Board3 Portal And Themes
Matty
Post by Matty »
Your Portal Version: 2.0.2
Boardlink: http://dayzmancave.com
Checked all the CSS/HTML files, Made sure all was correct
Basically i have a theme installed on my forums, Installed the Portal without a hitch.
BUT, On different resolutions the portal overlaps the theme.. Is there any way that this could be altered so it will automatically fit any resolution ?
Re: Board3 Portal And Themes
Matty wrote:Your Portal Version: 2.0.2
Disable the media block "DayzMancave Stats"
Blame can be the image in the block. ;)
Return to “Styles Support”
