$allowed_protocols = array('http', 'https', 'ftp', 'ftps');
	$url_parts = parse_url($url);
	if ($url_parts === false || empty($url_parts['scheme']) || !in_array($url_parts['scheme'], $allowed_protocols))
	if ($return)
		return $url;
	// Redirect via an HTML form for PITA webservers
	if (@preg_match('#Microsoft|WebSTAR|Xitami#', getenv('SERVER_SOFTWARE')))
		header('Refresh: 0; URL=' . $url);
		echo '<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">';
		echo '<html xmlns="http://www.w3.org/1999/xhtml" dir="' . $user->lang['DIRECTION'] . '" lang="' . $user->lang['USER_LANG'] . '" xml:lang="' . $user->lang['USER_LANG'] . '">';
		echo '<head>';
		echo '<meta http-equiv="content-type" content="text/html; charset=utf-8" />';
		echo '<meta http-equiv="refresh" content="0; url=' . str_replace('&', '&', $url) . '" />';
		echo '<title>' . $user->lang['REDIRECT'] . '</title>';
		echo '</head>';
		echo '<body>';
		echo '<div style="text-align: center;">' . sprintf($user->lang['URL_REDIRECT'], '<a href="' . str_replace('&', '&', $url) . '">', '</a>') . '</div>';
		echo '</body>';
		echo '</html>';
		exit;
	// Behave as per HTTP/1.1 spec for others
	header('Location: ' . $url);
	exit;
* Re-Apply session id after page reloads
function reapply_sid($url)
	global $phpEx, $phpbb_root_path;
	if ($url === "index.$phpEx")
		return append_sid("index.$phpEx");
	else if ($url === "{$phpbb_root_path}index.$phpEx")
		return append_sid("{$phpbb_root_path}index.$phpEx");
	// Remove previously added sid
	if (strpos($url, 'sid=') !== false)
		// All kind of links
		$url = preg_replace('/(\?)?(&|&)?sid=[a-z0-9]+/', '', $url);
		// if the sid was the first param, make the old second as first ones
		$url = preg_replace("/$phpEx(&|&)+?/", "$phpEx?", $url);
	return append_sid($url);
* Returns url from the session/current page with an re-appended SID with optionally stripping vars from the url
function build_url($strip_vars = false)
	global $user, $phpbb_root_path;
	// Append SID
	$redirect = append_sid($user->page['page'], false, false);
	// Add delimiter if not there...
	if (strpos($redirect, '?') === false)
		$redirect .= '?';
	// Strip vars...
	if ($strip_vars !== false && strpos($redirect, '?') !== false)
		if (!is_array($strip_vars))
			$strip_vars = array($strip_vars);
		$query = $_query = array();
		$args = substr($redirect, strpos($redirect, '?') + 1);
		$args = ($args) ? explode('&', $args) : array();
		$redirect = substr($redirect, 0, strpos($redirect, '?'));
		foreach ($args as $argument)
			$arguments = explode('=', $argument);
			$key = $arguments[0];
			unset($arguments[0]);
			if ($key === '')
				continue;
			$query[$key] = implode('=', $arguments);
		// Strip the vars off
		foreach ($strip_vars as $strip)
			if (isset($query[$strip]))
				unset($query[$strip]);
		// Glue the remaining parts together... already urlencoded
		foreach ($query as $key => $value)
			$_query[] = $key . '=' . $value;
		$query = implode('&', $_query);
		$redirect .= ($query) ? '?' . $query : '';
	// We need to be cautious here.
	// On some situations, the redirect path is an absolute URL, sometimes a relative path
	// For a relative path, let's prefix it with $phpbb_root_path to point to the correct location,
	// else we use the URL directly.
	$url_parts = @parse_url($redirect);
	// URL
	if ($url_parts !== false && !empty($url_parts['scheme']) && !empty($url_parts['host']))
		return str_replace('&', '&', $redirect);
	return $phpbb_root_path . str_replace('&', '&', $redirect);
* Meta refresh assignment
* Adds META template variable with meta http tag.
* @param int $time Time in seconds for meta refresh tag
* @param string $url URL to redirect to. The url will go through redirect() first before the template variable is assigned
* @param bool $disable_cd_check If true, meta_refresh() will redirect to an external domain. If false, the redirect point to the boards url if it does not match the current domain. Default is false.
function meta_refresh($time, $url, $disable_cd_check = false)
	global $template;
	$url = redirect($url, true, $disable_cd_check);
	// For XHTML compatibility we change back & to &
		'META' => '<meta http-equiv="refresh" content="' . $time . '; url=' . $url . '" />')
	return $url;
* Outputs correct status line header.
* Depending on php sapi one of the two following forms is used:
* Status: 404 Not Found
* HTTP/1.x 404 Not Found
* HTTP version is taken from HTTP_VERSION environment variable,
* and defaults to 1.0.
* Sample usage:
* send_status_line(404, 'Not Found');
* @param int $code HTTP status code
* @param string $message Message for the status code
* @return null
function send_status_line($code, $message)
	if (substr(strtolower(@php_sapi_name()), 0, 3) === 'cgi')
		// in theory, we shouldn't need that due to php doing it. Reality offers a differing opinion, though
		header("Status: $code $message", true, $code);
		if (!empty($_SERVER['SERVER_PROTOCOL']))
			$version = $_SERVER['SERVER_PROTOCOL'];
			$version = 'HTTP/1.0';
		header("$version $code $message", true, $code);
//Form validation
* Add a secret hash   for use in links/GET requests
* @param string  $link_name The name of the link; has to match the name used in check_link_hash, otherwise no restrictions apply
* @return string the hash
function generate_link_hash($link_name)
	global $user;
	if (!isset($user->data["hash_$link_name"]))
		$user->data["hash_$link_name"] = substr(sha1($user->data['user_form_salt'] . $link_name), 0, 8);
	return $user->data["hash_$link_name"];
* checks a link hash - for GET requests
* @param string $token the submitted token
* @return boolean true if all is fine
function check_link_hash($token, $link_name)
	return $token === generate_link_hash($link_name);
* Add a secret token to the form (requires the S_FORM_TOKEN template variable)
* @param string  $form_name The name of the form; has to match the name used in check_form_key, otherwise no restrictions apply
function add_form_key($form_name)
	global $config, $template, $user;
	$now = time();
	$token_sid = ($user->data['user_id'] == ANONYMOUS && !empty($config['form_token_sid_guests'])) ? $user->session_id : '';
	$token = sha1($now . $user->data['user_form_salt'] . $form_name . $token_sid);
	$s_fields = build_hidden_fields(array(
		'creation_time' => $now,
		'form_token'	=> $token,
		'S_FORM_TOKEN'	=> $s_fields,
* Check the form key. Required for all altering actions not secured by confirm_box
* @param string  $form_name The name of the form; has to match the name used in add_form_key, otherwise no restrictions apply
* @param int $timespan The maximum acceptable age for a submitted form in seconds. Defaults to the config setting.
* @param string $return_page The address for the return link
* @param bool $trigger If true, the function will triger an error when encountering an invalid form
function check_form_key($form_name, $timespan = false, $return_page = '', $trigger = false)
	if ($timespan === false)
		// we enforce a minimum value of half a minute here.
		$timespan = ($config['form_token_lifetime'] == -1) ? -1 : max(30, $config['form_token_lifetime']);
	if (isset($_POST['creation_time']) && isset($_POST['form_token']))
		$creation_time	= abs(request_var('creation_time', 0));
		$token = request_var('form_token', '');
		$diff = time() - $creation_time;
		// If creation_time and the time() now is zero we can assume it was not a human doing this (the check for if ($diff)...
		if (defined('DEBUG_TEST') || $diff && ($diff <= $timespan || $timespan === -1))
			$key = sha1($creation_time . $user->data['user_form_salt'] . $form_name . $token_sid);
			if ($key === $token)
				return true;
	if ($trigger)
		trigger_error($user->lang['FORM_INVALID'] . $return_page);
	return false;
// Message/Login boxes
* Build Confirm box
* @param boolean $check True for checking if confirmed (without any additional parameters) and false for displaying the confirm box
* @param string $title Title/Message used for confirm box.
*		message text is _CONFIRM appended to title.
*		If title cannot be found in user->lang a default one is displayed
*		If title_CONFIRM cannot be found in user->lang the text given is used.
* @param string $hidden Hidden variables
* @param string $html_body Template used for confirm box
* @param string $u_action Custom form action
function confirm_box($check, $title = '', $hidden = '', $html_body = 'confirm_body.html', $u_action = '')
	global $user, $template, $db;
	if (isset($_POST['cancel']))
		return false;
	$confirm = false;
	if (isset($_POST['confirm']))
		// language frontier
		if ($_POST['confirm'] === $user->lang['YES'])
			$confirm = true;
	if ($check && $confirm)
		$user_id = request_var('confirm_uid', 0);
		$session_id = request_var('sess', '');
		$confirm_key = request_var('confirm_key', '');
		if ($user_id != $user->data['user_id'] || $session_id != $user->session_id || !$confirm_key || !$user->data['user_last_confirm_key'] || $confirm_key != $user->data['user_last_confirm_key'])
			return false;
		// Reset user_last_confirm_key
		$sql = 'UPDATE ' . USERS_TABLE . " SET user_last_confirm_key = ''
			WHERE user_id = " . $user->data['user_id'];
		return true;
	else if ($check)
		return false;
	$s_hidden_fields = build_hidden_fields(array(
		'confirm_uid'	=> $user->data['user_id'],
		'sess'			=> $user->session_id,
		'sid'			=> $user->session_id,
	// generate activation key
	$confirm_key = gen_rand_string(10);
	if (defined('IN_ADMIN') && isset($user->data['session_admin']) && $user->data['session_admin'])
		adm_page_header((!isset($user->lang[$title])) ? $user->lang['CONFIRM'] : $user->lang[$title]);
		page_header(((!isset($user->lang[$title])) ? $user->lang['CONFIRM'] : $user->lang[$title]), false);
		'body' => $html_body)
	// If activation key already exist, we better do not re-use the key (something very strange is going on...)
