Problem in installation.
Current Version: 2.0.2
Released: 2013-10-27
scorpio
phpBB.de User: Scorpio
phpBB.com User: scorpiors
Post by scorpio »
Your Portal Version: 2.0.2
PHP Version: 3.0.12
I tried to update the portal version 2.0.0
I am trying to update the board portal version from 2.0.0 to 2.0.2 and facing following problem. I am unable to find the error. Please help me.
Re: Problem in installation.
That shounds like one of the default porta modules is not uploaded to your website. Make sure you upload every included file as instructed by the install.xml, or if you are updating take a look at the update instructions.
