Portal problem after update
Current Version: 2.0.2
Released: 2013-10-27
Nemo
Post by Nemo »
Boardlink: http://nlfow.nl
Trying to upgrade to 2.0.0 from 2.0.0b
Have been trying all day to make it work. Going over and over it again.
phpBB Debug] PHP Warning: in file [ROOT]/portal/modules/portal_birthday_list.php on line 58: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead
No clue to what this refers to.
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4690: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4692: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4693: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4694: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
I saw the latter problem appearing several times on this forum, I tried to solve it using the mentioned solution but no luck.
Any help is appreciated.
Frank
Re: Portal problem after update
When does this error actually appear? On the update page or on the portal after updating it?