	if (request_var('confirm_key', ''))
		// This should not occur, therefore we cancel the operation to safe the user
		return false;
	// re-add sid / transform & to & for user->page (user->page is always using &)
	$use_page = ($u_action) ? $phpbb_root_path . $u_action : $phpbb_root_path . str_replace('&', '&', $user->page['page']);
	$u_action = reapply_sid($use_page);
	$u_action .= ((strpos($u_action, '?') === false) ? '?' : '&') . 'confirm_key=' . $confirm_key;
		'MESSAGE_TITLE'		=> (!isset($user->lang[$title])) ? $user->lang['CONFIRM'] : $user->lang[$title],
		'MESSAGE_TEXT'		=> (!isset($user->lang[$title . '_CONFIRM'])) ? $title : $user->lang[$title . '_CONFIRM'],
		'YES_VALUE'			=> $user->lang['YES'],
		'S_CONFIRM_ACTION'	=> $u_action,
		'S_HIDDEN_FIELDS'	=> $hidden . $s_hidden_fields)
	$sql = 'UPDATE ' . USERS_TABLE . " SET user_last_confirm_key = '" . $db->sql_escape($confirm_key) . "'
		adm_page_footer();
		page_footer();
* Generate login box or verify password
function login_box($redirect = '', $l_explain = '', $l_success = '', $admin = false, $s_display = true)
	global $db, $user, $template, $auth, $phpEx, $phpbb_root_path, $config;
	if (!class_exists('phpbb_captcha_factory'))
		include($phpbb_root_path . 'includes/captcha/captcha_factory.' . $phpEx);
	$err = '';
	// Make sure user->setup() has been called
		$user->setup();
	// Print out error if user tries to authenticate as an administrator without having the privileges...
	if ($admin && !$auth->acl_get('a_'))
		// Not authd
		// anonymous/inactive users are never able to go to the ACP even if they have the relevant permissions
			add_log('admin', 'LOG_ADMIN_AUTH_FAIL');
		trigger_error('NO_AUTH_ADMIN');
	if (isset($_POST['login']))
		// Get credential
		if ($admin)
			$credential = request_var('credential', '');
			if (strspn($credential, 'abcdef0123456789') !== strlen($credential) || strlen($credential) != 32)
			$password	= request_var('password_' . $credential, '', true);
			$password	= request_var('password', '', true);
		$username	= request_var('username', '', true);
		$autologin	= (!empty($_POST['autologin'])) ? true : false;
		$viewonline = (!empty($_POST['viewonline'])) ? 0 : 1;
		$admin 		= ($admin) ? 1 : 0;
		$viewonline = ($admin) ? $user->data['session_viewonline'] : $viewonline;
		// Check if the supplied username is equal to the one stored within the database if re-authenticating
		if ($admin && utf8_clean_string($username) != utf8_clean_string($user->data['username']))
			// We log the attempt to use a different username...
			trigger_error('NO_AUTH_ADMIN_USER_DIFFER');
		// If authentication is successful we redirect user to previous page
		$result = $auth->login($username, $password, $autologin, $viewonline, $admin);
		// If admin authentication and login, we will log if it was a success or not...
		// We also break the operation on the first non-success login - it could be argued that the user already knows
		if ($admin)
			if ($result['status'] == LOGIN_SUCCESS)
				add_log('admin', 'LOG_ADMIN_AUTH_SUCCESS');
				// Only log the failed attempt if a real user tried to.
		// The result parameter is always an array, holding the relevant information...
			$redirect = request_var('redirect', "{$phpbb_root_path}index.$phpEx");
			$message = ($l_success) ? $l_success : $user->lang['LOGIN_REDIRECT'];
			$l_redirect = ($admin) ? $user->lang['PROCEED_TO_ACP'] : (($redirect === "{$phpbb_root_path}index.$phpEx" || $redirect === "index.$phpEx") ? $user->lang['RETURN_INDEX'] : $user->lang['RETURN_PAGE']);
			// append/replace SID (may change during the session for AOL users)
			$redirect = reapply_sid($redirect);
			// Special case... the user is effectively banned, but we allow founders to login
			if (defined('IN_CHECK_BAN') && $result['user_row']['user_type'] != USER_FOUNDER)
				return;
			$redirect = meta_refresh(3, $redirect);
			trigger_error($message . '<br /><br />' . sprintf($l_redirect, '<a href="' . $redirect . '">', '</a>'));
		// Something failed, determine what...
		if ($result['status'] == LOGIN_BREAK)
			trigger_error($result['error_msg']);
		// Special cases... determine
		switch ($result['status'])
			case LOGIN_ERROR_ATTEMPTS:
				$captcha = phpbb_captcha_factory::get_instance($config['captcha_plugin']);
				$captcha->init(CONFIRM_LOGIN);
				// $captcha->reset();
					'CAPTCHA_TEMPLATE'			=> $captcha->get_template(),
				$err = $user->lang[$result['error_msg']];
			break;
			case LOGIN_ERROR_PASSWORD_CONVERT:
				$err = sprintf(
					$user->lang[$result['error_msg']],
					($config['email_enable']) ? '<a href="' . append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=sendpassword') . '">' : '',
					($config['email_enable']) ? '</a>' : '',
					($config['board_contact']) ? '<a href="mailto:' . htmlspecialchars($config['board_contact']) . '">' : '',
					($config['board_contact']) ? '</a>' : ''
			break;
			// Username, password, etc...
			default:
				// Assign admin contact to some error messages
				if ($result['error_msg'] == 'LOGIN_ERROR_USERNAME' || $result['error_msg'] == 'LOGIN_ERROR_PASSWORD')
					$err = (!$config['board_contact']) ? sprintf($user->lang[$result['error_msg']], '', '') : sprintf($user->lang[$result['error_msg']], '<a href="mailto:' . htmlspecialchars($config['board_contact']) . '">', '</a>');
			break;
	// Assign credential for username/password pair
	$credential = ($admin) ? md5(unique_id()) : false;
	$s_hidden_fields = array(
	if ($redirect)
		$s_hidden_fields['redirect'] = $redirect;
	if ($admin)
		$s_hidden_fields['credential'] = $credential;
	$s_hidden_fields = build_hidden_fields($s_hidden_fields);
		'LOGIN_ERROR'		=> $err,
		'LOGIN_EXPLAIN'		=> $l_explain,
		'U_SEND_PASSWORD' 		=> ($config['email_enable']) ? append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=sendpassword') : '',
		'U_RESEND_ACTIVATION'	=> ($config['require_activation'] == USER_ACTIVATION_SELF && $config['email_enable']) ? append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=resend_act') : '',
		'U_TERMS_USE'			=> append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=terms'),
		'U_PRIVACY'				=> append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=privacy'),
		'S_DISPLAY_FULL_LOGIN'	=> ($s_display) ? true : false,
		'S_HIDDEN_FIELDS' 		=> $s_hidden_fields,
		'S_ADMIN_AUTH'			=> $admin,
		'USERNAME'				=> ($admin) ? $user->data['username'] : '',
		'USERNAME_CREDENTIAL'	=> 'username',
		'PASSWORD_CREDENTIAL'	=> ($admin) ? 'password_' . $credential : 'password',
	page_header($user->lang['LOGIN'], false);
		'body' => 'login_body.html')
	make_jumpbox(append_sid("{$phpbb_root_path}viewforum.$phpEx"));
	page_footer();
* Generate forum login box
function login_forum_box($forum_data)
	global $db, $config, $user, $template, $phpEx;
		FROM ' . FORUMS_ACCESS_TABLE . '
		WHERE forum_id = ' . $forum_data['forum_id'] . '
			AND user_id = ' . $user->data['user_id'] . "
			AND session_id = '" . $db->sql_escape($user->session_id) . "'";
	if ($row)
		return true;
	if ($password)
		// Remove expired authorised sessions
		$sql = 'SELECT f.session_id
			FROM ' . FORUMS_ACCESS_TABLE . ' f
			LEFT JOIN ' . SESSIONS_TABLE . ' s ON (f.session_id = s.session_id)
			WHERE s.session_id IS NULL';
		if ($row = $db->sql_fetchrow($result))
			$sql_in = array();
			do
				$sql_in[] = (string) $row['session_id'];
			while ($row = $db->sql_fetchrow($result));
			// Remove expired sessions
			$sql = 'DELETE FROM ' . FORUMS_ACCESS_TABLE . '
				WHERE ' . $db->sql_in_set('session_id', $sql_in);
		if (phpbb_check_hash($password, $forum_data['forum_password']))
			$sql_ary = array(
				'forum_id'		=> (int) $forum_data['forum_id'],
				'session_id'	=> (string) $user->session_id,
			$db->sql_query('INSERT INTO ' . FORUMS_ACCESS_TABLE . ' ' . $db->sql_build_array('INSERT', $sql_ary));
			return true;
		$template->assign_var('LOGIN_ERROR', $user->lang['WRONG_PASSWORD']);
		'FORUM_NAME'			=> isset($forum_data['forum_name']) ? $forum_data['forum_name'] : '',
		'S_LOGIN_ACTION'		=> build_url(array('f')),
		'S_HIDDEN_FIELDS'		=> build_hidden_fields(array('f' => $forum_data['forum_id'])))
		'body' => 'login_forum.html')
