Install v2.0.2 issues
Current Version: 2.0.2
Released: 2013-10-27
Kurt
Post by Kurt »
Your Portal Version: v2.0.2
I'm moving my b-board (phpbb 3.11 & board v1.3) to a new hosting. There I have a standard setup phpbb 3.12 ready. I imported the DB and converted it to v3.12 with install/database_update.php file that I used from the setup v3.12 package. Board is working so far.
checking portal permissions
trying to look at the error pages in the messages
purge the cache & refresh the styles.
Then I Installed board v2.0.2, following the step by step guide in the package. (funny there I can't copy the modifcations with supplied link? I need to copy manually, I run this file on my local disk)
First error I saw was when running the install/index.php, it says a board table already exists.
Then in ACP I can't access the MOD tab.
It looks like there are still remains of the v1.3 board that are causing issues here?
I working on this all day, are there infact upgrade procedures available?
I did a new install of the phpbb and the board (using my existing DB) but even then I'm getting errors.
Re: Install v2.0.2 issues
You have to first remove all files with board v1.3.
Then install the new version.
Kurt
Post by Kurt »
Since I'm on a new hosting with a default phpbb install, I think all v1.3 files are 'removed', but maybe the database table are causing problems? How can I solve this. Do I manually need to clean up the database?
Also the install af the new version v2.0.2, do I really need to cope each file manually and also do modifications of the files one by one manually? Or is there a sort of automatic install possible?
You have to remove the database entries for v1.3. Calls to the install.xml for v1.3 and click Uninstall.
Kurt wrote:Also the install af the new version v2.0.2, do I really need to cope each file manually and also do modifications of the files one by one manually? Or is there a sort of automatic install possible?
With the Automod it's possible.
Kurt
Post by Kurt »
I uploaded again the original v1.0.3 (not 1.3 like a said earlier) install files to the forum, but when viewing the install.xml, all I see are the instructions how to upload and modify files.
There is no expalantion how the database tables are modifoed for this setup of board v1.0.3.
So how can I undo the database changes then so I can insgtall the latest version 2.0.2 without errors?
Kurt wrote:So how can I undo the database changes then so I can insgtall the latest version 2.0.2 without errors?
Browse to install/index.php and and click on Uninstall.
Kurt
Post by Kurt »
OK I did this step and visited /install/index.php, there I choose uninstall and get a confirmation that the board was uninstalled and also this note;
'Remember to delete the Portal-related files and reverse any Portal-related edits made to phpBB core files.'
In fact so far I don't see any difference on the site, the board is still there and also in phpmyadmin I still have a _portal_config table in my DB.
I do noticed I don't have a MOD tab anymore in ACP.
So it looks I also need to follow the steps in install.xml in 'reverse order' to undo completely the board v1.0.3 setup.
But then I still have the portal table? Do I also need to deleted this table manually? I thought the Uninstall would do this?
That's a lot a manual work, it's a pitty there is no upgrade possible for v1.0.3 to 2.0.2, after all this manual work I will have to re-configure and add the links again in the link section on the 2.0.2 version.
Kurt wrote:But then I still have the portal table? Do I also need to deleted this table manually?
If you do delete it manually, make a backup before.
Kurt wrote:I thought the Uninstall would do this?
So it should be, unless you have these manually in the DB.
Kurt
Post by Kurt »
OK it looks I'm finally managed to reach my goal here. It was a lot of work but I've learned a lot new stuff.
Thanks to Kirk for pointing me in the right direction.
view my result on http://www.lambrettaforum.eu
Looks good, have fun with the Portal. :)
