Auto image resize
Mordynak
Auto image resize
Post by Mordynak »
Your Portal Version: 2.0.1
Boardlink: http://highrock.project-tamriel.com
Nothing yet
I tried to add this.
.portal-body img{
padding: 3px;
max-width: 100%;
Hi again. Got a minor problem that i cant seem to figure out.
On my board i added
/* AUTO RESIZE IMG IMAGES*/
.postbody img{
	padding: 3px;
	max-width: 100%;
To the bottom of common.css to stop images from breaking out of the theme no matter what size they are.
And i wanted to be able to post images that would show up on the announcements block in the portal. Problem is that the images are full sized on the portal.
Any ideas how i could fix this?
Thanks in advance. I really love this portal, keep up the great work![/i]
Re: Auto image resize
At max-width: 100% the images are displayed in original size.
Try it this way
.postbody img{
   padding: 3px;
   max-width: 700px;
Change the value 700px as you want it.
Mordynak
Post by Mordynak »
Not thats not actually the problem. The images display at 100% of the post body with a padding of 3px. So if i resize the window the images scale with it.
The problem is that this doesnt work in the announcements part of the portal. So if an announcement post contains an img it stretches the entire page.
Put this code in the portal.css
.postbody img {
    max-width: 500px;
    padding: 3px;
A look here: http://allround-phpbb.de/viewtopic.php?p=3622#p3622
Mordynak
Post by Mordynak »
Sorry if i sound rude but i think you are missing the point.
This code here...
.postbody img{
	padding: 3px;
	max-width: 100%;
Works 100%, it literally does exactly as i wish. However, it only affects the forum itself, and not the area on the portal.
Say there is an image in an announcement, it will display on the portal, but instead of automatically resizing like it does on the forum itself, it displays at full size.
EDIT:
If you look on the announcements here
http://highrock.project-tamriel.com/portal.php
You see the second announcement down the list has massive images, they are at full size.
Whereas in the actual topic itself
http://highrock.project-tamriel.com/vie ... ?f=57&t=13
They are automatically scaled to fit the width of the post body / window.
You can create a different BBCode with its own name:
BBCode-Name:
[Imgres100]{URL}[/Imgres100]
html:
<img width="100%" src="{URL}" />
Or change like this:
In line with this snippet: externe Bilder zu groß
External images to message size
Open root/includes/bbcodes.php :
search:
'#\[img:$uid\](.*?)\[/img:$uid\]#s'		=> $this->bbcode_tpl('img', $bbcode_id),
replace this:
'#\[img:$uid\](.*?)\[/img:$uid\]#s'     => '<img alt="Image" src="$1" style="width:100%;" />',
Mordynak
Post by Mordynak »
Ahh i thought it might end up with something like that.
In that case I'll just use the highslide image code instead.
Thanks for all the help guys i really do appreciate your time.
Just curious. I dont suppose you know if its possible to change the img implementation?
<div class="highslide-gallery">
<a href="{URL}" class="highslide" onclick="return hs.expand(this)"><img src="{URL}" alt="" title="Click to enlarge" style="max-width:300px; max-height:300px;" /></a><div class="highslide-heading"></div>
It would be nice to have the standard img bbcode to do this. Instead of having a separate one.
Much appreciated!
I move the topic, as it relates to phpBB.
Mordynak
Post by Mordynak »
Thank you for moving the topic for me Archivar.
Is that part you posted from the bbcode.php where i can add this?
Thanks again
archivar wrote: In line with this snippet: externe Bilder zu groß
search:
replace this:
when they highslide replace this:
    '#\[img:$uid\](.*?)\[/img:$uid\]#s'        => '<a href="$1" class="highslide" onclick="return hs.expand(this)"><img alt="Image" src="$1" style="width:100%;" /></a>',
Mordynak wrote:Thank you for moving the topic for me Archivar.
Thanks again
Or they just do that:
    <a href="{URL}" class="highslide" onclick="return hs.expand(this, { wrapperClassName: 'controls-in-heading', slideshowGroup: 'highslide' })">
      <img src="{URL}" width=100% />
    </a>
    <div class="highslide-heading"></div><br />
Mordynak
Post by Mordynak »
archivar wrote: when they highslide replace this:
This was absolutely perfect! Also I like that you added the image scale in there for me too.
Also, my apologies Kirk. I completely misunderstood you.
Thank you both very much, you've both been great help.
EDIT: I'd just like to add that i changed it from 100% to 98% because it slightly cropped off the right edge. I may still change it to pixels anyway and have small boxes. If only i could figure out how to have them side by side.
EDIT 2: Wow, just changed the width to 200px and they sit side by side. Most places ive searched for said that it was impossible. Youre the best Archivar!
Mordynak
Post by Mordynak »
Hi guys. As much as i appreciate your help ive noticed a minor issue.
Obviously all this affects all uses of the [IMG] bbcode. This is generally fine for everywhere, except for signatures.
Would it be possible to make it not affect them or should i just settle with a new bbcode?
Thanks a lot in advance!