	page_footer();
// Little helpers
* Little helper for the build_hidden_fields function
function _build_hidden_fields($key, $value, $specialchar, $stripslashes)
	$hidden_fields = '';
	if (!is_array($value))
		$value = ($stripslashes) ? stripslashes($value) : $value;
		$value = ($specialchar) ? htmlspecialchars($value, ENT_COMPAT, 'UTF-8') : $value;
		$hidden_fields .= '<input type="hidden" name="' . $key . '" value="' . $value . '" />' . "\n";
		foreach ($value as $_key => $_value)
			$_key = ($stripslashes) ? stripslashes($_key) : $_key;
			$_key = ($specialchar) ? htmlspecialchars($_key, ENT_COMPAT, 'UTF-8') : $_key;
			$hidden_fields .= _build_hidden_fields($key . '[' . $_key . ']', $_value, $specialchar, $stripslashes);
	return $hidden_fields;
* Build simple hidden fields from array
* @param array $field_ary an array of values to build the hidden field from
* @param bool $specialchar if true, keys and values get specialchared
* @param bool $stripslashes if true, keys and values get stripslashed
* @return string the hidden fields
function build_hidden_fields($field_ary, $specialchar = false, $stripslashes = false)
	$s_hidden_fields = '';
	foreach ($field_ary as $name => $vars)
		$name = ($stripslashes) ? stripslashes($name) : $name;
		$name = ($specialchar) ? htmlspecialchars($name, ENT_COMPAT, 'UTF-8') : $name;
		$s_hidden_fields .= _build_hidden_fields($name, $vars, $specialchar, $stripslashes);
	return $s_hidden_fields;
* Parse cfg file
function parse_cfg_file($filename, $lines = false)
	$parsed_items = array();
	if ($lines === false)
		$lines = file($filename);
	foreach ($lines as $line)
		$line = trim($line);
		if (!$line || $line[0] == '#' || ($delim_pos = strpos($line, '=')) === false)
			continue;
		// Determine first occurrence, since in values the equal sign is allowed
		$key = strtolower(trim(substr($line, 0, $delim_pos)));
		$value = trim(substr($line, $delim_pos + 1));
		if (in_array($value, array('off', 'false', '0')))
			$value = false;
		else if (in_array($value, array('on', 'true', '1')))
			$value = true;
		else if (!trim($value))
			$value = '';
		else if (($value[0] == "'" && $value[sizeof($value) - 1] == "'") || ($value[0] == '"' && $value[sizeof($value) - 1] == '"'))
			$value = substr($value, 1, sizeof($value)-2);
		$parsed_items[$key] = $value;
	if (isset($parsed_items['inherit_from']) && isset($parsed_items['name']) && $parsed_items['inherit_from'] == $parsed_items['name'])
		unset($parsed_items['inherit_from']);
	return $parsed_items;
* Add log event
function add_log()
	global $db, $user;
	// In phpBB 3.1.x i want to have logging in a class to be able to control it
	// For now, we need a quite hakish approach to circumvent logging for some actions
	// @todo implement cleanly
	if (!empty($GLOBALS['skip_add_log']))
		return false;
	$args = func_get_args();
	$mode			= array_shift($args);
	$reportee_id	= ($mode == 'user') ? intval(array_shift($args)) : '';
	$forum_id		= ($mode == 'mod') ? intval(array_shift($args)) : '';
	$topic_id		= ($mode == 'mod') ? intval(array_shift($args)) : '';
	$action			= array_shift($args);
	$data			= (!sizeof($args)) ? '' : serialize($args);
	$sql_ary = array(
		'user_id'		=> (empty($user->data)) ? ANONYMOUS : $user->data['user_id'],
		'log_ip'		=> $user->ip,
		'log_time'		=> time(),
		'log_operation'	=> $action,
		'log_data'		=> $data,
	switch ($mode)
		case 'admin':
			$sql_ary['log_type'] = LOG_ADMIN;
		break;
		case 'mod':
			$sql_ary += array(
				'log_type'	=> LOG_MOD,
				'forum_id'	=> $forum_id,
				'topic_id'	=> $topic_id
		break;
		case 'user':
			$sql_ary += array(
				'log_type'		=> LOG_USERS,
				'reportee_id'	=> $reportee_id
		break;
		case 'critical':
			$sql_ary['log_type'] = LOG_CRITICAL;
		break;
		default:
			return false;
	$db->sql_query('INSERT INTO ' . LOG_TABLE . ' ' . $db->sql_build_array('INSERT', $sql_ary));
	return $db->sql_nextid();
* Return a nicely formatted backtrace.
* Turns the array returned by debug_backtrace() into HTML markup.
* Also filters out absolute paths to phpBB root.
* @return string	HTML markup
function get_backtrace()
	$output = '<div style="font-family: monospace;">';
	$backtrace = debug_backtrace();
	// We skip the first one, because it only shows this file/function
	unset($backtrace[0]);
	foreach ($backtrace as $trace)
		// Strip the current directory from path
		$trace['file'] = (empty($trace['file'])) ? '(not given by php)' : htmlspecialchars(phpbb_filter_root_path($trace['file']));
		$trace['line'] = (empty($trace['line'])) ? '(not given by php)' : $trace['line'];
		// Only show function arguments for include etc.
		// Other parameters may contain sensible information
		$argument = '';
		if (!empty($trace['args'][0]) && in_array($trace['function'], array('include', 'require', 'include_once', 'require_once')))
			$argument = htmlspecialchars(phpbb_filter_root_path($trace['args'][0]));
		$trace['class'] = (!isset($trace['class'])) ? '' : $trace['class'];
		$trace['type'] = (!isset($trace['type'])) ? '' : $trace['type'];
		$output .= '<br />';
		$output .= '<b>FILE:</b> ' . $trace['file'] . '<br />';
		$output .= '<b>LINE:</b> ' . ((!empty($trace['line'])) ? $trace['line'] : '') . '<br />';
		$output .= '<b>CALL:</b> ' . htmlspecialchars($trace['class'] . $trace['type'] . $trace['function']);
		$output .= '(' . (($argument !== '') ? "'$argument'" : '') . ')<br />';
	$output .= '</div>';
	return $output;
* This function returns a regular expression pattern for commonly used expressions
* Use with / as delimiter for email mode and # for url modes
* mode can be: email|bbcode_htm|url|url_inline|www_url|www_url_inline|relative_url|relative_url_inline|ipv4|ipv6
function get_preg_expression($mode)
	switch ($mode)
		case 'email':
			// Regex written by James Watts and Francisco Jose Martin Moreno
			// http://fightingforalostcause.net/misc/2006/compare-email-regex.php
			return '([\w\!\#$\%\&\'\*\+\-\/\=\?\^\`{\|\}\~]+\.)*(?:[\w\!\#$\%\'\*\+\-\/\=\?\^\`{\|\}\~]|&)+@((((([a-z0-9]{1}[a-z0-9\-]{0,62}[a-z0-9]{1})|[a-z])\.)+[a-z]{2,63})|(\d{1,3}\.){3}\d{1,3}(\:\d{1,5})?)';
		break;
		case 'bbcode_htm':
			return array(
				'#<!\-\- e \-\-><a href="mailto:(.*?)">.*?</a><!\-\- e \-\->#',
				'#<!\-\- l \-\-><a (?:class="[\w-]+" )?href="(.*?)(?:(&|\?)sid=[0-9a-f]{32})?">.*?</a><!\-\- l \-\->#',
				'#<!\-\- ([mw]) \-\-><a (?:class="[\w-]+" )?href="(.*?)">.*?</a><!\-\- \1 \-\->#',
				'#<!\-\- s(.*?) \-\-><img src="\{SMILIES_PATH\}\/.*? \/><!\-\- s\1 \-\->#',
				'#<!\-\- .*? \-\->#s',
				'#<.*?>#s',
		break;
		// Whoa these look impressive!
		// The code to generate the following two regular expressions which match valid IPv4/IPv6 addresses
		// can be found in the develop directory
		case 'ipv4':
			return '#^(?:(?:\d{1,2}|1\d\d|2[0-4]\d|25[0-5])\.){3}(?:\d{1,2}|1\d\d|2[0-4]\d|25[0-5])$#';
		break;
		case 'ipv6':
			return '#^(?:(?:(?:[\dA-F]{1,4}:){6}(?:[\dA-F]{1,4}:[\dA-F]{1,4}|(?:(?:\d{1,2}|1\d\d|2[0-4]\d|25[0-5])\.){3}(?:\d{1,2}|1\d\d|2[0-4]\d|25[0-5])))|(?:::(?:[\dA-F]{1,4}:){0,5}(?:[\dA-F]{1,4}(?::[\dA-F]{1,4})?|(?:(?:\d{1,2}|1\d\d|2[0-4]\d|25[0-5])\.){3}(?:\d{1,2}|1\d\d|2[0-4]\d|25[0-5])))|(?:(?:[\dA-F]{1,4}:):(?:[\dA-F]{1,4}:){4}(?:[\dA-F]{1,4}:[\dA-F]{1,4}|(?:(?:\d{1,2}|1\d\d|2[0-4]\d|25[0-5])\.){3}(?:\d{1,2}|1\d\d|2[0-4]\d|25[0-5])))|(?:(?:[\dA-F]{1,4}:){1,2}:(?:[\dA-F]{1,4}:){3}(?:[\dA-F]{1,4}:[\dA-F]{1,4}|(?:(?:\d{1,2}|1\d\d|2[0-4]\d|25[0-5])\.){3}(?:\d{1,2}|1\d\d|2[0-4]\d|25[0-5])))|(?:(?:[\dA-F]{1,4}:){1,3}:(?:[\dA-F]{1,4}:){2}(?:[\dA-F]{1,4}:[\dA-F]{1,4}|(?:(?:\d{1,2}|1\d\d|2[0-4]\d|25[0-5])\.){3}(?:\d{1,2}|1\d\d|2[0-4]\d|25[0-5])))|(?:(?:[\dA-F]{1,4}:){1,4}:(?:[\dA-F]{1,4}:)(?:[\dA-F]{1,4}:[\dA-F]{1,4}|(?:(?:\d{1,2}|1\d\d|2[0-4]\d|25[0-5])\.){3}(?:\d{1,2}|1\d\d|2[0-4]\d|25[0-5])))|(?:(?:[\dA-F]{1,4}:){1,5}:(?:[\dA-F]{1,4}:[\dA-F]{1,4}|(?:(?:\d{1,2}|1\d\d|2[0-4]\d|25[0-5])\.){3}(?:\d{1,2}|1\d\d|2[0-4]\d|25[0-5])))|(?:(?:[\dA-F]{1,4}:){1,6}:[\dA-F]{1,4})|(?:(?:[\dA-F]{1,4}:){1,7}:)|(?:::))$#i';
		break;
		case 'url':
		case 'url_inline':
			$inline = ($mode == 'url') ? ')' : '';
			$scheme = ($mode == 'url') ? '[a-z\d+\-.]' : '[a-z\d+]'; // avoid automatic parsing of "word" in "last word.http://..."
