Top Titles
Current Version: 2.0.2
Released: 2013-10-27
Vampire77
Top Titles
Post by Vampire77 »
Your Portal Version: 2.0.2
Boardlink: http://www.homelessaustralia.com
Just wondering if this is suppose to look like this cause it just doesn't look right.
Any help or ideas grateful. Thanks
Re: Top Titles
You have the link to the portal in the overall_header.html not set correctly.
Open ./styles/prosilver/template/overall_header-html
Find:
<li class="icon-home"><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>&#8249;</strong> <!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> &#187; <!-- ENDIF --> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
Replace with:
Vampire77
Re: Top Titles
Post by Vampire77 »
Great thank you Kirk :) Issue fixed.
