Ajax Chat Shoutbox Modul
Peyah
Post by Peyah »
ich möchte gerne ein eigenes Portal Modul für den Ajax Chat erstellen, eine Shoutbox.
Ich habe nun schon einiges ergoogled, mit einem workaround funktioniert es auch.
Basierend auf diesem Thread: viewtopic.php?f=23&t=9253
insbesondere auf den Post von Kirk viewtopic.php?f=23&t=9253#p32936
habe ich folgendes gemacht:
Folgende Änderungen an includes/functions.php
'SHOUTBOX'                      => getShoutBoxContent(),
* Shoutbox function
function getShoutBoxContent() {
        // URL to the chat directory:
        if(!defined('AJAX_CHAT_URL')) {
                define('AJAX_CHAT_URL', './chat/');
        // Path to the chat directory:
        if(!defined('AJAX_CHAT_PATH')) {
                define('AJAX_CHAT_PATH', realpath(dirname($_SERVER['SCRIPT_FILENAME']).'/chat').'/');
        // Validate the path to the chat:
        if(@is_file(AJAX_CHAT_PATH.'lib/classes.php')) {
                // Include Class libraries:
                require_once(AJAX_CHAT_PATH.'lib/classes.php');
                // Initialize the shoutbox:
                $ajaxChat = new CustomAJAXChatShoutBox();
                // Parse and return the shoutbox template content:
                return $ajaxChat->getShoutBoxContent();
        return null;
unter phpBB3/portal/modules portal_shoutbox.php angelegt:
* @package - Board3portal v2 Shoutbox
* @ignore
if (!defined('IN_PHPBB'))
    exit;
* @package Shoutbox
class portal_shoutbox_module
    * top        1
    * left        2
    * center    4
    * right        8
    * bottom    16
    public $columns = 21;
    * Default modulename
    public $name = 'SHOUTBOX';
    * Default module-image:
    public $image_src = '';
    * module-language file
    public $language = 'portal_shoutbox_module';
    * custom acp template
    public $custom_acp_tpl = '';
    public $hide_name = false;
        global $config, $template, $user, $phpbb_root_path, $phpEx;
// Show all errors:
error_reporting(E_ALL);
define('AJAX_CHAT_PATH', dirname($_SERVER['SCRIPT_FILENAME']).'/chat/');
// Include custom libraries and initialization code:
require(AJAX_CHAT_PATH.'lib/custom.php');
require(AJAX_CHAT_PATH.'lib/classes.php');
// Initialize the chat:
$ajaxChat = new CustomAJAXChat();
        return 'portal_shoutbox_side.html';
        return array(
            'title'    => 'PORTAL_SHOUTBOX',
            'vars'    => array(),
    * API functions
        return true;
        return true;
unter phpBB3/language/en/mods/portal/ portal_shoutbox_module.php angelegt:
* @version 1.0.0
* DO NOT CHANGE
    exit;
    $lang = array();
// DEVELOPERS PLEASE NOTE
    'PORTAL_SHOUTBOX'             => 'Shoutbox',
unter phpBB3/styles/<stylename>/template/portal/modules portal_shoutbox_side.html
<!--version $Id: latest_members.html 544 2009-09-10 12:35:25Z christian_n $ //-->
{$LR_BLOCK_H_L}<!-- IF $S_BLOCK_ICON --><img src="{T_IMAGESET_PATH}/prosilver/portal/portal_members.png" width="16" height="16" alt="" />&nbsp;<!-- ENDIF -->SHOUTBOX{$LR_BLOCK_H_R}
        <!-- IF not S_IS_BOT -->
        <div style="font-size: 1.2em; margin-bottom: 20px;">{SHOUTBOX}</div>
        <div id="ajaxChatCopyright"><a href="https://blueimp.net/ajax/">AJAX Chat</a> © <a href="https://blueimp.net">blueimp.net</a></div>
Nun zum eigentlichen Problem:
Wie kann ich das Modul nun zum Portal hinzufügen? Im ACP ist es bei den Portal Modulen nicht auswählbar?
Als workarround habe ich nun einfach portal_shoutbox_side.html in attachments_side.html umbenannt, und das Attachments Modul hinzugefügt.
Hätte es aber gern als eigenständiges Modul, damit es auch beim nächsten Portalupdate noch funktioniert.
Re: Ajax Chat Shoutbox Modul
  1. Du hast das hier public $columns = 21; eingetragen, die 21 steht aber für die Mitte, für die Seite musst du 10 eintragen.
  2. Ändere das hier public $name = 'SHOUTBOX'; in public $name = 'PORTAL_SHOUTBOX'; um,
    du hast ja in deiner Language Datei auch PORTAL_SHOUTBOX drin stehen.
  3. Das hier:
    steht für die Mitte, ändere es so um:
  4. Ändere mal in deiner portal_shoutbox_side.html die ersten beiden Zeilen in das um:
Peyah
Post by Peyah »
Das kommt dabei raus wenn man zuviel C&P nutzt und nicht drüber nachdenkt :oops:
Danke für die Hilfe.
Funktioniert jetzt wie gewünscht, außer dass die eigentliche Funktion weiterhin über includes/functions.php aufgerufen wird. Die Funktion in der portal_shoutbox.php hat irgendwie nicht funktioniert, ruft jetzt nur noch die .html auf.
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
just reading over the code and noticed the block title image is set wrong.
theres 2 different ways to have it set right.
/portal/modules portal_shoutbox.php:
find:
replace with:
public $image_src = 'portal_members.png';
/styles/<stylename>/template/portal/modules portal_shoutbox_side.html:
find:
replace with:
OR just edit the html file so it points to the right place.
find:
replace with:
{$LR_BLOCK_H_L}<!-- IF $S_BLOCK_ICON --><img src="{T_IMAGESET_PATH}/portal/portal_members.png" width="16" height="16" alt="" />&nbsp;<!-- ENDIF -->{$TITLE}{$LR_BLOCK_H_R}
you will notice in the above edits that you have
{$TITLE}
instead of the name of the block. that is so any edits to language files are carried into the title of the block aswell.