			// generated with regex generation file in the develop folder
			return "[a-z]$scheme*:/{2}(?:(?:[a-z0-9\-._~!$&'($inline*+,;=:@|]+|%[\dA-F]{2})+|[0-9.]+|\[[a-z0-9.]+:[a-z0-9.]+:[a-z0-9.:]+\])(?::\d*)?(?:/(?:[a-z0-9\-._~!$&'($inline*+,;=:@|]+|%[\dA-F]{2})*)*(?:\?(?:[a-z0-9\-._~!$&'($inline*+,;=:@/?|]+|%[\dA-F]{2})*)?(?:\#(?:[a-z0-9\-._~!$&'($inline*+,;=:@/?|]+|%[\dA-F]{2})*)?";
		break;
		case 'www_url':
		case 'www_url_inline':
			$inline = ($mode == 'www_url') ? ')' : '';
			return "www\.(?:[a-z0-9\-._~!$&'($inline*+,;=:@|]+|%[\dA-F]{2})+(?::\d*)?(?:/(?:[a-z0-9\-._~!$&'($inline*+,;=:@|]+|%[\dA-F]{2})*)*(?:\?(?:[a-z0-9\-._~!$&'($inline*+,;=:@/?|]+|%[\dA-F]{2})*)?(?:\#(?:[a-z0-9\-._~!$&'($inline*+,;=:@/?|]+|%[\dA-F]{2})*)?";
		break;
		case 'relative_url':
		case 'relative_url_inline':
			$inline = ($mode == 'relative_url') ? ')' : '';
			return "(?:[a-z0-9\-._~!$&'($inline*+,;=:@|]+|%[\dA-F]{2})*(?:/(?:[a-z0-9\-._~!$&'($inline*+,;=:@|]+|%[\dA-F]{2})*)*(?:\?(?:[a-z0-9\-._~!$&'($inline*+,;=:@/?|]+|%[\dA-F]{2})*)?(?:\#(?:[a-z0-9\-._~!$&'($inline*+,;=:@/?|]+|%[\dA-F]{2})*)?";
		break;
		case 'table_prefix':
			return '#^[a-zA-Z][a-zA-Z0-9_]*$#';
		break;
	return '';
* Generate regexp for naughty words censoring
* Depends on whether installed PHP version supports unicode properties
* @param string	$word			word template to be replaced
* @param bool	$use_unicode	whether or not to take advantage of PCRE supporting unicode
* @return string $preg_expr		regex to use with word censor
function get_censor_preg_expression($word, $use_unicode = true)
	static $unicode_support = null;
	// Check whether PHP version supports unicode properties
	if (is_null($unicode_support))
		$unicode_support = ((version_compare(PHP_VERSION, '5.1.0', '>=') || (version_compare(PHP_VERSION, '5.0.0-dev', '<=') && version_compare(PHP_VERSION, '4.4.0', '>='))) && @preg_match('/\p{L}/u', 'a') !== false) ? true : false;
	// Unescape the asterisk to simplify further conversions
	$word = str_replace('\*', '*', preg_quote($word, '#'));
	if ($use_unicode && $unicode_support)
		// Replace asterisk(s) inside the pattern, at the start and at the end of it with regexes
		$word = preg_replace(array('#(?<=[\p{Nd}\p{L}_])\*+(?=[\p{Nd}\p{L}_])#iu', '#^\*+#', '#\*+$#'), array('([\x20]*?|[\p{Nd}\p{L}_-]*?)', '[\p{Nd}\p{L}_-]*?', '[\p{Nd}\p{L}_-]*?'), $word);
		// Generate the final substitution
		$preg_expr = '#(?<![\p{Nd}\p{L}_-])(' . $word . ')(?![\p{Nd}\p{L}_-])#iu';
		// Replace the asterisk inside the pattern, at the start and at the end of it with regexes
		$word = preg_replace(array('#(?<=\S)\*+(?=\S)#iu', '#^\*+#', '#\*+$#'), array('(\x20*?\S*?)', '\S*?', '\S*?'), $word);
		$preg_expr = '#(?<!\S)(' . $word . ')(?!\S)#iu';
	return $preg_expr;
* Returns the first block of the specified IPv6 address and as many additional
* ones as specified in the length paramater.
* If length is zero, then an empty string is returned.
* If length is greater than 3 the complete IP will be returned
function short_ipv6($ip, $length)
	if ($length < 1)
		return '';
	// extend IPv6 addresses
	$blocks = substr_count($ip, ':') + 1;
	if ($blocks < 9)
		$ip = str_replace('::', ':' . str_repeat('0000:', 9 - $blocks), $ip);
	if ($ip[0] == ':')
		$ip = '0000' . $ip;
	if ($length < 4)
		$ip = implode(':', array_slice(explode(':', $ip), 0, 1 + $length));
	return $ip;
* Wrapper for php's checkdnsrr function.
* @param string $host	Fully-Qualified Domain Name
* @param string $type	Resource record type to lookup
*						Supported types are: MX (default), A, AAAA, NS, TXT, CNAME
*						Other types may work or may not work
* @return mixed		true if entry found,
*					false if entry not found,
*					null if this function is not supported by this environment
* Since null can also be returned, you probably want to compare the result
* with === true or === false,
* @author bantu
function phpbb_checkdnsrr($host, $type = 'MX')
	// The dot indicates to search the DNS root (helps those having DNS prefixes on the same domain)
	if (substr($host, -1) == '.')
		$host_fqdn = $host;
		$host = substr($host, 0, -1);
		$host_fqdn = $host . '.';
	// $host		has format	some.host.example.com
	// $host_fqdn	has format	some.host.example.com.
	// If we're looking for an A record we can use gethostbyname()
	if ($type == 'A' && function_exists('gethostbyname'))
		return (@gethostbyname($host_fqdn) == $host_fqdn) ? false : true;
	// checkdnsrr() is available on Windows since PHP 5.3,
	// but until 5.3.3 it only works for MX records
	// See: http://bugs.php.net/bug.php?id=51844
	// Call checkdnsrr() if
	// we're looking for an MX record or
	// we're not on Windows or
	// we're running a PHP version where #51844 has been fixed
	// checkdnsrr() supports AAAA since 5.0.0
	// checkdnsrr() supports TXT since 5.2.4
	if (
		($type == 'MX' || DIRECTORY_SEPARATOR != '\\' || version_compare(PHP_VERSION, '5.3.3', '>=')) &&
		($type != 'AAAA' || version_compare(PHP_VERSION, '5.0.0', '>=')) &&
		($type != 'TXT' || version_compare(PHP_VERSION, '5.2.4', '>=')) &&
		function_exists('checkdnsrr')
		return checkdnsrr($host_fqdn, $type);
	// dns_get_record() is available since PHP 5; since PHP 5.3 also on Windows,
	// but on Windows it does not work reliable for AAAA records before PHP 5.3.1
	// Call dns_get_record() if
	// we're not looking for an AAAA record or
	// we're running a PHP version where AAAA lookups work reliable
	if (
		($type != 'AAAA' || DIRECTORY_SEPARATOR != '\\' || version_compare(PHP_VERSION, '5.3.1', '>=')) &&
		function_exists('dns_get_record')
		// dns_get_record() expects an integer as second parameter
		// We have to convert the string $type to the corresponding integer constant.
		$type_constant = 'DNS_' . $type;
		$type_param = (defined($type_constant)) ? constant($type_constant) : DNS_ANY;
		// dns_get_record() might throw E_WARNING and return false for records that do not exist
		$resultset = @dns_get_record($host_fqdn, $type_param);
		if (empty($resultset) || !is_array($resultset))
			return false;
		else if ($type_param == DNS_ANY)
			// $resultset is a non-empty array
			return true;
		foreach ($resultset as $result)
			if (
				isset($result['host']) && $result['host'] == $host &&
				isset($result['type']) && $result['type'] == $type
				return true;
		return false;
	// If we're on Windows we can still try to call nslookup via exec() as a last resort
	if (DIRECTORY_SEPARATOR == '\\' && function_exists('exec'))
		@exec('nslookup -type=' . escapeshellarg($type) . ' ' . escapeshellarg($host_fqdn), $output);
		// If output is empty, the nslookup failed
		if (empty($output))
			return NULL;
		foreach ($output as $line)
			if (empty($line))
				continue;
			// Squash tabs and multiple whitespaces to a single whitespace.
			$line = preg_replace('/\s+/', ' ', $line);
			switch ($type)
				case 'MX':
					if (stripos($line, "$host MX") === 0)
						return true;
				break;
				case 'NS':
					if (stripos($line, "$host nameserver") === 0)
						return true;
				break;
				case 'TXT':
					if (stripos($line, "$host text") === 0)
						return true;
				break;
				case 'CNAME':
					if (stripos($line, "$host canonical name") === 0)
						return true;
				break;
				default:
				case 'AAAA':
					// AAAA records returned by nslookup on Windows XP/2003 have this format.
