Rokbox not working anymore
Current Version: 2.0.2
Released: 2013-10-27
PaulusB
phpBB.com User: PaulusB
Post by PaulusB »
Your Portal Version: 2.0.2
Boardlink: http://www.vr6clubholland.nl/forum
PHP Version: 5.3.28
MySQL Version: 5.5.37-cll
I installed the the portal. After installing the portal my rokbox (Lightbox) is not working anymore on my RocketTheme Phpbb3 style template. The logon box is not working anymore and the rokbox in the garage is not working anymore example http://www.vr6clubholland.nl/forum/gara ... icle&VID=5 see source code rel="rokbox[1024 768]" the photos only open in de same window now.
Looking for clash between JS scripts but dont see of the portal mod uses js scripts
Anybody know the solution?
Many thanks :mrgreen:
PaulusB
Re: Rokbox not working anymore
Post by PaulusB »
I have replaced the mootools.js en rokbox.js with a newer version but makes no difference.
PaulusB
Post by PaulusB »
I solved it by putting the js dir code hard in the header.
