Need help with Board 3 1.0.6
Current Version: 2.0.2
Released: 2013-10-27
isaqkaloa
Post by isaqkaloa »
Hi, I believe I have Board3 version 1.0.6 installed on my site. I have a lot of mods installed under this portal, but for the last few months, I noticed that now when I go into Admin under .MODS tab , I am only able to see SUDOKU and Who was here mods only, I can not see any other mods. Can you help me figure out what my problem is ? I would also like to move from 1.0.6 to 2.0.1, How do I go about upgrading my portal from 1.0.6 to 2.0.1 ?
Thanks
Re: Need help with Board 3 1.0.6
We normally give no more support for this version. "End of Life" for Board3 Portal 1.0.x
You must first uninstall the old version including all associated files.
isaqkaloa
Post by isaqkaloa »
Thank you for the reply.
So, Are you saying that I need to start from scratch with a phpBB 3.11 and then install Board 3 portal 2.0.1 on it ?
Is there a way that I can upgrade my current portal to 2.0.1 so that I can keep all my mods and settings ?
isaqkaloa wrote:So, Are you saying that I need to start from scratch with a phpBB 3.11 and then install Board 3 portal 2.0.1 on it ?
No, only uninstall the portal, including all files that belong to the portal.
isaqkaloa
Post by isaqkaloa »
I do not see an Uninstall Portal option in the Admin Panel. The only two Mods I see under the .MODS tab in admin are: SUDOKU -> General Settings and Who Was Here? -> Configurate "Who was here?" I have a lot of mods installed but these are the only two I see.
So Do I need to manually remove the folder and files associated to Portal 1.0.6 ?
Work the install.xml for Portal 1.0.6 backwards from.
While you do that, please make sure to upload the Board3 Portal 1.0.6 installer first and try to uninstall the MOD with it. Afterwards you can undo the file changes and remove the old files.
isaqkaloa
Post by isaqkaloa »
Okay, Thank you Kirk, and Marc... Will give it a try on the weekend.
Thanks for the tips.