					// Later Windows versions use the A record format below for AAAA records.
					if (stripos($line, "$host AAAA IPv6 address") === 0)
						return true;
				// No break
				case 'A':
					if (!empty($host_matches))
						// Second line
						if (stripos($line, "Address: ") === 0)
							return true;
							$host_matches = false;
					else if (stripos($line, "Name: $host") === 0)
						// First line
						$host_matches = true;
				break;
		return false;
	return NULL;
// Handler, header and footer
* Error and message handler, call with trigger_error if reqd
function msg_handler($errno, $msg_text, $errfile, $errline)
	global $cache, $db, $auth, $template, $config, $user;
	global $phpEx, $phpbb_root_path, $msg_title, $msg_long_text;
	// Do not display notices if we suppress them via @
	if (error_reporting() == 0 && $errno != E_USER_ERROR && $errno != E_USER_WARNING && $errno != E_USER_NOTICE)
		return;
	// Message handler is stripping text. In case we need it, we are possible to define long text...
	if (isset($msg_long_text) && $msg_long_text && !$msg_text)
		$msg_text = $msg_long_text;
	if (!defined('E_DEPRECATED'))
		define('E_DEPRECATED', 8192);
	switch ($errno)
		case E_NOTICE:
		case E_WARNING:
			// Check the error reporting level and return if the error level does not match
			// If DEBUG is defined the default level is E_ALL
			if (($errno & ((defined('DEBUG')) ? E_ALL : error_reporting())) == 0)
				return;
			if (strpos($errfile, 'cache') === false && strpos($errfile, 'template.') === false)
				$errfile = phpbb_filter_root_path($errfile);
				$msg_text = phpbb_filter_root_path($msg_text);
				$error_name = ($errno === E_WARNING) ? 'PHP Warning' : 'PHP Notice';
				echo '<b>[phpBB Debug] ' . $error_name . '</b>: in file <b>' . $errfile . '</b> on line <b>' . $errline . '</b>: <b>' . $msg_text . '</b><br />' . "\n";
				// we are writing an image - the user won't see the debug, so let's place it in the log
				if (defined('IMAGE_OUTPUT') || defined('IN_CRON'))
					add_log('critical', 'LOG_IMAGE_GENERATION_ERROR', $errfile, $errline, $msg_text);
				// echo '<br /><br />BACKTRACE<br />' . get_backtrace() . '<br />' . "\n";
			return;
		break;
		case E_USER_ERROR:
			if (!empty($user) && !empty($user->lang))
				$msg_text = (!empty($user->lang[$msg_text])) ? $user->lang[$msg_text] : $msg_text;
				$msg_title = (!isset($msg_title)) ? $user->lang['GENERAL_ERROR'] : ((!empty($user->lang[$msg_title])) ? $user->lang[$msg_title] : $msg_title);
				$l_return_index = sprintf($user->lang['RETURN_INDEX'], '<a href="' . $phpbb_root_path . '">', '</a>');
				$l_notify = '';
				if (!empty($config['board_contact']))
					$l_notify = '<p>' . sprintf($user->lang['NOTIFY_ADMIN_EMAIL'], $config['board_contact']) . '</p>';
				$msg_title = 'General Error';
				$l_return_index = '<a href="' . $phpbb_root_path . '">Return to index page</a>';
				$l_notify = '';
					$l_notify = '<p>Please notify the board administrator or webmaster: <a href="mailto:' . $config['board_contact'] . '">' . $config['board_contact'] . '</a></p>';
			$log_text = $msg_text;
			$backtrace = get_backtrace();
			if ($backtrace)
				$log_text .= '<br /><br />BACKTRACE<br />' . $backtrace;
			if (defined('IN_INSTALL') || defined('DEBUG_EXTRA') || isset($auth) && $auth->acl_get('a_'))
				$msg_text = $log_text;
			if ((defined('DEBUG') || defined('IN_CRON') || defined('IMAGE_OUTPUT')) && isset($db))
				// let's avoid loops
				add_log('critical', 'LOG_GENERAL_ERROR', $msg_title, $log_text);
			// Do not send 200 OK, but service unavailable on errors
			send_status_line(503, 'Service Unavailable');
			// Try to not call the adm page data...
			echo '<html xmlns="http://www.w3.org/1999/xhtml" dir="ltr">';
			echo '<head>';
			echo '<title>' . $msg_title . '</title>';
			echo '<style type="text/css">' . "\n" . '/* <![CDATA[ */' . "\n";
			echo '* { margin: 0; padding: 0; } html { font-size: 100%; height: 100%; margin-bottom: 1px; background-color: #E4EDF0; } body { font-family: "Lucida Grande", Verdana, Helvetica, Arial, sans-serif; color: #536482; background: #E4EDF0; font-size: 62.5%; margin: 0; } ';
			echo 'a:link, a:active, a:visited { color: #006699; text-decoration: none; } a:hover { color: #DD6900; text-decoration: underline; } ';
			echo '#wrap { padding: 0 20px 15px 20px; min-width: 615px; } #page-header { text-align: right; height: 40px; } #page-footer { clear: both; font-size: 1em; text-align: center; } ';
			echo '.panel { margin: 4px 0; background-color: #FFFFFF; border: solid 1px  #A9B8C2; } ';
			echo '#errorpage #page-header a { font-weight: bold; line-height: 6em; } #errorpage #content { padding: 10px; } #errorpage #content h1 { line-height: 1.2em; margin-bottom: 0; color: #DF075C; } ';
			echo '#errorpage #content div { margin-top: 20px; margin-bottom: 5px; border-bottom: 1px solid #CCCCCC; padding-bottom: 5px; color: #333333; font: bold 1.2em "Lucida Grande", Arial, Helvetica, sans-serif; text-decoration: none; line-height: 120%; text-align: left; } ';
			echo "\n" . '/* ]]> */' . "\n";
			echo '</style>';
			echo '</head>';
			echo '<body id="errorpage">';
			echo '<div id="wrap">';
			echo '	<div id="page-header">';
			echo '		' . $l_return_index;
			echo '	</div>';
			echo '	<div id="acp">';
			echo '	<div class="panel">';
			echo '		<div id="content">';
			echo '			<h1>' . $msg_title . '</h1>';
			echo '			<div>' . $msg_text . '</div>';
			echo $l_notify;
			echo '		</div>';
			echo '	</div>';
			echo '	</div>';
			echo '	<div id="page-footer">';
			echo '		Powered by <a href="https://www.phpbb.com/">phpBB</a>&reg; Forum Software &copy; phpBB Group';
			echo '	</div>';
			echo '</div>';
			echo '</body>';
			echo '</html>';
			exit_handler();
			// On a fatal error (and E_USER_ERROR *is* fatal) we never want other scripts to continue and force an exit here.
			exit;
		break;
		case E_USER_WARNING:
		case E_USER_NOTICE:
			define('IN_ERROR_HANDLER', true);
			if (empty($user->data))
				$user->session_begin();
			// We re-init the auth array to get correct results on login/logout
			$auth->acl($user->data);
				$user->setup();
			if ($msg_text == 'ERROR_NO_ATTACHMENT' || $msg_text == 'NO_FORUM' || $msg_text == 'NO_TOPIC' || $msg_text == 'NO_USER')
			$msg_title = (!isset($msg_title)) ? $user->lang['INFORMATION'] : ((!empty($user->lang[$msg_title])) ? $user->lang[$msg_title] : $msg_title);
			if (!defined('HEADER_INC'))
					adm_page_header($msg_title);
					page_header($msg_title, false);
				'body' => 'message_body.html')
				'MESSAGE_TITLE'		=> $msg_title,
				'MESSAGE_TEXT'		=> $msg_text,
				'S_USER_WARNING'	=> ($errno == E_USER_WARNING) ? true : false,
				'S_USER_NOTICE'		=> ($errno == E_USER_NOTICE) ? true : false)
			// We do not want the cron script to be called on error messages
			define('IN_CRON', true);
				adm_page_footer();
				page_footer();
			exit_handler();
		break;
		// PHP4 compatibility
		case E_DEPRECATED:
			return true;
		break;
	// If we notice an error not handled here we pass this back to PHP by returning false
	// This may not work for all php versions
	return false;
* Removes absolute path to phpBB root directory from error messages
* and converts backslashes to forward slashes.
* @param string $errfile	Absolute file path
*							(e.g. /var/www/phpbb3/phpBB/includes/functions.php)
*							Please note that if $errfile is outside of the phpBB root,
*							the root path will not be found and can not be filtered.
* @return string			Relative file path
*							(e.g. /includes/functions.php)
function phpbb_filter_root_path($errfile)
	static $root_path;
	if (empty($root_path))
		$root_path = phpbb_realpath(dirname(__FILE__) . '/../');
	return str_replace(array($root_path, '\\'), array('[ROOT]', '/'), $errfile);
* Queries the session table to get information about online guests
* @param int $item_id Limits the search to the item with this id
* @param string $item The name of the item which is stored in the session table as session_{$item}_id
* @return int The number of active distinct guest sessions
function obtain_guest_count($item_id = 0, $item = 'forum')
	global $db, $config;
	if ($item_id)
		$reading_sql = ' AND s.session_' . $item . '_id = ' . (int) $item_id;
		$reading_sql = '';
	$time = (time() - (intval($config['load_online_time']) * 60));
	// Get number of online guests
	if ($db->sql_layer === 'sqlite')
		$sql = 'SELECT COUNT(session_ip) as num_guests
			FROM (
				SELECT DISTINCT s.session_ip
				FROM ' . SESSIONS_TABLE . ' s
				WHERE s.session_user_id = ' . ANONYMOUS . '
					AND s.session_time >= ' . ($time - ((int) ($time % 60))) .
				$reading_sql .
		$sql = 'SELECT COUNT(DISTINCT s.session_ip) as num_guests
			$reading_sql;
	$guests_online = (int) $db->sql_fetchfield('num_guests');
	$db->sql_freeresult($result);
	return $guests_online;
* Queries the session table to get information about online users
* @return array An array containing the ids of online, hidden and visible users, as well as statistical info
function obtain_users_online($item_id = 0, $item = 'forum')
	global $db, $config, $user;
	$reading_sql = '';
	if ($item_id !== 0)
	$online_users = array(
		'online_users'			=> array(),
		'hidden_users'			=> array(),
		'total_online'			=> 0,
		'visible_online'		=> 0,
		'hidden_online'			=> 0,
		'guests_online'			=> 0,
	if ($config['load_online_guests'])
		$online_users['guests_online'] = obtain_guest_count($item_id, $item);
	// a little discrete magic to cache this for 30 seconds
	$sql = 'SELECT s.session_user_id, s.session_ip, s.session_viewonline
		WHERE s.session_time >= ' . ($time - ((int) ($time % 30))) .
			$reading_sql .
		' AND s.session_user_id <> ' . ANONYMOUS;
		// Skip multiple sessions for one user
		if (!isset($online_users['online_users'][$row['session_user_id']]))
			$online_users['online_users'][$row['session_user_id']] = (int) $row['session_user_id'];
			if ($row['session_viewonline'])
				$online_users['visible_online']++;
				$online_users['hidden_users'][$row['session_user_id']] = (int) $row['session_user_id'];
				$online_users['hidden_online']++;
	$online_users['total_online'] = $online_users['guests_online'] + $online_users['visible_online'] + $online_users['hidden_online'];
	return $online_users;
* Uses the result of obtain_users_online to generate a localized, readable representation.
