Your Portal Version: 2.0.1
Hi all,
I would like to know the exact size (in pixel) of the centers blocks.
I'm searching in this forum but no result ...
Any way to make this ?
Thx for your help.
Center block size ?
GlouGlou
- phpBB.de User: Kirk
Re: Center block size ?
The size of the center block is determined by the width of the Forum and the width of the left and right blocks.
GlouGlou
Of course
But how to get it in one block ?
I can get the size by javascript, but don't found the possibility to use the result directly in a block.
Any way or solution ?
heiner
- Valued Contributor
- phpBB.de User: HirschHeinrich
- phpBB.com User: HirschHeinrich
Anpassung des Inhalts-Darstellungsgröße eines Boardportalmodul.
Eine Anpassung der Darstellungsgöße des Inhaltes eines Moduls ist nur per CSS in der zugehörigen portal.module.html möglich
Vor dem eigentlichen Inhalt ist eine Styleanweisung [style)...[/style) einzufügen.
Ohne diese Styleanweisung erfolgt die Darstellung entsprechend Vorgaben des aktuellen Forenstyles.
Sizing of content representation of Boardportalmodul.
Viewing contents of a module is possible only via CSS in the associated portal.module.html
Before the content is to adapt via CSS in HTML [(style)...to insert [(/style).]
Without this the current Forenstyles will be displayed.
Vielleicht interessant/ perhaps look here: viewtopic.php?f=28&t=10471&hilit=Tag+cloud
Heiner
Heiner
GlouGlou
Thx I'm going to look your post (but difficult in german) google translation powa needeed
heiner
try (MS) Microsoft Translator. This is miles better than googles ... (for example inserted as MOD in my own board)
mChat is open.
mChat is open.
