Newly created module not showing in ACP
Aleyah
Post by Aleyah »
Hello!
I'm here because I need help to create a new module for Board3.
As I'm setting up a new website for a FFXIV Free Company (Same as guilds in WoW), I try to create some new modules for Board3 and phpBB. The first I'm working on is a Recruitement Module which will work almost the same as talonos Warcraft Guild Recruitment block. (Thanks for the inspiration, I'll try to be as close in functionnality but I won't steal your code or, if necessary, will respect the copyrigth :geek: )
The problem is : As I want to test my module on my phpBB installation, I can do a correct installation with the dedicated page in the Board3 configuration but then, I'm unable to add my block in any of the columns of my portal.
I hope I missed something realy simple and that you'll be able to help me!
Here is my git with the code i'm using : https://github.com/Kyah/board3_ffxiv_recruitement
And my web host informations :
:arrow: phpBB 3.0.12
:arrow: Board3 2.0.2
:arrow: php 5.4.25
Thanks! :)
PS : Sorry if my English isn't that good, I'm not a native English speaker :oops:
talonos
Portal Specialist
phpBB.com User: talonos
Re: Newly created module not showing in ACP
Post by talonos »
i've had a look @ your code and removed ALLOT of whitespace and checked things over but still cannot get it to display in the add module page. the upload process works fine.
i even went and streamlined the vars a little so it was a little more readable so i could check over the code and thats still popped up the problem. at first i thought it was a conflict with my recruitment module but its not.
to be honest you can edit my code OR if i have the TIME! and you could provide me with a little info i could possibly build the ACP module for you.
talonos
Portal Specialist
Post by talonos »
ok so i got it going for you :)
http://pretereo-stormrage.co.uk/board3_ ... alonos.zip
take note of a change in filenames to reduce conflicts AND also changes to the Lang template aswell all you have to do now is setup your style html with the revised vars/lang and your up and running
just check over the code and tell me if you have any problems
Aleyah
Post by Aleyah »
Thanks! It works :D
So it seems my problem was the name of my module which was to long or maybe in conflict?
Now that I've a base to work with, I'll try to do something as good as yours 8-)
talonos
Portal Specialist
Post by talonos »
i just rebuilt the module and lang files with the info i could get from your original file. saved me messing around looking for the error. also streamlined it a little for you and gave it a little mark up here and there. i hope it works nicely for you :)
talonos
Portal Specialist
Post by talonos »
did you get this module completed and if so would you like to have it up on my support site for others to make use of it ?