* @param mixed $online_users result of obtain_users_online - array with user_id lists for total, hidden and visible users, and statistics
* @param int $item_id Indicate that the data is limited to one item and not global
* @return array An array containing the string for output to the template
function obtain_users_online_string($online_users, $item_id = 0, $item = 'forum')
	global $config, $db, $user, $auth;
	$user_online_link = $online_userlist = '';
	// Need caps version of $item for language-strings
	$item_caps = strtoupper($item);
	if (sizeof($online_users['online_users']))
		$sql = 'SELECT username, username_clean, user_id, user_type, user_allow_viewonline, user_colour
				FROM ' . USERS_TABLE . '
				WHERE ' . $db->sql_in_set('user_id', $online_users['online_users']) . '
				ORDER BY username_clean ASC';
			// User is logged in and therefore not a guest
			if ($row['user_id'] != ANONYMOUS)
				if (isset($online_users['hidden_users'][$row['user_id']]))
					$row['username'] = '<em>' . $row['username'] . '</em>';
				if (!isset($online_users['hidden_users'][$row['user_id']]) || $auth->acl_get('u_viewonline'))
					$user_online_link = get_username_string(($row['user_type'] <> USER_IGNORE) ? 'full' : 'no_profile', $row['user_id'], $row['username'], $row['user_colour']);
					$online_userlist .= ($online_userlist != '') ? ', ' . $user_online_link : $user_online_link;
	if (!$online_userlist)
		$online_userlist = $user->lang['NO_ONLINE_USERS'];
	if ($item_id === 0)
		$online_userlist = $user->lang['REGISTERED_USERS'] . ' ' . $online_userlist;
	else if ($config['load_online_guests'])
		$l_online = ($online_users['guests_online'] === 1) ? $user->lang['BROWSING_' . $item_caps . '_GUEST'] : $user->lang['BROWSING_' . $item_caps . '_GUESTS'];
		$online_userlist = sprintf($l_online, $online_userlist, $online_users['guests_online']);
		$online_userlist = sprintf($user->lang['BROWSING_' . $item_caps], $online_userlist);
	// Build online listing
	$vars_online = array(
		'ONLINE'	=> array('total_online', 'l_t_user_s', 0),
		'REG'		=> array('visible_online', 'l_r_user_s', !$config['load_online_guests']),
		'HIDDEN'	=> array('hidden_online', 'l_h_user_s', $config['load_online_guests']),
		'GUEST'		=> array('guests_online', 'l_g_user_s', 0)
	foreach ($vars_online as $l_prefix => $var_ary)
		if ($var_ary[2])
			$l_suffix = '_AND';
			$l_suffix = '';
		switch ($online_users[$var_ary[0]])
			case 0:
				${$var_ary[1]} = $user->lang[$l_prefix . '_USERS_ZERO_TOTAL' . $l_suffix];
			break;
			case 1:
				${$var_ary[1]} = $user->lang[$l_prefix . '_USER_TOTAL' . $l_suffix];
			break;
			default:
				${$var_ary[1]} = $user->lang[$l_prefix . '_USERS_TOTAL' . $l_suffix];
			break;
	unset($vars_online);
	$l_online_users = sprintf($l_t_user_s, $online_users['total_online']);
	$l_online_users .= sprintf($l_r_user_s, $online_users['visible_online']);
	$l_online_users .= sprintf($l_h_user_s, $online_users['hidden_online']);
		$l_online_users .= sprintf($l_g_user_s, $online_users['guests_online']);
	return array(
		'online_userlist'	=> $online_userlist,
		'l_online_users'	=> $l_online_users,
* Get option bitfield from custom data
* @param int	$bit		The bit/value to get
* @param int	$data		Current bitfield to check
* @return bool	Returns true if value of constant is set in bitfield, else false
function phpbb_optionget($bit, $data)
	return ($data & 1 << (int) $bit) ? true : false;
* Set option bitfield
* @param int	$bit		The bit/value to set/unset
* @param bool	$set		True if option should be set, false if option should be unset.
* @param int	$data		Current bitfield to change
* @return int	The new bitfield
function phpbb_optionset($bit, $set, $data)
	if ($set && !($data & 1 << $bit))
		$data += 1 << $bit;
	else if (!$set && ($data & 1 << $bit))
		$data -= 1 << $bit;
	return $data;
* Login using http authenticate.
* @param array	$param		Parameter array, see $param_defaults array.
* @return null
function phpbb_http_login($param)
	global $auth, $user;
	global $config;
	$param_defaults = array(
		'auth_message'	=> '',
		'autologin'		=> false,
		'viewonline'	=> true,
		'admin'			=> false,
	// Overwrite default values with passed values
	$param = array_merge($param_defaults, $param);
	// User is already logged in
	// We will not overwrite his session
	if (!empty($user->data['is_registered']))
		return;
	// $_SERVER keys to check
	$username_keys = array(
		'PHP_AUTH_USER',
		'Authorization',
		'REMOTE_USER', 'REDIRECT_REMOTE_USER',
		'HTTP_AUTHORIZATION', 'REDIRECT_HTTP_AUTHORIZATION',
		'REMOTE_AUTHORIZATION', 'REDIRECT_REMOTE_AUTHORIZATION',
		'AUTH_USER',
	$password_keys = array(
		'PHP_AUTH_PW',
		'REMOTE_PASSWORD',
		'AUTH_PASSWORD',
	$username = null;
	foreach ($username_keys as $k)
		if (isset($_SERVER[$k]))
			$username = $_SERVER[$k];
			break;
	$password = null;
	foreach ($password_keys as $k)
			$password = $_SERVER[$k];
			break;
	// Decode encoded information (IIS, CGI, FastCGI etc.)
	if (!is_null($username) && is_null($password) && strpos($username, 'Basic ') === 0)
		list($username, $password) = explode(':', base64_decode(substr($username, 6)), 2);
	if (!is_null($username) && !is_null($password))
		set_var($username, $username, 'string', true);
		set_var($password, $password, 'string', true);
		$auth_result = $auth->login($username, $password, $param['autologin'], $param['viewonline'], $param['admin']);
		if ($auth_result['status'] == LOGIN_SUCCESS)
			return;
		else if ($auth_result['status'] == LOGIN_ERROR_ATTEMPTS)
			send_status_line(401, 'Unauthorized');
			trigger_error('NOT_AUTHORISED');
	// Prepend sitename to auth_message
	$param['auth_message'] = ($param['auth_message'] === '') ? $config['sitename'] : $config['sitename'] . ' - ' . $param['auth_message'];
	// We should probably filter out non-ASCII characters - RFC2616
	$param['auth_message'] = preg_replace('/[\x80-\xFF]/', '?', $param['auth_message']);
	header('WWW-Authenticate: Basic realm="' . $param['auth_message'] . '"');
* Generate page header
function page_header($page_title = '', $display_online_list = true, $item_id = 0, $item = 'forum')
	global $db, $config, $template, $SID, $_SID, $_EXTRA_URL, $user, $auth, $phpEx, $phpbb_root_path;
	if (defined('HEADER_INC'))
		return;
	define('HEADER_INC', true);
	// gzip_compression
	if ($config['gzip_compress'])
		// to avoid partially compressed output resulting in blank pages in
		// the browser or error messages, compression is disabled in a few cases:
		// 1) if headers have already been sent, this indicates plaintext output
		//    has been started so further content must not be compressed
		// 2) the length of the current output buffer is non-zero. This means
		//    there is already some uncompressed content in this output buffer
		//    so further output must not be compressed
		// 3) if more than one level of output buffering is used because we
		//    cannot test all output buffer level content lengths. One level
		//    could be caused by php.ini output_buffering. Anything
		//    beyond that is manual, so the code wrapping phpBB in output buffering
		//    can easily compress the output itself.
		if (@extension_loaded('zlib') && !headers_sent() && ob_get_level() <= 1 && ob_get_length() == 0)
			ob_start('ob_gzhandler');
	// Generate logged in/logged out status
	if ($user->data['user_id'] != ANONYMOUS)
		$u_login_logout = append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=logout', true, $user->session_id);
		$l_login_logout = sprintf($user->lang['LOGOUT_USER'], $user->data['username']);
		$u_login_logout = append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=login');
		$l_login_logout = $user->lang['LOGIN'];
	// Last visit date/time
	$s_last_visit = ($user->data['user_id'] != ANONYMOUS) ? $user->format_date($user->data['session_last_visit']) : '';
	// Get users online list ... if required
	$l_online_users = $online_userlist = $l_online_record = $l_online_time = '';
	if ($config['load_online'] && $config['load_online_time'] && $display_online_list)
		* Load online data:
		* For obtaining another session column use $item and $item_id in the function-parameter, whereby the column is session_{$item}_id.
