Boardlink: http://www.centaurus-sgc.com
I have researched these forums over and over and over again, I have found some advice that told me to go into my colours.css file and change some background colors but its not working. If you visit my site it will show you that I am using the BlackPearl Template and the blocks are different colors.
I have researched these forums over and over and over again, I have found some advice that told me to go into my colours.css file and change some background colors but its not working. If you visit my site it will show you that I am using the BlackPearl Template and the blocks are different colors. I would like to know what file I must edit to be able to change the block colors. I am fairly new to PHPBB boards but I love this Portal it makes my site look and feel better. Thanks for the great source.
Thanks
Jon
Block Background Colors
