Addon Version: 1.1.0
Addon Author: Talonos
Addon Description: This block is used to display recent activity within a set guild that will show stuff like achievements and epics aquired. very minimal setup required. just input region/realm/guild and set the amount of items you would like to display 1-25. theres also an option to disable images in the block so you can disable them if you have wowhead tooltips set to display icons.
Addon Requirements: Board3 Portal 2.0.0b1 and newer. AND wowhead tooltips from HERE to display popups
Download Link is here:
http://pretereo-stormrage.co.uk/viewtopic.php?f=3&t=17
Instructions:
2. Add new module into left or right column of the portal (ACP > MODS > Portal > Portal Modules).
3: ESSENTIAL - you need a battle.net api key from https://dev.battle.net to make this block functional. your key can be used accross multiple blocks so only 1 key is needed
Demo: http://pretereo-stormrage.co.uk/portal.php
REVISION INFOMATION
1.1.0
Battle.net api changes implemented. block now requires an apikey from https://dev.battle.net to function (key can be used for mulitple blocks)
Initial Release
ACP
Portal Block
