[Released] Add-On Block for Advertisement Management
MOB
phpBB.com User: M.O.B.
Post by MOB »
Addon: for Advertisment Management v1.0.10+
Addon Version: 1.0.0
Addon Author: MOB
Addon Description: Block for Board3 Portal to support a block for Advertisement Management. This one will add a block at the bottom of the right column. (If you need one for the left column, just post below, so I can do it for you. :) )
supports Board3 Portal 2.0.x
supports prosilver
supports subsilver2
supports AutoMOD
phpBB3: 3.0.12
Download: B3_Portal_Ad_Mgt_ R_ Block_1_0_0.zip
MD5 checksum 64018A3BC95FB0DF0641CE614EA648B6
Installation level: Easy
AutoMOD: Yes
Installation time: ~2 minutes
Author notes:
  • You should first install Advertisement Management
  • This block should support vertical banners such as: 160px x 600px banners.
  • You'll need to create a new Ad Position in Advertisement Management and then it should give you a position ID like {ADS_10} -- depending how many custom positions you've created.
  • This add-on is not administered in the ACP, you will have to edit the "ads_right.html" file to enter your AD Position ID.
Instructions:
  1. Be sure to make the modifications to your custom style and also upload the two files to their correct directories.
  2. Edit ads_right.html and replace the position ID according to what your Advertisement Management version gives you.
  3. By default the file has {ADS_10} -- but you will need to change that so it displays the ad position you've created.
  4. After you manually edit the file, then purge your cache and refresh your styles.
Screenshots:
Click Here
** NOTE: I haven't learned how to make modules, but as soon as I wrap my brain on it, I may end up updating this add-on--that's if someone doesn't beat me to it--which would be a nice touch for once. :)
Re: [Released] Add-On Block for Advertisement Management
MOB wrote:** NOTE: I haven't learned how to make modules, but as soon as I wrap my brain on it, I may end up updating this add-on--that's if someone doesn't beat me to it--which would be a nice touch for once. :)
Look here:
How to edit a module file
How to create a module zip for Board3 Portal
Crocodile
phpBB.com User: Crocodile442
Post by Crocodile »
I tried to upload this but on upload it says file is corrupt.
What have you for a portal version?
Load each file individually via FTP prescribed in the Directory.
MOB
Post by MOB »
Keep in mind this is not a module you can install using the Portal's installation feature. Instead, you are suppose to use phpbb's automod.