		$item_id = max($item_id, 0);
		$online_users = obtain_users_online($item_id, $item);
		$user_online_strings = obtain_users_online_string($online_users, $item_id, $item);
		$l_online_users = $user_online_strings['l_online_users'];
		$online_userlist = $user_online_strings['online_userlist'];
		$total_online_users = $online_users['total_online'];
		if ($total_online_users > $config['record_online_users'])
			set_config('record_online_users', $total_online_users, true);
			set_config('record_online_date', time(), true);
		$l_online_record = sprintf($user->lang['RECORD_ONLINE_USERS'], $config['record_online_users'], $user->format_date($config['record_online_date'], false, true));
		$l_online_time = ($config['load_online_time'] == 1) ? 'VIEW_ONLINE_TIME' : 'VIEW_ONLINE_TIMES';
		$l_online_time = sprintf($user->lang[$l_online_time], $config['load_online_time']);
	$l_privmsgs_text = $l_privmsgs_text_unread = '';
	$s_privmsg_new = false;
	// Obtain number of new private messages if user is logged in
		if ($user->data['user_new_privmsg'])
			$l_message_new = ($user->data['user_new_privmsg'] == 1) ? $user->lang['NEW_PM'] : $user->lang['NEW_PMS'];
			$l_privmsgs_text = sprintf($l_message_new, $user->data['user_new_privmsg']);
			if (!$user->data['user_last_privmsg'] || $user->data['user_last_privmsg'] > $user->data['session_last_visit'])
				$sql = 'UPDATE ' . USERS_TABLE . '
					SET user_last_privmsg = ' . $user->data['session_last_visit'] . '
					WHERE user_id = ' . $user->data['user_id'];
				$s_privmsg_new = true;
			$l_privmsgs_text = $user->lang['NO_NEW_PM'];
		if ($user->data['user_unread_privmsg'] && $user->data['user_unread_privmsg'] != $user->data['user_new_privmsg'])
			$l_message_unread = ($user->data['user_unread_privmsg'] == 1) ? $user->lang['UNREAD_PM'] : $user->lang['UNREAD_PMS'];
			$l_privmsgs_text_unread = sprintf($l_message_unread, $user->data['user_unread_privmsg']);
	$forum_id = request_var('f', 0);
	$topic_id = request_var('t', 0);
	$s_feed_news = false;
	// Get option for news
	if ($config['feed_enable'])
		$sql = 'SELECT forum_id
			FROM ' . FORUMS_TABLE . '
			WHERE ' . $db->sql_bit_and('forum_options', FORUM_OPTION_FEED_NEWS, '<> 0');
		$result = $db->sql_query_limit($sql, 1, 0, 600);
		$s_feed_news = (int) $db->sql_fetchfield('forum_id');
	// Determine board url - we may need it later
	$board_url = generate_board_url() . '/';
	$web_path = (defined('PHPBB_USE_BOARD_URL_PATH') && PHPBB_USE_BOARD_URL_PATH) ? $board_url : $phpbb_root_path;
	// Which timezone?
	$tz = ($user->data['user_id'] != ANONYMOUS) ? strval(doubleval($user->data['user_timezone'])) : strval(doubleval($config['board_timezone']));
	// Send a proper content-language to the output
	$user_lang = $user->lang['USER_LANG'];
	if (strpos($user_lang, '-x-') !== false)
		$user_lang = substr($user_lang, 0, strpos($user_lang, '-x-'));
	$s_search_hidden_fields = array();
	if ($_SID)
		$s_search_hidden_fields['sid'] = $_SID;
	if (!empty($_EXTRA_URL))
		foreach ($_EXTRA_URL as $url_param)
			$url_param = explode('=', $url_param, 2);
			$s_search_hidden_fields[$url_param[0]] = $url_param[1];
        	$user->add_lang('mods/portal');
	// The following assigns all _common_ variables that may be used at any point in a template.
	$template->assign_vars(array(
		'SITENAME'						=> $config['sitename'],
		'SITE_DESCRIPTION'				=> $config['site_desc'],
		'PAGE_TITLE'					=> $page_title,
		'SCRIPT_NAME'					=> str_replace('.' . $phpEx, '', $user->page['page_name']),
		'LAST_VISIT_DATE'				=> sprintf($user->lang['YOU_LAST_VISIT'], $s_last_visit),
		'LAST_VISIT_YOU'				=> $s_last_visit,
		'CURRENT_TIME'					=> sprintf($user->lang['CURRENT_TIME'], $user->format_date(time(), false, true)),
		'TOTAL_USERS_ONLINE'			=> $l_online_users,
		'LOGGED_IN_USER_LIST'			=> $online_userlist,
		'RECORD_USERS'					=> $l_online_record,
		'PRIVATE_MESSAGE_INFO'			=> $l_privmsgs_text,
		'PRIVATE_MESSAGE_INFO_UNREAD'	=> $l_privmsgs_text_unread,
		'S_USER_NEW_PRIVMSG'			=> $user->data['user_new_privmsg'],
		'S_USER_UNREAD_PRIVMSG'			=> $user->data['user_unread_privmsg'],
		'S_USER_NEW'					=> $user->data['user_new'],
		'SID'				=> $SID,
		'_SID'				=> $_SID,
		'SESSION_ID'		=> $user->session_id,
		'ROOT_PATH'			=> $phpbb_root_path,
		'BOARD_URL'			=> $board_url,
		'L_LOGIN_LOGOUT'	=> $l_login_logout,
		'L_INDEX'			=> $user->lang['FORUM_INDEX'],
		'L_ONLINE_EXPLAIN'	=> $l_online_time,
		'U_PORTAL'				=> (isset($config['board3_enable']) && $config['board3_enable'] && $auth->acl_get('u_view_portal')) ? append_sid("{$phpbb_root_path}portal.$phpEx") : '',
		'U_PRIVATEMSGS'			=> append_sid("{$phpbb_root_path}ucp.$phpEx", 'i=pm&folder=inbox'),
		'U_RETURN_INBOX'		=> append_sid("{$phpbb_root_path}ucp.$phpEx", 'i=pm&folder=inbox'),
		'U_POPUP_PM'			=> append_sid("{$phpbb_root_path}ucp.$phpEx", 'i=pm&mode=popup'),
		'UA_POPUP_PM'			=> addslashes(append_sid("{$phpbb_root_path}ucp.$phpEx", 'i=pm&mode=popup')),
		'U_MEMBERLIST'			=> append_sid("{$phpbb_root_path}memberlist.$phpEx"),
		'U_VIEWONLINE'			=> ($auth->acl_gets('u_viewprofile', 'a_user', 'a_useradd', 'a_userdel')) ? append_sid("{$phpbb_root_path}viewonline.$phpEx") : '',
		'U_LOGIN_LOGOUT'		=> $u_login_logout,
		'U_INDEX'				=> append_sid("{$phpbb_root_path}index.$phpEx"),
		'U_SEARCH'				=> append_sid("{$phpbb_root_path}search.$phpEx"),
		'U_REGISTER'			=> append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=register'),
		'U_PROFILE'				=> append_sid("{$phpbb_root_path}ucp.$phpEx"),
		'U_MODCP'				=> append_sid("{$phpbb_root_path}mcp.$phpEx", false, true, $user->session_id),
		'U_FAQ'					=> append_sid("{$phpbb_root_path}faq.$phpEx"),
		'U_SEARCH_SELF'			=> append_sid("{$phpbb_root_path}search.$phpEx", 'search_id=egosearch'),
		'U_SEARCH_NEW'			=> append_sid("{$phpbb_root_path}search.$phpEx", 'search_id=newposts'),
		'U_SEARCH_UNANSWERED'	=> append_sid("{$phpbb_root_path}search.$phpEx", 'search_id=unanswered'),
		'U_SEARCH_UNREAD'		=> append_sid("{$phpbb_root_path}search.$phpEx", 'search_id=unreadposts'),
		'U_SEARCH_ACTIVE_TOPICS'=> append_sid("{$phpbb_root_path}search.$phpEx", 'search_id=active_topics'),
		'U_DELETE_COOKIES'		=> append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=delete_cookies'),
		'U_TEAM'				=> ($user->data['user_id'] != ANONYMOUS && !$auth->acl_get('u_viewprofile')) ? '' : append_sid("{$phpbb_root_path}memberlist.$phpEx", 'mode=leaders'),
		'U_RESTORE_PERMISSIONS'	=> ($user->data['user_perm_from'] && $auth->acl_get('a_switchperm')) ? append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=restore_perm') : '',
		'U_FEED'				=> generate_board_url() . "/feed.$phpEx",
		'S_USER_LOGGED_IN'		=> ($user->data['user_id'] != ANONYMOUS) ? true : false,
		'S_AUTOLOGIN_ENABLED'	=> ($config['allow_autologin']) ? true : false,
		'S_BOARD_DISABLED'		=> ($config['board_disable']) ? true : false,
		'S_REGISTERED_USER'		=> (!empty($user->data['is_registered'])) ? true : false,
		'S_IS_BOT'				=> (!empty($user->data['is_bot'])) ? true : false,
		'S_USER_PM_POPUP'		=> $user->optionget('popuppm'),
		'S_USER_LANG'			=> $user_lang,
		'S_USER_BROWSER'		=> (isset($user->data['session_browser'])) ? $user->data['session_browser'] : $user->lang['UNKNOWN_BROWSER'],
		'S_USERNAME'			=> $user->data['username'],
		'S_CONTENT_DIRECTION'	=> $user->lang['DIRECTION'],
		'S_CONTENT_FLOW_BEGIN'	=> ($user->lang['DIRECTION'] == 'ltr') ? 'left' : 'right',
		'S_CONTENT_FLOW_END'	=> ($user->lang['DIRECTION'] == 'ltr') ? 'right' : 'left',
		'S_CONTENT_ENCODING'	=> 'UTF-8',
		'S_TIMEZONE'			=> ($user->data['user_dst'] || ($user->data['user_id'] == ANONYMOUS && $config['board_dst'])) ? sprintf($user->lang['ALL_TIMES'], $user->lang['tz'][$tz], $user->lang['tz']['dst']) : sprintf($user->lang['ALL_TIMES'], $user->lang['tz'][$tz], ''),
		'S_DISPLAY_ONLINE_LIST'	=> ($l_online_time) ? 1 : 0,
		'S_DISPLAY_SEARCH'		=> (!$config['load_search']) ? 0 : (isset($auth) ? ($auth->acl_get('u_search') && $auth->acl_getf_global('f_search')) : 1),
		'S_DISPLAY_PM'			=> ($config['allow_privmsg'] && !empty($user->data['is_registered']) && ($auth->acl_get('u_readpm') || $auth->acl_get('u_sendpm'))) ? true : false,
		'S_DISPLAY_MEMBERLIST'	=> (isset($auth)) ? $auth->acl_get('u_viewprofile') : 0,
		'S_NEW_PM'				=> ($s_privmsg_new) ? 1 : 0,
		'S_REGISTER_ENABLED'	=> ($config['require_activation'] != USER_ACTIVATION_DISABLE) ? true : false,
		'S_FORUM_ID'			=> $forum_id,
		'S_TOPIC_ID'			=> $topic_id,
