Recent posts : not all the forum are included
Current Version: 2.0.2
Released: 2013-10-27
Draky
phpBB.com User: draky
Post by Draky »
Your Portal Version: 2.0.1
Boardlink: http://www.ouahouah.eu/forum/
Installed Board3.
Change "recent posts forum".
Hello.
I have a problem with the "Recent posts" block.
It displays posts but not from all the forums I selected in the module config !
If I didn't choose any forums, it displays all the recent posts but if I select 2 or more forums, it only displays one recent posts.
Any idea of the problem ?
To test : you can use the link provided with "test" account (password = testtest)...
Re: Recent posts : not all the forum are included
Have you put in to exclude forum yes?
Draky
Post by Draky »
I tried with and without exclusion...
The permissions but correct?
Draky
Post by Draky »
Ok, I found the problem : this module does not take "post-it" thread :lol:
Sorry for my mistake !
Thanks for helping :)