		'S_LOGIN_ACTION'		=> ((!defined('ADMIN_START')) ? append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=login') : append_sid("index.$phpEx", false, true, $user->session_id)),
		'S_LOGIN_REDIRECT'		=> build_hidden_fields(array('redirect' => build_url())),
		'S_ENABLE_FEEDS'			=> ($config['feed_enable']) ? true : false,
		'S_ENABLE_FEEDS_OVERALL'	=> ($config['feed_overall']) ? true : false,
		'S_ENABLE_FEEDS_FORUMS'		=> ($config['feed_overall_forums']) ? true : false,
		'S_ENABLE_FEEDS_TOPICS'		=> ($config['feed_topics_new']) ? true : false,
		'S_ENABLE_FEEDS_TOPICS_ACTIVE'	=> ($config['feed_topics_active']) ? true : false,
		'S_ENABLE_FEEDS_NEWS'		=> ($s_feed_news) ? true : false,
		'S_LOAD_UNREADS'			=> ($config['load_unreads_search'] && ($config['load_anon_lastread'] || $user->data['is_registered'])) ? true : false,
		'S_SEARCH_HIDDEN_FIELDS'	=> build_hidden_fields($s_search_hidden_fields),
		'T_THEME_PATH'			=> "{$web_path}styles/" . rawurlencode($user->theme['theme_path']) . '/theme',
		'T_TEMPLATE_PATH'		=> "{$web_path}styles/" . rawurlencode($user->theme['template_path']) . '/template',
		'T_SUPER_TEMPLATE_PATH'	=> (isset($user->theme['template_inherit_path']) && $user->theme['template_inherit_path']) ? "{$web_path}styles/" . rawurlencode($user->theme['template_inherit_path']) . '/template' : "{$web_path}styles/" . rawurlencode($user->theme['template_path']) . '/template',
		'T_IMAGESET_PATH'		=> "{$web_path}styles/" . rawurlencode($user->theme['imageset_path']) . '/imageset',
		'T_IMAGESET_LANG_PATH'	=> "{$web_path}styles/" . rawurlencode($user->theme['imageset_path']) . '/imageset/' . $user->lang_name,
		'T_IMAGES_PATH'			=> "{$web_path}images/",
		'T_SMILIES_PATH'		=> "{$web_path}{$config['smilies_path']}/",
		'T_AVATAR_PATH'			=> "{$web_path}{$config['avatar_path']}/",
		'T_AVATAR_GALLERY_PATH'	=> "{$web_path}{$config['avatar_gallery_path']}/",
		'T_ICONS_PATH'			=> "{$web_path}{$config['icons_path']}/",
		'T_RANKS_PATH'			=> "{$web_path}{$config['ranks_path']}/",
		'T_UPLOAD_PATH'			=> "{$web_path}{$config['upload_path']}/",
		'T_STYLESHEET_LINK'		=> (!$user->theme['theme_storedb']) ? "{$web_path}styles/" . rawurlencode($user->theme['theme_path']) . '/theme/stylesheet.css' : append_sid("{$phpbb_root_path}style.$phpEx", 'id=' . $user->theme['style_id'] . '&lang=' . $user->lang_name),
		'T_STYLESHEET_NAME'		=> $user->theme['theme_name'],
		'T_THEME_NAME'			=> rawurlencode($user->theme['theme_path']),
		'T_TEMPLATE_NAME'		=> rawurlencode($user->theme['template_path']),
		'T_SUPER_TEMPLATE_NAME'	=> rawurlencode((isset($user->theme['template_inherit_path']) && $user->theme['template_inherit_path']) ? $user->theme['template_inherit_path'] : $user->theme['template_path']),
		'T_IMAGESET_NAME'		=> rawurlencode($user->theme['imageset_path']),
		'T_IMAGESET_LANG_NAME'	=> $user->data['user_lang'],
		'T_IMAGES'				=> 'images',
		'T_SMILIES'				=> $config['smilies_path'],
		'T_AVATAR'				=> $config['avatar_path'],
		'T_AVATAR_GALLERY'		=> $config['avatar_gallery_path'],
		'T_ICONS'				=> $config['icons_path'],
		'T_RANKS'				=> $config['ranks_path'],
		'T_UPLOAD'				=> $config['upload_path'],
		'SITE_LOGO_IMG'			=> $user->img('site_logo'),
		'A_COOKIE_SETTINGS'		=> addslashes('; path=' . $config['cookie_path'] . ((!$config['cookie_domain'] || $config['cookie_domain'] == 'localhost' || $config['cookie_domain'] == '127.0.0.1') ? '' : '; domain=' . $config['cookie_domain']) . ((!$config['cookie_secure']) ? '' : '; secure')),
	// application/xhtml+xml not used because of IE
	header('Content-type: text/html; charset=UTF-8');
	header('Cache-Control: private, no-cache="set-cookie"');
	header('Expires: 0');
	header('Pragma: no-cache');
	if (!empty($user->data['is_bot']))
		// Let reverse proxies know we detected a bot.
		header('X-PHPBB-IS-BOT: yes');
	return;
* Generate page footer
function page_footer($run_cron = true)
	global $db, $config, $template, $user, $auth, $cache, $starttime, $phpbb_root_path, $phpEx;
	// Output page creation time
	if (defined('DEBUG'))
		$mtime = explode(' ', microtime());
		$totaltime = $mtime[0] + $mtime[1] - $starttime;
		if (!empty($_REQUEST['explain']) && $auth->acl_get('a_') && defined('DEBUG_EXTRA') && method_exists($db, 'sql_report'))
			$db->sql_report('display');
		$debug_output = sprintf('Time : %.3fs | ' . $db->sql_num_queries() . ' Queries | GZIP : ' . (($config['gzip_compress'] && @extension_loaded('zlib')) ? 'On' : 'Off') . (($user->load) ? ' | Load : ' . $user->load : ''), $totaltime);
		if ($auth->acl_get('a_') && defined('DEBUG_EXTRA'))
			if (function_exists('memory_get_usage'))
				if ($memory_usage = memory_get_usage())
					global $base_memory_usage;
					$memory_usage -= $base_memory_usage;
					$memory_usage = get_formatted_filesize($memory_usage);
					$debug_output .= ' | Memory Usage: ' . $memory_usage;
			$debug_output .= ' | <a href="' . build_url() . '&explain=1">Explain</a>';
		'DEBUG_OUTPUT'			=> (defined('DEBUG')) ? $debug_output : '',
		'TRANSLATION_INFO'		=> (!empty($user->lang['TRANSLATION_INFO'])) ? $user->lang['TRANSLATION_INFO'] : '',
		'CREDIT_LINE'			=> $user->lang('POWERED_BY', '<a href="https://www.phpbb.com/">phpBB</a>&reg; Forum Software &copy; phpBB Group'),
		'U_ACP' => ($auth->acl_get('a_') && !empty($user->data['is_registered'])) ? append_sid("{$phpbb_root_path}adm/index.$phpEx", false, true, $user->session_id) : '')
	// Call cron-type script
	$call_cron = false;
	if (!defined('IN_CRON') && $run_cron && !$config['board_disable'] && !$user->data['is_bot'])
		$call_cron = true;
		$time_now = (!empty($user->time_now) && is_int($user->time_now)) ? $user->time_now : time();
		// Any old lock present?
		if (!empty($config['cron_lock']))
			$cron_time = explode(' ', $config['cron_lock']);
			// If 1 hour lock is present we do not call cron.php
			if ($cron_time[0] + 3600 >= $time_now)
				$call_cron = false;
	// Call cron job?
	if ($call_cron)
		$cron_type = '';
		if ($time_now - $config['queue_interval'] > $config['last_queue_run'] && !defined('IN_ADMIN') && file_exists($phpbb_root_path . 'cache/queue.' . $phpEx))
			// Process email queue
			$cron_type = 'queue';
		else if (method_exists($cache, 'tidy') && $time_now - $config['cache_gc'] > $config['cache_last_gc'])
			// Tidy the cache
			$cron_type = 'tidy_cache';
		else if ($config['warnings_expire_days'] && ($time_now - $config['warnings_gc'] > $config['warnings_last_gc']))
			$cron_type = 'tidy_warnings';
		else if ($time_now - $config['database_gc'] > $config['database_last_gc'])
			// Tidy the database
			$cron_type = 'tidy_database';
		else if ($time_now - $config['search_gc'] > $config['search_last_gc'])
			// Tidy the search
			$cron_type = 'tidy_search';
		else if ($time_now - $config['session_gc'] > $config['session_last_gc'])
			$cron_type = 'tidy_sessions';
		if ($cron_type)
			$template->assign_var('RUN_CRON_TASK', '<img src="' . append_sid($phpbb_root_path . 'cron.' . $phpEx, 'cron_type=' . $cron_type) . '" width="1" height="1" alt="cron" />');
	$template->display('body');
	garbage_collection();
	exit_handler();
* Closing the cache object and the database
* Cool function name, eh? We might want to add operations to it later
function garbage_collection()
	global $cache, $db;
	// Unload cache, must be done before the DB connection if closed
	if (!empty($cache))
		$cache->unload();
	// Close our DB connection.
	if (!empty($db))
		$db->sql_close();
* Handler for exit calls in phpBB.
* This function supports hooks.
* Note: This function is called after the template has been outputted.
function exit_handler()
	global $phpbb_hook, $config;
	if (!empty($phpbb_hook) && $phpbb_hook->call_hook(__FUNCTION__))
		if ($phpbb_hook->hook_return(__FUNCTION__))
			return $phpbb_hook->hook_return_result(__FUNCTION__);
	// As a pre-caution... some setups display a blank page if the flush() is not there.
	(ob_get_level() > 0) ? @ob_flush() : @flush();
	exit;
* Handler for init calls in phpBB. This function is called in user::setup();
function phpbb_user_session_handler()
	global $phpbb_hook;
	return;
Re: Probleme beim Instalieren des Boards
Du hast vielleicht nach <? ein oder mehrere Leerzeichen drin, das darf nicht sein.
Ick
Post by Ick »
Hallo Kirk, danke für deine Hilfe.
Nein es lag nicht an einem Leerzeichen, ich hab das ganze Forum und Board nochmals hochgeladen und Instaliert, nach ein paar versuchen und Nervenzusammenbrüchen hab ich es nun endlich geschafft.
Danke Trotzdem
MFG
Sascha
Kleiner Hinweis: Das <? gehört nicht an das Ende dieser Datei oder irgendeiner PHP Datei. ;)
